Old 05-30-2003, 01:42 AM   #1
HotRod929
HotRod929's Avatar
Location: Bondurant, IA but in Worcester, MA for school
Brake Shoe Adjuster???
Is the adjuster on for the brake shoes for a 70 C20 an automatic adjuster? Latly I have noticed that my brake pedal bottoms out every once in a while. I have blead the brakes and there is no air in system. Do I just need to adjust the adjuster or do I need to put new brake shoes in? Thanks
HotRod
1970 Chevy C-20
350 V-8
Turbo 350 w/ shift kit
Dana 60 w/ 4.10 gears AND Powr-Loc POSI
New Additions:
Summit Headers
135amp alternator
Proform HEI
Edelbrock 1406 600cfm carb
Sunpro Tach
Powr-Loc POSI
Edelbrock Performer RPM Intake
MSD 6A Ignition Box
AIM: HotRod929
Visit My Site: http://1970chevy.netfirms.com/
HotRod929 is offline   Reply With Quote
Old 05-30-2003, 03:41 AM   #2
Southpa
Southpa's Avatar
It doesn't hurt to jack the truck up, pull the wheels and have a looksee every now and then. If you haven't done that for a long time then you might have some surprizes. If there is no meat left on the shoes or if the shoes are worn unevenly to the extreme then its time for new ones. Check your drums as well for uneven wear. The ratchet pawl (little toothed wheel) at the bottom of the brake assembly is the manual/auto adjustment. Backing up and slamming on the brakes should set the brakes. Sometimes the auto-adjust feature doesn't work well and lubricating the ratchet assembly with Never-Seize (graphite) helps. I usually do it manually by tightening the little wheel until I get only one revolution out of the big wheel, .
I just did my front brakes today (discs). The wear indicators were making noise the last few days so I figured I better do something before my rotors got scored. Baby's got a new pair of shoes and the rotors don't need turning. Preventative medicine. Too many people don't pay attention and later end up paying big money.
1970 GMC 1500 Custom
Original 350/TH350
Victoria, BC, Canada
You can wish in one hand and crap in the other.
See which one gets filled first.
Southpa is offline   Reply With Quote
