Old 06-23-2010, 11:29 PM   #351
cstm68
cstm68's Avatar
Re: my 68 shortbed build
here are some pics from today, i got the diff pulled and took it to work to do axle bearings and seals and replace the pinion seals and crush sleve,
also got the c notch bolted in the rest of the way. im going to weld it in a few more spots also.
i just have one question. how do mark the bottom of the frame to drill the 2 3/8 holes to bolt the bag to and the 1'' hole for the fitting??
68 swb fleet bagged on 20's 327 with 4 speed http://67-72chevytrucks.com/vboard/s...d.php?t=223308
2014 Chevy 2500hd duramax CCLB
cstm68 is offline   Reply With Quote
Old 06-24-2010, 11:54 AM   #352
VA72C10
VA72C10
VA72C10's Avatar
Looking good. I marked my holes by making a paper template with the holes matching up to the plate on the airbag for the fitting/bolt holes. Taped it to the bag with some painter's tape. Had tape under the template sticky side up as well. So when I raised up the trailing arms till the bags touch the frame, you loosen the tape holding the paper template to the bag and attach the tape that was sticky side up to the frame....drop the trailing arm/bags and the paper template is left behind. Mark, repeat, and drill
Old 06-24-2010, 09:23 PM   #353
cstm68
cstm68's Avatar
sweet thanx, i junt need to bolt the rear end in now so the trailing arms are squared up rite !
Old 06-24-2010, 09:32 PM   #354
VA72C10
VA72C10
VA72C10's Avatar
yep, just bolt them to the rear and then crank the rear up and you're good to go! Don't worry...the bags won't sit evenly under the frame..they stick out more on one side...just make sure to pre-line up the holes before using the actual template to make sure they will all be under the frame.
Old 06-27-2010, 08:57 PM   #355
cstm68
cstm68's Avatar
today i got the rear bags hung and set the frame down to see how low it will be.
now i just need to wire wheel the frame and brush on some black frame paint, then the bed goes back on and its time for plumbing!
Old 06-28-2010, 03:32 AM   #356
67chevy1series
67chevy1series's Avatar
man sweet build i cant wait to see those steelies on your truck
67chevy1series is offline   Reply With Quote
Old 07-09-2010, 12:42 AM   #357
cstm68
cstm68's Avatar
today i got the switch box wires and all the vlaves wired, just need to ground the valves
also got the bed on and picked up some trailer fenders for front inners they are 33X13
Old 07-09-2010, 08:08 AM   #358
smbrouss70
smbrouss70's Avatar
Looking good. You're getting close now! Where did you get 13" fenders that are only 33" long?
Steven
"If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers
R.I.P. Oscar
R.I.P. Ratchet
1967 Pontiac GTO - Dad was the Original Owner
1970 Chevy 2wd SWB "Oscar's Truck"
1970 Chevy 2wd Blazer "Ratchet's Blazer"
2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar"
2017 Chevy Suburban "BDB"
2020 Chevy Blazer Premier "Foxy"
Shop Build
smbrouss70 is offline   Reply With Quote
Old 07-09-2010, 09:59 AM   #359
72SWBChevy
72SWBChevy's Avatar
WOW, You have really made some progress! Looks great!!!
1977 Camaro 468 BBC - SOLD -
1972 Chevy SWB....in the works!!
2006 Crew Cab Dmax/Allison Summit White-SOLD-
2009 Toyota Tacoma V6 Pre Runner - daily driver -
my build thread -http://67-72chevytrucks.com/vboard/s...95#post4774595
72SWBChevy is offline   Reply With Quote
Old 07-09-2010, 11:41 AM   #360
nuke1
nuke1's Avatar
truck looks great, glad to see it coming along this good!!!! keep it up or should I say lay it down low now.
