Old 07-12-2010, 01:27 AM   #401
Fer79
Fer79's Avatar
Re: my 80 build
nice...
Fer79 is offline   Reply With Quote
Old 07-12-2010, 01:38 AM   #402
flamingbig10
6.0 powered square
flamingbig10's Avatar
Re: my 80 build
thanks guys and I also got a few parts for ls swap a new 87 fuel tank, fuel filler hose, and anti rattle rubber, next will be the fuel sender, pump, also a 87 metal fuel filler line and the shield that connects to bed
Aaron
1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot
Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326
flamingbig10 is offline   Reply With Quote
Old 08-02-2010, 12:22 AM   #403
flamingbig10
6.0 powered square
Re: my 80 build
my truck was running a little warm yesterday going to a car show it was about 100 out and the traffic was bad, since my cooling fan isn't best I'll upgrading to a dual setup and fan controls
http://www.summitracing.com/parts/HDA-3654/
http://www.summitracing.com/parts/BCI-75007/?rtype=10
Aaron
Old 08-03-2010, 10:24 AM   #404
JohnC
JohnC's Avatar
Re: my 80 build
Those will look sweet on there man!
JohnC is offline   Reply With Quote
Old 08-05-2010, 09:58 PM   #405
flamingbig10
6.0 powered square
Re: my 80 build
thanks John, I just spent 1500 on the truck, hint once installed I'll be roasting a tire with ease
Aaron
Old 08-05-2010, 11:05 PM   #406
menace121978
menace121978's Avatar
Re: my 80 build
"Dennis the Menace"
1978 Silverado (2wd, 1/2 ton, short bed)complete nut & bolt frame off restomod LQ9/4L80E
MY LS SWAP/FRAME OFF BUILD BOOK
2006 TBSS way too much to list
menace121978 is offline   Reply With Quote
Old 08-05-2010, 11:28 PM   #407
flamingbig10
6.0 powered square
Re: my 80 build
now time to find a 4l80 my plan is to find one without a converter if so I'll add one with around a 1500 stall and a mild cam, but the parts I do have is a brand 87 fuel tank and sender, with hoses and fuel filler tube, and I plan getting the harness lengthened so I can sill keep the wires hidden and mount the computer behind the glove box
Aaron
Old 08-06-2010, 02:07 PM   #408
JohnC
JohnC's Avatar
Re: my 80 build
We need to put that on the list of to do's also. You need to be roasting "TIRES" not just one.
Old 08-06-2010, 07:18 PM   #409
flamingbig10
6.0 powered square
Re: my 80 build
don't worry it will get, 373 and posi traction,
Aaron
Old 08-12-2010, 12:49 AM   #410
flamingbig10
6.0 powered square
Re: my 80 build
the engine finally shipped so it should be here some time next week
Aaron
Old 08-12-2010, 08:07 PM   #411
flamingbig10
6.0 powered square
Re: my 80 build
look what followed me home
Aaron
Old 08-12-2010, 08:12 PM   #412
menace121978
Re: my 80 build
"Dennis the Menace"
Old 08-12-2010, 08:18 PM   #413
3r!c84
Badass
3r!c84's Avatar
Re: my 80 build
haha ride the bumpstops on the way home? what is it ?6.0
Think outside the box?
-84c10 (1stcar)→My Build
-00 Saturn 5spd
drop a gear and disappear!
1/4:13:90
3r!c84 is offline   Reply With Quote
Old 08-12-2010, 08:22 PM   #414
flamingbig10
6.0 powered square
Re: my 80 build
yes it a 6.0 but need study a little more to make sure its the lq9, and it had a half inch with the c-notch and stubby bump stops
Aaron
Old 08-12-2010, 10:37 PM   #415
flamingbig10
6.0 powered square
Re: my 80 build
I starting disconnecting the wiring harness, but didn't get very far, it was hot outside
Aaron
Old 08-12-2010, 11:48 PM   #416
jgh64pkup
Sunburst C10!!!
jgh64pkup's Avatar
Re: my 80 build
i dont think its gonna be a lq9
its probably a lq4
Gage
1967 C10 Shortbed Stepside
jgh64pkup is offline   Reply With Quote
Old 08-12-2010, 11:50 PM   #417
flamingbig10
6.0 powered square
Re: my 80 build
I look it up its a lq9 what I ordered
Aaron
Old 08-13-2010, 12:02 AM   #418
3r!c84
Badass
3r!c84's Avatar
Re: my 80 build
drop it off at mmy house if its not the lq9 (:
-00 Saturn 5spd
1/4:13:90
Old 08-13-2010, 09:13 AM   #419
flamingbig10
6.0 powered square
Re: my 80 build
only if it was 4.8, when I got the motor it had two things wrong with it, was the oil cap was missing and the Idler pulley was broken so I emailed the seller I they said "I apologize for that and I will make it right. I will send a cap and replacement idler pulley"
Aaron
Old 08-13-2010, 09:31 AM   #420
menace121978
Re: my 80 build
glad to see you got it and they are making it right. to double check if its a lq9 pull the plugs out and the pistons should be flat top. the lq4's are dished.
"Dennis the Menace"
Old 08-13-2010, 11:26 AM   #421
Driveway Dreams
I have car A.D.D.
Driveway Dreams's Avatar
Re: my 80 build
Man, its been a while since I have gotten on here. Glad to see you got the LS. That is gonna be one sweet truck very soon. Way to go Aaron!
-Gerald
Building vehicles in memory of the first "car guy" I ever knew, my Grandpa. Bob Dunham 1935-2009. Rest in peace.
61 GMC Suburban SOLD
The 86 build thread SOLD
Are you a Colorado member?Click here.
Driveway Dreams is offline   Reply With Quote
Old 08-13-2010, 10:46 PM   #422
flamingbig10
6.0 powered square
Re: my 80 build
thanks Dennis, I did get the motor down to a long block today, but it kind of hard doing it in the bed of the truck I was able to borrow a engine hoist so tomorrow I will be able to get the engine de greased
Aaron
Old 08-14-2010, 01:03 AM   #423
flamingbig10
6.0 powered square
Re: my 80 build
Aaron
Old 08-14-2010, 08:53 AM   #424
JohnC
JohnC's Avatar
Re: my 80 build
Nice score man!
Old 08-16-2010, 12:30 AM   #425
flamingbig10
6.0 powered square
Re: my 80 build
thanks John, cleaned up and painted the alternator, power steering pump bracket, and water pump and started cleaning on the engine
Aaron
