07-12-2010, 09:50 PM | #1 |
Source for stock 4x4 springs? 71 blazer
Looking for a good source for a set of front and rear stock height springs.
too many problems with my lift kit, it's time to go stock with some zero rates. Thanks for the help. |
07-12-2010, 10:39 PM | #2 |
Re: Source for stock 4x4 springs? 71 blazer
What probs are you having? I'd love to see more pics of your Blazer. I'll keep an eye out for stock springs.
07-12-2010, 11:00 PM | #3 |
It just doesn't handle well. Lots of body sway and roll. My bushings are shot which I am sure is a major cause. I need to replace all the bushing and if I am going to have it that far torn down I might as well change out the springs. I have wanted to bring it down to about a 2 inch lift since I bought it and now think I would rather get back to stock height plus a zero rate in the rear for some leveling. I have replaced and repaired the entire front end trying to get it to drive decently. The front end is tight now, but it still rides like an out of control brick. My wife (and me at times) is terrified to drive it. It's my DD and I need it be a better all around truck.
It has a 4'' lift with springs front and back plus a 4 inch block in the rear. I suspect the block was added after the initial lift because the back looked saggy. I have 10 inches on the tape measure between the top of the tire and the outer fender on the front, I didn't measure the back. EDIT: Looks like 12" inches in the back. A couple of pics for you. At work one day. I guess I didn't get the "buy a new black tahoe" memo. Last edited by AlaskaMatt; 07-14-2010 at 10:10 PM. |
07-12-2010, 11:25 PM | #4 |
I have a 4" lift and 33's and experienced something similar. The culprit, the u bolts in the front were loose and the spring pack wld slide along the perch until there was no more room. Scarry. I tightened them up and immediately noticed a big diff. Your rig looks great. Alaska is so beautiful. Def provides a great backdrop the pics. Btw, how does the blazer do in the snow?
07-12-2010, 11:30 PM | #5 |
OK now that is scary! I am going to go check them now even though I know they are tight.
The blazer is actually great in the snow. I do run pizza cutters though and that helps greatly. Wide tires on snow and ice are just begging for the slip and slide. On bare ice the blazer can be a little interesting but so is everything. |
07-12-2010, 11:47 PM | #6 |
How are the brakes? Steering? I noticedthat it is higher in the back. what block are you using? Here's mine. Yours is cooler with the jerry can holder and Alaska.
07-12-2010, 11:53 PM | #7 |
brakes are good, just had them redone last week. Steering is really pretty darn good too.
Really it's just short wheel base with too much suspension height to wiggle around on. I don't know what brand of block but I am sure it's part of a skylift or one of the typical kits. The swing out gate and can holders are a mixed bag. I am working on a redesign that I hope to fab up this winter. Same concept but in a more modular design so I can pull them off when not in use. BTW I love the the color of yours, but just can't sell the wife on it. Last edited by AlaskaMatt; 07-12-2010 at 11:56 PM. |
07-13-2010, 12:11 AM | #8 |
I don't know, I tow my boat with mine and it handles really well. Hmmmm......
07-13-2010, 12:15 AM | #9 |
Yeah I have many people tell me their 4 inch lifts handle great. Mine just doesn't and the mechanics etc I have jump in and ride along agree. Something is out of whack.
07-13-2010, 12:49 AM | #10 |
Is the rear to high or are your front springs sagging? Another thing that causes these trucks to wander is the lack of a sway bar in the front. a nice and fairly cheap improvement is a steering stabalizer to dampen some of that movement as well. No matter if you go back to stock or not these trucks will not handle like the newer stuff and not many of our spouses like to drive them for whatever reason.
Enjoy, Matt
72 chevy k-10, swb, auto, 35's, rally's, posi, 4" lift, 2.5" old style 40 series flows with headers and crossover pipe and some other stuff!! |
07-13-2010, 01:31 AM | #11 |
I do think the rear is too high. The front still have a positive arch and I don't think they have sagged. A sway bar would be nice! Most of my movement seems to come from the rear. You can feel it swing around like it's hinged at the top of the spring mounts.
There are other reasons for bringing it down to stock or a milder lift, both handling and comfort. It will always ride like a "truck" but safe and stable should be attainable. My wife doesn't have to like it, just not white faced and sweating after running down the highway! |
07-13-2010, 07:19 AM | #12 |
I think if you have done all that I wld swap out the bushings in the leaf packs prior to ditching the lift. Maybe your stock rear springs are the problem too. They could be twisted or misaligned with eachother. Maybe the pin that holds them together has sheared? Just trouble shooting.
07-13-2010, 09:53 AM | #13 |
GEARHEAD
Replacement springs are available at most auto parts stores. They might have to bring them in from a warehouse, but they are available. I just checked rockauto.com and they have them for $144.89 each rear and $226.79 each for front.
I think replacing the spring bushings and checking the condition of the shackles is where I'd start though. 4" of lift isn't that much and should not cause it to feel dangerous.