James
1968 GMC "HAVOC"
1986 GMC "Frank"
J.J.R.H. Design & Consulting
My 68`Rebuild "HAVOC": http://67-72chevytrucks.com/vboard/s...d.php?t=316300
A 58' chev build thread: http://www.67-72chevytrucks.com/vboa...d.php?t=311238
1969 Camaro Pro Touring http://67-72chevytrucks.com/vboard/s...61#post3513361
Swiss Cheese: http://67-72chevytrucks.com/vboard/s...d.php?t=384390
Adjustable Trailing Arm How-To: http://67-72chevytrucks.com/vboard/s...d.php?t=321100
1968 Ford Farm Truck: http://67-72chevytrucks.com/vboard/s...=1#post6555587
nuke1 is offline   Reply With Quote
Old 07-09-2010, 12:20 PM   #361
1LoC10
Insert Title Here
1LoC10's Avatar
Coming along great.... awesome job
BOBBY
_69 SWB_
1000 pics of 67-72's>> http://s193.photobucket.com/albums/z...-72/?start=all <<
1LoC10 is offline   Reply With Quote
Old 07-09-2010, 01:29 PM   #362
ATT
ATT's Avatar
Looking good! I would like to see alot of pictures when you put the trailer fenders in.
ATT is offline   Reply With Quote
Old 07-09-2010, 02:39 PM   #363
b&a72
Active Member
b&a72's Avatar
Good build! And great job!
b&a72 is offline   Reply With Quote
Old 07-09-2010, 02:43 PM   #364
67cheby
67cheby
67cheby's Avatar
i like that shot down the side of the bed.... man i cant wait to get paint on mine!!
67cheby is offline   Reply With Quote
Old 07-10-2010, 10:19 PM   #365
cstm68
cstm68's Avatar
oops. typo. they are 33x11 sorry about that, but i got them from a local trailer supply store
Old 07-11-2010, 08:51 PM   #366
cstm68
cstm68's Avatar
one step forward and a big leap back...
soo i got all the valves and campressors wired and working great today. but now the truck wont turn over, everything eles works great radio, guages, lights, e-fan, dash lights etc. but when i go to start it... nothen
Old 07-11-2010, 09:08 PM   #367
VA72C10
VA72C10
VA72C10's Avatar
is it clicking at all? Maybe just not enough juice to turn it over since you were playing with the compressors? THey take a lot of juice....or did you mess with any ground wires and maybe leave one off? Also check the connection at the battery...mine would let the lights work but not turn over when it was loose at the terminal....tightened it down and it started right up...
Old 07-12-2010, 01:14 AM   #368
cstm68
cstm68's Avatar
no clicking, everything i working normal just nothing at the starter, the starter is new and so is the ignition switch
Old 07-12-2010, 08:40 AM   #369
hgs_notes
GEARHEAD
hgs_notes's Avatar
Check the neutral safety switch. If it's not adjusted right or unplugged, it won't turn over. I had this happen.
hgs_notes is offline   Reply With Quote
Old 07-13-2010, 09:07 PM   #370
cstm68
cstm68's Avatar
ok i got it started... hgs_notes was right. i had my security switch wired into the neutral saftey switch and one of the wires had come disconected out of the back of that.
so today i got all the bags plumbed to the tank. heres some pics ill get a video up once i get shocks in
Old 07-13-2010, 09:09 PM   #371
Newtz67
Newtz67's Avatar
Very nice, truck looks great!
Newtz67 is offline   Reply With Quote
Old 07-13-2010, 09:46 PM   #372
JesseH13
AMBITION
JesseH13's Avatar
looks good man!! real good
1979 Nova-daily-R.I.P
1976 c10 "daily"-
1968 c10 -project
CROOKED68 (PROJECT)
JesseH13 is offline   Reply With Quote
Old 07-13-2010, 10:03 PM   #373
mcbassin
Still Learning
mcbassin's Avatar
Very nice work! Truck looks great!
Old 07-13-2010, 10:16 PM   #374
hgs_notes
GEARHEAD
hgs_notes's Avatar
Cool, my previous misfortune was used to help someone else out. Truck looks great.
Old 07-13-2010, 10:44 PM   #375
b&a72
Active Member
b&a72's Avatar
looks good got any pictures of your tank mounting, trying to find a good place to mount mine.
