Old 07-16-2010, 01:46 PM   #1
70stroker
70stroker's Avatar
88 blazer tbi problem
i got a 88 gmc 350 tbi i just bought. it used to be a buddys, When you started it it would run for a few seconds and die. if you held the throttle down it would run and act as if it were loading up. He put a fuel pressure regulator on, fuel filter and plugs. Now it will start for about 2 seconds and dies, after those few seconds its not gettin fuel to the tbi unit.
to me it sounds like a fuel pump. anyone got any ideas?
70stroker is offline   Reply With Quote
Old 07-16-2010, 02:05 PM   #2
Walts_restoration
Real Projects never die
Walts_restoration's Avatar
Re: 88 blazer tbi problem
sisters 91 rs started doing this as well, but new fuel pump (2 years less than 10k miles). Started every time till we let it sit for a couple months after she got T boned, then needed to move it to get the trailer out, and wouldnt fire, primed it and she ran, but then died out.
Ill put it this way, ive got a few lawn ornaments
My name tag says Ryan
KansasTwister On other forums
Walts_restoration is offline   Reply With Quote
Old 07-16-2010, 08:48 PM   #3
rfmaster
rfmaster's Avatar
More than likely in tank fuel pump has captured output hose. If its has original fuel pump it is probably tired as well. The easiest way to verify this is to perform fuel pressure check. Fuel pressure check involves installing gauge and forcing fuel pump to operate continuously by applying +12 Volt to the FP relay test connector (red wire with single 1/4" sply). Stock TBI needs 13 PSI for normal operation - you probably have around 1-3 PSI.
//RF
"The Beast"
1975 Chevrolet C20 longbed
350/700R4! with 3inch body lift
Dual Flowmasters Super 40's!
TBI retrofit completed (2007-07-29)
New 383CID (+030) 08-304-8 9.5:1CR x36,005 (2012-12-17)
rfmaster is offline   Reply With Quote
Old 07-18-2010, 01:58 PM   #4
1987GmcSierra
1987GmcSierra's Avatar
#1 SIGN A FUEL PUMP IS GETTING WEAK FUEL SMELL ON THE PASSENGER SIDE THRU THE FENDER U CAN SMELL IT WHEN U OPEN THE PASSENGER DOOR
Yeah Sounds like the fuel pump i have had 1 of my 87 trucks die out in the drive way and then not have a problem for a week than i parked it and it wouldnt crank lol i have 3 tbi trucks the fuel pressure is suppose to be 13-15 psi ideally 14 constant would be great but they go up and down the psi isnt constant u can put a FP reg and put it all the way to 15 but no more or u will have more problems
CANT RESCUE ALL OF THEM BUT I CAN SURE TRY
1987 Gmc Sierra swb 2wd (soon to have a TBI 454)
1987 Custom Deluxe 2wd (Was a TBI 4.3 V6 Now TBI 5.7 350) DAILY DRIVER
1985 MILITARY CUCV M1008 Pretty much Stock
1987 3/4 ton GMC 2wd Suburban TBI 7.4 454(DONOR FOR 87 GMC SWB) BEING USED AS PARTS
1989 GMC SUBURBAN TBI 5.7 350 (MOTOR IS NOW IN 87 CUSTOM DELUXE)BEING USED FOR PARTS
Gets More Chicks =GMC Got More Cubes=GMC
Got My Chevy=GMC God Made Chevy=GMC
1987GmcSierra is offline   Reply With Quote
