Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1967 - 1972 Chevy/GMC Suburbans & Panels Message Board > 1967 - 1972 Chevy/GMC Suburbans and PanelsProjects and Builds
Old 07-15-2010, 06:23 PM   #926
CheyenneShop
CheyenneShop's Avatar
Re: 1969 SuperBurb build-up (Bagged and Blown!)
Rob - LOVE the gauges, especially the 180 MPH. Your progress, and workmanship are spectacular!!!
72 Cheyenne shorty "CheyLow"
72 3/4 long 4X4
69 SWB "Prospector"
68 C/10 shorty - "Picacho" http://67-72chevytrucks.com/vboard/s...d.php?t=428379 sold to "93redsled"
Have you heard about C10 Talk? C10 Talk is a podcast all about C10 Trucks, the builders, the vendors, and most importantly the C10 Community. Check us out online at www.c10talk.com
CheyenneShop is offline   Reply With Quote
Old 07-15-2010, 06:29 PM   #927
67cheby
67cheby
67cheby's Avatar
by the way , i thought you had the trim on ??
67cheby is offline   Reply With Quote
Old 07-15-2010, 06:48 PM   #928
project 67 sub
project 67 sub's Avatar
160mph
project 67 sub is offline   Reply With Quote
Old 07-15-2010, 06:53 PM   #929
mcbassin
Still Learning
mcbassin's Avatar
Those gauges look awesome! I know that you had that done a few years back, but you have a ballpark cost on just the gauges? Looks like a bunch of $$$.
+1 on the Mar-K stuff. I have used their stuff in the past with good results.
Old 07-15-2010, 08:15 PM   #930
Hart_Rod
Hart_Rod's Avatar
Originally Posted by 67cheby View Post
i have never been a big fan of these but in your application and with your taste i bet it would look great.... i cant think of another place to add guages that would look good
I think that will be the easiest way to add the gauges since everything else is already painted.
Originally Posted by gcburdic View Post
Hart....I think they are okay....but it's so unlike you to use the usual and not have something else custom
If everything wasn't painted........
Thanks! How's the blazer coming?
I just had it taped on to check the fit. I won't put the trim on until all of the body panels are on and aligned.
Originally Posted by project 67 sub View Post
160mph
I got the gauges from Summit. I think the total was around $550-$600. Here's some more pictures of the front brake lines going to the master cylinder, the Flaming River tilt column, the CPP steering shaft setup and my custom made glove box emblem, .
Hart_Rod is offline   Reply With Quote
Old 07-15-2010, 08:56 PM   #931
Frizzle Fry
Frizzle Fry's Avatar
Holy...! That emblem is insane!
Frizzle Fry is offline   Reply With Quote
Old 07-15-2010, 09:17 PM   #932
chevydog66
GM ONLY BABY!!!
chevydog66's Avatar
Rob, I have a few questions. Hope you can share some of your wisdom.
You are using the ECE motor mounts correct? I am starting to install a LS2 in my 72 GMC truck. I also have the ECE mounts. What headers would you recommend, the Thorleys? I will be using a 200 4R trans, which is still in the truck. My LS2 is like a 01 or 02, and I would like to use the mechanical fan that's on it. I wonder if I can use it with the stock radiator? Why did you go electric, radiator to fan spacing?
2 wrongs don't make a right, but 3 lefts do.
66 Chevelle Malibu 406ci, 573hp, 10.99@121mph
96 Chevy Silverado Z71
72 GMC 1500 Super Custom LS 6.0/4L65 on airride
http://www.cardomain.com/ride/707879...mc-c-k-pick-up
chevydog66 is offline   Reply With Quote
Old 07-15-2010, 09:29 PM   #933
Hart_Rod
Hart_Rod's Avatar
It was hand carved......
I really like the Thorleys. If you look at my 67 Crewcab thread you can see where I used the mechanical fan with the 5.3 it put in it. You can use the factory radiator, but you'll have to figure out the hoses to make it work. Several people have done it on t his board. Here's a good thread to check out:
http://67-72chevytrucks.com/vboard/s...d.php?t=377348
Old 07-15-2010, 10:03 PM   #934
chevydog66
GM ONLY BABY!!!
chevydog66's Avatar
Thanks Rob, ya I just found that LS swap subforum. Keep up the good work!! We all want to see the finished 'Burb. Maybe at a board meet someday.
