Old 07-09-2010, 10:26 PM   #26
raycow
Re: what gears do i need on differential?
Originally Posted by gdogg14 View Post
I would like to cruise down the road 70mph @ no more than 3000 RPM, I may get that with a 3.07 raito but will it have enough power to get itself going from a dead stop.
Easily. 3.07 was a factory option on these trucks, and GM doesn't like to sell parts combinations that are going to result in unhappy customers.
Ray
raycow is offline   Reply With Quote
Old 07-10-2010, 12:09 AM   #27
ERASER5
ERASER5's Avatar
I agree with Ray. The 3.08 (3.07) was probably the most common C10 ratio out there. This is not a hot rod gear, it is a mileage gear, but it still gets it done. I ran 2 different trucks on 31" tires with no problems for years.
Ray and I agree on the easiest way to check gear ratios too. Simple, fast, non-intrusive, accurate.
'70 GMC C1500 LWB
Power disc brakes. WooHoo!
Posi 6 Lug Dana 60
ERASER5 is offline   Reply With Quote
Old 07-10-2010, 10:16 PM   #28
camaney
ok so ihave 4.11 gears and im thinking on puting 3.40s do u think that i will have any problems if i do? also what other driveshaft from another vehicle will fit whit out cutting or anything?(shortbed). i never done gear changing before but i seen videos they use some kind of tool with a gauge dial. do i realy need that tool or should pay someone who knows how?
camaney is offline   Reply With Quote
Old 07-11-2010, 04:57 PM   #29
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
if you have no idea whats involved, then I'd recomend paying someone. The problem is, it won't be cheap.
Even if you had the tools there for you, this isn't something most people should try. If you don't get it dead nuts right, it'll chew them up and spit them out, and damage other stuff at the same time.
Old 07-11-2010, 06:27 PM   #30
LONGHAIR
Yeah, what he said^^^
Gear swapping is not a job for a novice. Pay a pro, it will still cost less in the end. Destroying parts and having to pay to fix it after it fails, is expensive.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 07-11-2010, 11:38 PM   #31
raycow
You will come out ahead by buying a complete rear end with the ratio you want. This will be much cheaper than buying gears and paying someone to set them up in your housing. The rear end swap is something you can do yourself without needing any special skills or tools.
When you are done, you might even be able to sell your old rear to someone who wants the ratio that's in it.
Ray
Old 07-12-2010, 06:28 PM   #32
292farmer
292farmer's Avatar
whats wrong with the driveshaft?
1972 gmc c25 292/sm465 dana 60 w/5.13s
1973 vw super beetle 1600cc/4spd(baja bug)
1974 chevy c60 351v6/np-540+2 speed eaton rear
2005 chevy cobalt 2.2l
292farmer is offline   Reply With Quote
Old 07-12-2010, 10:49 PM   #33
camaney
thanks my mecanic coute me$150 for the job i think is cheap where can i buy the ring and pinion? i want to change the drive shaft with something lighter like my newer gmc is some kind alloy metal
Old 07-13-2010, 12:32 AM   #34
raycow
If you want to install 3.07 gears you will also need to replace the differential case. This is the part that the ring gear bolts to. Your mechanic will probably not want to press off your old bearings and re-use them on the new parts, so this means you will need new bearings. You will need new seals and gaskets also. At this point, you are way beyond the cost of a salvage yard rear.
Ray
