Old 07-14-2010, 10:47 PM   #1
camjck89
camjck89's Avatar
ign wire on skip white
Hello Me and a friend did some work on my 72 and i got a skip white dizzy and i took off the cap and disconnected the wire from the coil and pulled the stock points, got the s.w. dizzy in and went to run the ing wire to my interior fuse box. but honestly i dont know where the ing wire is to be connected on the dizzy the instructions said that the stock hei plugs into the pigtail on the dizzy( i maybe misunderstanding this) so my question is where is the ing wire plug into the dizzy cause there is 2 spades under the batt. portion of the super coil, can anyone clarify??
camjck89 is offline   Reply With Quote
Old 07-14-2010, 11:03 PM   #2
my67chevytruck
Under Construction
my67chevytruck's Avatar
Re: ign wire on skip white
should be the one on the right, the left is for TACH. if you have the solid red SW dizzy, it should have tach, and batt on the top of the coil pack, let me know if you need pics.
Heath
subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php
http://67-72chevytrucks.com/vboard/s...d.php?t=157669
FAQ how to's
1956 Chevy Apache
1967 C10 SWB FleetSide (under construction)
1969 K10 SWB FleetSide (Future Build)
1972 C10 SWB Stepside (Future Build)
56 chevy truck :
http://www.cardomain.com/ride/2955823/1
67 truck build:
http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1
69 k10:
http://67-72chevytrucks.com/vboard/s...d.php?t=389470
my67chevytruck is offline   Reply With Quote
Old 07-14-2010, 11:09 PM   #3
camjck89
camjck89's Avatar
yea i have the red SW dizzy so the pigtail on the distributor plugs into the coil and the ing wire uses a female connector to the right side of the "other space for connectors" if this is right im doin doughnuts in my truck tomorrow. sry for the ignorance wiring is my downfall
Old 07-14-2010, 11:10 PM   #4
Jwill41
Jwill41's Avatar
I have another SW dizzy question. It says it has an adjustable spark advance but no mention of how to adjust it. Ayone know? Sorry for the highjack but kinda related to your problem.
http://www.picturetrail.com/jwill41
67 1/2 ton GMC short step side
68 1/2 ton Chevy long fleet side
72 1/2 ton Chevy Suburban
99 1/2 ton Chevy Suburban
founder (and only member) of the primer/clearcoat club
Jwill41 is offline   Reply With Quote
Old 07-14-2010, 11:19 PM   #5
my67chevytruck
Under Construction
yes, the black plug plugs into the coil (closest to the dizzy) the two front spades are Tach (left side) BATT (12v keyed power source)
Heath
FAQ how to's
1956 Chevy Apache
56 chevy truck :
67 truck build:
69 k10:
Old 07-14-2010, 11:20 PM   #6
camjck89
camjck89's Avatar
for the sake of knowledge i would like to know, however it probably uses the allen wrench that was included
Old 07-14-2010, 11:32 PM   #7
my67chevytruck
Under Construction
They are referring to you being able to change the weights/springs to adjust timing advance etc. see pic below. The allen wrench is for the oil gear on the end of the dizzy, if i remember correctly that has an allen screw holding the gear on....
Heath
FAQ how to's
1956 Chevy Apache
56 chevy truck :
67 truck build:
69 k10:
Old 07-15-2010, 12:02 AM   #8
ERASER5
ERASER5's Avatar
The vacuum canister is adjustable with that allen wrench. Take the vac hose off, insert the allen wrench into the metal tube hole. Wiggle it around until the wrench seats. Turn left or right to adjust the maximum vacuum advance.
You will have to play with it, check, play with it, check.
Note: Pulling the vac hose off while vacuum is applied is a good way to pop the rubber diaphragm inside the canister.
'70 GMC C1500 LWB
Power disc brakes. WooHoo!
Posi 6 Lug Dana 60
ERASER5 is offline   Reply With Quote
Old 07-15-2010, 08:09 AM   #9
Jwill41
Jwill41's Avatar
thanks, mine didn't come with allen wrench or instructions. I am sure I have a wrench though.
