Old 07-18-2010, 12:04 PM   #1
project67-stepside
project67-stepside's Avatar
shock help plz
my 67 is bagged and notched, not sure how to do the shocks, and what shocks to use? little help guys
it usual better and faster if u figure it out yourself!!!!
project67-stepside is offline   Reply With Quote
Old 07-18-2010, 12:54 PM   #2
kev2809
low n' slo
kev2809's Avatar
Re: shock help plz
pics? i ran the stock part number shocks on mine, got them from oreilly. just welded new shock tabs on the axle and bridge bar of my notch.
67 1/2 ton Suburban - Project DRGNWGN. Build thread
-_--_--_ _________
_--_-_ -/____|__|__\__
,.,,,.,.,,.,|_O _______ O_]
kev2809 is offline   Reply With Quote
Old 07-19-2010, 04:16 PM   #3
charx2
charx2's Avatar
Re: shock help plz
I am in the same spot. I found the relocator kits, I'm just worrying about blowing out the shocks due to to much compression/extention.
My 67 c10 Thread.
http://67-72chevytrucks.com/vboard/s...d.php?t=409192
charx2 is offline   Reply With Quote
Old 07-19-2010, 04:25 PM   #4
michael bustamante
michael bustamante's Avatar
Re: shock help plz
are you talking front or rear shocks, if the front what control arms /spindles did you use?
The rears is easy, just take you shock perches under the u bolts and flip and reverse them (once you flatten the lip) and get some upper relocators, or you can do a search on here and theres a thread that shows how to modify and use your factory upper shock mounts in the rear.
1967custom
michael bustamante is offline   Reply With Quote