If no one knows what you're doing, they can't tell you you're doing it wrong HG's Dream Car Build - Shelby Cobra Kit Build your own adjustable track bar 71 Long Fleet C/10 72 Jimmy 4x4 (Junkyard Jimmy) HG's Plow Truck '78 K35 Dually Bigass Farm Truck HG's thread of miscellaneous stuff |
07-13-2010, 10:06 PM | #14 |
I'm a poor spectator
Here's my story and maybe you can relate:
I had the rearend in my blazer go out and since I had never done that sort of thing before I wanted to give it a shot. It looked like a huge PITA to lay under trying to set the gears so I pulled the whole axle out and put it on some jackstands to set the gears up. Anyways, gear swap went well and I put the axle back under the truck and go it all buttoned up except for the shocks. I wanted to replace the shocks with new ones since the old ones were junk so I decided to drive it to work w/o rear shocks and pick some up on the way home the next day. I noticed at first it was a pretty boat like ride but once I got on the highway and picked up some speed it got worse but it wasn't until I started making a sorta sharp turn at speed that it got really bad, the road had some good bumps and as I made the turn the back end started to bounce and actually caught air!! It was scary as hell and obviously I shouldn't have ever driven it in that condition but I did and I definitely learned my lesson. So what i'm trying to ask is are you sure your shocks aren't junk? After my experience, it sounds like it's possible from what you're saying.
2006 Jeep Unlimited IMPACT ORANGE 1993 Chevy 2500 4x4 ExCab LWB 454/NV4500 Tow rig 1977 Ford F100 2x4 LWB 1st truck I owned, still have it!!! 1979 Ford F150 4x4 SWB Built Ford Tough!!! 1971 Chevy Blazer 350 / SM465 / NP205 UNDER CONSTRUCTION Soon to have a LQ4 6.0!!! |
07-13-2010, 11:11 PM | #15 |
Yeah that's scary! Not sure at all. They may be junk, however they are stiff as hell... so who knows. My bushings are definitely shot and I may start there and see what happens. $100 for bushings or a grand for new springs. Bushings sound pretty good.
07-15-2010, 02:12 PM | #16 |
Wish you were closer to me, I have some stock rears I could give you.
07-15-2010, 05:25 PM | #17 |
Hey thanks, I am 90% ready to pull the trigger on a 2.5" skyjacker set of springs (all around springs no blocks) as they are much easier to get here. That I know my 33's will clear no problem.
Hopefully the ride is improved and the handling issues dealt with. I am thinking I will go with adjustable shocks in the rear so I can crank them down to tow my little camp trailer (12 ft). |
07-30-2010, 07:25 PM | #18 |
Ready, Set, Off-Road!
Hi Matt,
Were you able to resolve the suspension issue? I just bought a 72 Blazer with the identical problem as yours and similar suspension. Mine also has a 4inch lift with rear blocks and busted bushings. The only difference is that I already changed the body bushings and the shocks which improved the ride but it still feels loose. Thanks, Mario |
07-30-2010, 07:42 PM | #19 |
What?
One thing to consider if you are still trying to figure out what to do about the springs...
Find a tractor truck brake and suspension garage, they make new spring packs for the big trucks all day long. Being that my burb has springs no one makes anymore, I took it to one of those and they made up a really nice set of four for me. Plus, being that the suspensions are their gig they should be able to figure out right away what may be amiss with your set up. Good luck!
Chris 1968 K20 Suburban 1972 K10 LWB PU |
07-31-2010, 12:30 PM | #20 | ||
If you have been through the suspension I would focus on the front end. I would be more concerned about mine but the entire front end was replaced and repaired a year ago and it's still very tight upon inspection. I am pretty sure my issues are "rear wheel steering" induced by the overtall springs blocks and shot bushings. Quote:
At another shop they quoted me a 2.5/4 all spring skyjacker installed for $500 less and they would have the parts in two weeks. Much better. So I put a deposit down and they should be in next week. Last edited by AlaskaMatt; 07-31-2010 at 12:32 PM. |
08-05-2010, 10:32 PM | #21 |
So here is the old.
Here is now It doesn't look like much change in the photo, but it really did drop it down to a more reasonable level. Mostly in the rear. The front came down some too, and I will be swapping the pitman arm back to the original as the raised arm is now too high. Bushings are all replaced and that helped a great deal. The skyjackers ride very nicely compared to what was in there. I checked the body mounts and they appear to be fine, so I rule them out as a handling issue. It's driving MUCH better. Not as well as I would like, but certainly acceptable. I am going to continue to fuss with it until it handles how I want it to. At this point I am simply venturing into "want" territory not "need". Next step is a steering stabilizer and a set of roadmasters. |
08-05-2010, 11:52 PM | #22 |
20' Daredevil (Ret)
Just saw this -- nice looking Blazer! I think you'll be happy with that suspension. I have the same front springs on my K20, never did use the rear blocks, but I have rear AAL so it sits nearly level. In fact, it looks similar to the way your Blazer sits, nose up just a hair.
In case you need shocks (and didn't already know this), standard rear shocks work well on the front with 2.5" springs. My stock front shocks were too short.
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay |
08-06-2010, 01:02 PM | #23 |
72 K/5 Junkie
Looks a lot better I think, with the 2.5's. Good match for the 33's
08-07-2010, 01:34 PM | #24 | |
I thought so too. Now the 33's look just right. Last edited by AlaskaMatt; 08-07-2010 at 01:35 PM. |
08-10-2010, 02:37 AM | #25 |
Just a quick update. The steering stabilizer was the missing ingredient. Man it drives sooo nice now.
