07-19-2010, 01:57 PM | #701 | |||
Re: My Crew Cab Short Bed Project, AKA "Project Destiny"
I told him about the site, there is a sticker on the back window too I like how low it is, but the frame is sitting on the axle, it would take lots of work
CHEVY ONLY |
07-19-2010, 02:12 PM | #702 |
Repost:
Where is your compressor from? Did you replace an older working model? If you did replace an older one, what kind of difference have you noticed? The A/C in my 78 Silverado was updated to the new Freon type, but the compressor is original. The air is very cold, but the compressor bogs down my engine every few seconds. It feels like an 80 mph gust of wind slams into the front of my truck, slows down, and then goes away... I would really like to know if a new compressor would fix this... Thanks!
78 Silverado 1/2 Ton LWB (restore) 78 Silverado 3/4 Ton LWB (parts truck & practice - eventually a work horse) My Build thread: http://67-72chevytrucks.com/vboard/s....php?p=4082128 Ellis Benus - Web Design Columbia Mo & Google Fan Boy! |
07-19-2010, 02:21 PM | #703 |
Do they make a bolt in notch for the c10 or only weld in? I figure a mild notch, and helper bags and your money for the back. I could see the front being a bit of a pain. Does your crew have a two piece driveshaft?
My AD Truck Build Thread 52 GMC one day laying on the running boards 2004 Chevy Crewcab. 3/5 and notched |
07-19-2010, 02:50 PM | #704 | |||
In the early '80's GM changed to this style of compressor. Sorry I don't have any experience with the older compressors Quote:
I have thought about some helper bags too. And yes it is a 2 piece shaft
CHEVY ONLY |
07-19-2010, 02:53 PM | #705 | |
No problem. You are getting a lot of them. :-) But with this style you do not experience the "bog down" I'm referring to? My uncle and I plan to eventually pull a late-80's fuel injection engine with an overdrive tranny which would allow me to use this newer compressor. Or, it might just be better to go the Vintage Air route.
07-19-2010, 02:57 PM | #706 |
Still Learning
I have twenty acres and about 6 projects......go figure
07-19-2010, 03:01 PM | #707 | |
Still Learning
07-19-2010, 04:05 PM | #708 |
07-21-2010, 12:49 AM | #709 |
Still Learning
Update? How is the new compressor working for you?
You need to tweak your sig.....didn't you sell the 80? |
07-21-2010, 07:29 AM | #710 |
I haven't driven it since I replaced the compressor, this rear end swap is a bit more involved than I anticipated. Gotta swap out the springs and get my drive shaft shortened.
Thanks for the reminder, I'll fix my sig right now
CHEVY ONLY |
07-21-2010, 08:34 AM | #711 |
Still Learning
Whoa! I thought it was just a matter of changing some shock mounts and u-bolt hangers? That kinda sucks I was thinking about installing a later rear end with posi. Makes me wonder now. Be sure to document what you are doing just in case
07-21-2010, 08:44 AM | #712 | |
I'll take some pics tonight
CHEVY ONLY |
07-21-2010, 08:52 AM | #713 |
Getting Old; Going Broke
Were you planning on driving Destiny over here this weekend? Just wondering
Amazing how something you thought would be simple, ends up being a lot more. Is gonna be worth it though, well worth it. Looking slick! |
07-21-2010, 09:02 AM | #714 | |
That is the plan. I'm trying to work on it after work so I'll have it done to head up there Saturday. I can't wait to drive it with the 3.73's Oh and having a good buddy that works at a driveline shop is SWEET!
CHEVY ONLY |
07-21-2010, 09:47 AM | #715 |
You can't have enough good friends when it comes to having older autos.
My body man has an engine builder buddy, been using him for all sorts of information on my truck lately. Just wish he were closer, not really worth it to load up and drive almost to Tahlequah for this small stuff. Could have had my intake machined, but the air drill worked fine. |
07-21-2010, 10:02 AM | #716 |
That is a true statement!
Sweet, I'll be waiting for new pics in your thread
CHEVY ONLY |
07-22-2010, 07:35 PM | #717 |
One day...
What about picks in your thread??
07-22-2010, 07:37 PM | #718 |
Scott just took it there lol.
07-22-2010, 07:37 PM | #719 |
Yeah! I put up pictures today. You did not stipulate pictures of what....
Why is every used 350 sbc out of a corvette? There's only two things that excite a man, expensive toys and real expensive toys. VEGETARIAN: That's an old Indian word meaning "I don't hunt so good." When the going gets tough, switch to power tools. |
07-22-2010, 08:23 PM | #720 |
I wish I had some progress pix, since I don't I will harass everyone else too.
What's up joe been quiet lately. |
07-22-2010, 09:19 PM | #721 |
I bet he is out in the driveway putting on new U bolts. Just my guess. Or... he is out with a smile from ear to ear cruising with his new third member already all bolted in.
07-23-2010, 12:51 AM | #722 |
Man, I wish
I got it all put back together and guess what? I only have about an inch and a half between the axle tubes and frame. Drove it around the block and it bottoms hard on small bumps. I'm about out of ideas. I guess flipping the axle was a bad idea. I could notch the frame, but I would need to bring the front down 4-5 inches. That's too much to do with springs IMO. I'm also thinking about modifying my rear hangers to flip the shackle over. But that would most definitely jack up my pinion angle. I might just un-flip the axle, hope my shortened drive-shaft will still work... What the hell was I thinking? Scott, feel free to give me an "I told you so"
CHEVY ONLY Last edited by joe231; 07-23-2010 at 12:53 AM. |
07-23-2010, 07:28 AM | #723 |
Doh.
07-23-2010, 08:01 AM | #724 |
One day...
dang man, i was afraid of that when we were looking at it. Try and un flip it and if the drive shaft dont work ill look for one and we can make you one and keep that one for later.
Buy some drop spindles and have the rush shipped and we will put some C notches in it this weekend Last edited by scotts62; 07-23-2010 at 08:01 AM. |
07-23-2010, 08:14 AM | #725 |
It has 3" drop spindles on it already. Think I'll stop by the trailer place on the way home and see if they have any perches. Randy, Sorry, it doesn't look like I'll be able to make it this weekend
CHEVY ONLY |
