07-10-2010, 09:05 PM | #51 |
Re: Wing or vent window rebuild
Exactly; that upper pivot is what I'm referring to. Is it better to remove the 'pivot' rivet or the two the retain the pivot bracket?
07-11-2010, 10:11 PM | #52 |
1 thing at a time is progress.
I didn't try removing the 2 rivets. So I can't speak from experience on that. Do you have a spare to try it on? I looked for my other vent window frame I had to put together and can't find it anywhere. It will pop up someday LOL
Alan
Philippians 2:14-16 |
07-11-2010, 10:56 PM | #53 |
I have not tried anything. I was trying to determine which would be the better/easier route before doing something regrettable.
07-11-2010, 11:00 PM | #54 |
If I did it again I would do the single pivot rivet. IMHO
Alan
07-11-2010, 11:05 PM | #55 |
Looks like that one is the easiest to access as well. Where can a guy find those 'pivot' rivets? They don't look like a standard rivet....
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 07-11-2010 at 11:05 PM. |
07-11-2010, 11:08 PM | #56 |
The rivet is a stepped rivet. I know Tim Christian has sold his business. You might PM him he might help you out. he helped me out when I needed another
Alan
Philippians 2:14-16 Last edited by Alan's Classic; 07-11-2010 at 11:09 PM. |
07-11-2010, 11:13 PM | #57 |
You can see the rivet in the bottom right of the bag.
Alan
07-12-2010, 08:53 AM | #58 |
i ended up just using aluminum pop rivets too, 100X easier, looks just as good, can do w/out help, BUT is not original like CHEVY FLEETSIDE said.
I just taped off the striker plate when i primed/painted the frame. really makes a world of difference in sealing up the vent windows.
Life's journey is not to arrive at the grave safely in a well preserved body, but rather to skid in sideways, totally used up and worn out, shouting '...man, what a ride!' GC |
08-27-2010, 04:10 PM | #59 |
Easy Does It
Hey Alan, did you say to install the rubber around the vent window frame first then the short piece along the glass channel runner? if so why is that? thanks
08-27-2010, 07:23 PM | #60 | |
Because if I remember right the soft rubber around the hoop tucks in behind the rigid verticle piece that has the 4 rivets. It was very difficult to tuck the weatherstrip in with the verticle piece riveted. Basicaly get everything in place before the rivets go in. Hope this clears it up.
Alan
Philippians 2:14-16 Last edited by Alan's Classic; 08-27-2010 at 07:25 PM. |
08-28-2010, 08:13 AM | #61 |
I bought my weatherstrip kit from truckandcarshop.com. The special rivits for the weatherstrip are too short for the weatherstrip that they sell. I used regular pop rivits and weatherstrip adhesive for the one I could not get to. After reading here about how much trouble they are to replace, I did not replace my pivot stepped rivit.
BTW most of the stuff I bought from truckandcarshop.com has been fine. The original style firewall pad was real hard to install even with 2 people. The door to cab weatherstrip has been on B/O for a month. They said it should be in any day.
Father and son built. Driven daily since 2012. 283, 3 speed. Mostly original. '81 PS and disk front. Fuel tank relocate. Maintenance, repairs and upgrades on his dime now. http://zacks64longfleet.shutterfly.com/ Higher res. photos in my gallery. Last edited by ljackson; 08-28-2010 at 08:40 AM. Reason: spelling |
08-28-2010, 09:33 AM | #62 |
MBGMIKE , what is the part# for that rivet tool?Couldn't find in your site.Thanks!!
08-28-2010, 09:53 PM | #63 |
Easy Does It
Alan, thanks for the help, great thread -thanks for sharing.
08-28-2010, 10:13 PM | #64 |
I still have another one to do. Nothing like procrastination.
Alan
08-29-2010, 09:19 AM | #65 | |
http://www.mcssl.com/store/mikesbump...ndgarage/tools They can be fabicated out of steel or aluminum. These are cast. They use a 1/2IN Fine thread bolt drilled out and you press fit the two dies in. Pretty simple. We sell the revits and all from 1 to 50 per box. http://www.mcssl.com/store/mikesbump...092dcf2901a8b7 these work great to Last edited by mbgmike; 08-29-2010 at 09:36 AM. |
09-23-2010, 09:32 AM | #66 |
Good info
1972 SWB Medium Olive South Houston Instagram: Antbish84 |
09-28-2010, 05:43 AM | #67 |
Thank you for posting this (how too) on wing or vent window rebuild, I found it a benefit in rebuilding my 67-72 vent window.
I think it should be moved or copied into the FAQ/how too section of this forum for the benefits of all the forum members regardless what year truck their working on. I did have some minor tips to rebuilding the vent window that I posted in my build thread that possibly will make it a little easer to do the rebuild. Just a small addition to this good post. If you’re interested in the tips (see post #399) http://67-72chevytrucks.com/vboard/s...11#post4213711
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=318544 |
10-24-2010, 12:02 AM | #68 |
Great write up Allen!! I am going to tackle my vent windows tomorrow this thread makes me much more confident.
03-13-2011, 11:15 PM | #69 |
The second one is always easier. The first time I installed the rigid strip first. That for me was a no-no. The wrap around goes in first as seen below.
Parts laid out on a padded work bench. With some lube for it to squeeze into the channel I installed the wrap around piece first. The rigid piece needs to be bowed a little to get it in the corner pockets. The wrap around didn't fit as well as the first one. It seemed a little short on both ends. I pulled it back out of the track some to fix the end gaps by shifting it. I trimmed about 1/8" off because it binding on the pivot bracket. It really didn't help much it was just too short. With everything in and lined up it's ready for the rivets.
Alan
03-15-2011, 08:46 PM | #70 |
Insert the glass frame in place while installing the washers that you made note of their position earlier. I oiled the washers and anything that moves just in case.
These two pics show the stop washer in place. I then inserted an awl in the pivot rivet hole and made sure the window opens and closes like it should. Then installed the rest of the washers, spring, nut and lock. I tightened the spring until the felt right. You don't want it flopping going down the road with it open. I used the "TLAR" method. That means "That Looks About Right" Once your satisfied with the operation install the pivot rivot and handle. This is the finished product minus the glass.
Alan
Philippians 2:14-16 Last edited by Alan's Classic; 03-15-2011 at 09:08 PM. |
11-23-2012, 10:17 PM | #71 |
TTT since there have been several questions coming up.
Alan
12-16-2012, 01:51 PM | #72 |
06-24-2013, 07:29 PM | #73 |
Quick question (hope someone answers), if I pull the vent window and divider out and drive around for a few days like that, will it cause the door to distort at all?
Posted via Mobile Device |
06-24-2013, 07:58 PM | #74 |
Does it matter or is it easier to install the glass into it's frame before or after installing the glass frame into the vent window assembly? Alan's pictures show the completed assembly without the glass so I assume he put it in after. I have heard thought that installing the glass into it's frame may require force to seat it properly which I think may be better to do before. Any opinions?
06-24-2013, 08:00 PM | #75 |
I doubt it since the vent window assembly is not a structural part of the door.
