Old 05-30-2003, 05:48 AM   #1
68 Suburban
68 Suburban's Avatar
A/C Question.
I am finishing up installing an aftermarket A/C system in the burb. The A/C shop wants $32 to evacuate and $12 a pound for the R-134.
This seems reasonable, but I have some R-134 lying around. Will I cause any problems if I put about 2 lbs in my system before I take it over to be evacuated? Then they can top it off. I just dont feel like spending $36 for freon I all ready have.
Just sitting here contemplating contemplation.
68 Suburban is offline   Reply With Quote
Old 05-30-2003, 06:32 AM   #2
firstgencamaros
When they evac the system they will pull everything out of the system. So, you'll just be wasting your freon. They might be willing to use your freon if your paying them to do everything else. If they wont work with you, let me know, I know a shop here in Mesa that would probably work with you.
Later,
FGC
FGC
firstgencamaros is offline   Reply With Quote
Old 05-30-2003, 07:35 AM   #3
Andy4639
Old member
Andy4639's Avatar
Cool A/C
Once you get the truck driving take it to the shop and let them pull vacuum on it check for leaks and drive it home and filler up with R-134 A.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 05-30-2003, 08:28 AM   #4
68 Suburban
Re: A/C
Is that the same as evacuating the system?
Old 05-30-2003, 08:43 AM   #5
ddsmith
Glowing since 1978
ddsmith's Avatar
They pull it into a deep vacuum. Basically removing everything that will boil at very low vacuum.(freon, moisture) As long as no leaks exist in your system this will work. I will caution you to ensure that the lines you connect for charging at home are purge with a small flow of freon to the environment just prior to hooking to the connection on the truck. This will blow out any air/moisture sitting in the lines and then all you'll be charging is freon. That first can of freon charges real fast because you are essentially breaking the vacuum in the system with the first can. Good luck.
66 Chevy C30 Stakebody Dump, PS,PB, 327cu in
71 Corvette Coupe 454 4 speed
69 Chevy C20 Custom Camper
ddsmith is offline   Reply With Quote
Old 05-30-2003, 11:24 AM   #6
Yellow Cheyenne
Systems using R134 are much more sensitive to needing the correct amount of freon to work correctly. Too much or too little and it won't cool right. For some reason, the sight glass method doesn't work for 134. May want to see if they would use yours. If not, just keep it to top off the system in the future when a little leaks off.
'72 Cheyenne. AC, PS, PB, Rear slider window, tilt. Light yellow (grapefruit yellow according to new sales literature from '72)
'56 Chevy short step V-8 (My dad bought it new!!)
'70 Olds 442 convertible
'70 Olds Rallye 350
Yellow Cheyenne is offline   Reply With Quote