Old 07-15-2010, 10:41 PM   #935
Hart_Rod
Hart_Rod's Avatar
Any time. Let me know if you have any more questions. Got one more thing done. Here's some pictures of the LOKAR shift linkage hooked up to the tilt.
R/
Old 07-16-2010, 12:36 AM   #936
Ricks' 72C10
Going Down?
Ricks' 72C10's Avatar
Rob,
Where did you get the temp sender bushing?
All looks good
Just another day in Paradise
Rebuild thread
http://67-72chevytrucks.com/vboard/s...d.php?t=354512
Ricks' 72C10 is offline   Reply With Quote
Old 07-16-2010, 12:45 AM   #937
mcbassin
Still Learning
mcbassin's Avatar
thanks for the info on the gauges. I was thinking it would cost more than that.
[/url]
Wow! that took some serious time! Just curious what material did you use to make that from?
Have I mentioned this burb is way over the top.
Old 07-16-2010, 01:04 AM   #938
VA72C10
VA72C10
VA72C10's Avatar
Awesome as usual but that glovebox emblem.....WOW.....just.......WOW!
Old 07-16-2010, 03:49 AM   #939
Jvsapp
Jvsapp's Avatar
Here's some pictures of the glass and a couple of pictures of my solution to putting the temperature sender in the passengers side head. It's a 1/8 npt to 12mm 1.5 bushing. It beats drilling and retapping the head and it's not as bulky as the adapters most people use.
i like that. where did you get the sending unit? will it work with stock GM gauges? i like to tap mine into the plug on the intake by the water neck. i seen it on a factory impala so i stole that idea.
Jvsapp is offline   Reply With Quote
Old 07-16-2010, 05:48 AM   #940
Hart_Rod
Hart_Rod's Avatar
Originally Posted by Ricks' 72C10 View Post
Rob,
All looks good
I ordered them from Dakota Digital. They were $2 each + shipping.
That didn't include the cost of the bezel or having it assembled, just the gauges. I didn't make the emblem, I had a boardmember MrGoodplierss make it for me.
Thanks. The sending unit came with the gauges and the bushing came from Dakota Digital. I'm not sure if it will work with the stock gauges.
Old 07-16-2010, 08:53 AM   #941
hgs_notes
GEARHEAD
hgs_notes's Avatar
I know I need a boost gauge, but I have two other holes to fill, any suggestions?
Tranny temp, vacuum?
hgs_notes is offline   Reply With Quote
Old 07-16-2010, 09:39 AM   #942
mcbassin
Still Learning
mcbassin's Avatar
Cool! I like the way you are spreading the love on this project all over the board. Let me know if I can make something for you too
Old 07-16-2010, 02:38 PM   #943
CheyenneShop
Blazer(s) are doing about as good as your's!!!!
That hand engraved emblem is out of this world sick!
Ronnie
72 3/4 long 4X4
69 SWB "Prospector"
Old 07-17-2010, 06:03 AM   #944
Hart_Rod
Hart_Rod's Avatar
One gauge will be a dual boost/vac. I've already got tranny temp. I was thinking wideband and oil temp?
I'm open for ideas, .
Ronnie
Thanks Ronnie. I'm looking forward to seeing your build thread.
R/
Old 07-17-2010, 08:24 AM   #945
lolife99
67-72 parts collector,…
lolife99's Avatar
How about some billet Coys centercaps?
Keith
Convert to disc brakes.
Old 07-17-2010, 02:13 PM   #946
mcbassin
Still Learning
mcbassin's Avatar
I'm your huckleberry
Old 07-17-2010, 03:54 PM   #947
Hart_Rod
Hart_Rod's Avatar
Some caps with SB on them would be SUPER COOL!!!
Old 07-18-2010, 04:11 PM   #948
Hart_Rod
Hart_Rod's Avatar
Here are a few pictures of the modification I did to my "drive by wire" gas pedal that allowed me to install a stock 72 CST pedal in it's place. I also got all the steering linkage cut and connected.
Old 07-18-2010, 10:26 PM   #949
Hart_Rod
Hart_Rod's Avatar
Here are some pictures of what the inside of a "NEW" engine looks like when I pulled the valve cover, . I'm thinking about painting the valve covers, but I can't decide between red or black???? Also, any suggestions to where to install a oil temperature sender for a 4L60E? TIA.
R/
Old 07-18-2010, 10:28 PM   #950
VA72C10
VA72C10
VA72C10's Avatar
Man, you know how to test a man's willpower from coveting.
