Closed Thread
Old 07-20-2010, 10:49 AM   #1626
jgh64pkup
Sunburst C10!!!
jgh64pkup's Avatar
Re: What did you do to your truck today?
Originally Posted by ravens65 View Post
Good thing you had some fire extinguishers, better be carefull or you'll set yourself a couple years behind!!!!!! you need to get rid of all rubber fuel lines!!! 50- or 100 bucks is a good investment.
i have stainless from the rear axle to the motor mounts
then i have rubber connecting the fuel cell and carb
Gage
1967 C10 Shortbed Stepside
jgh64pkup is offline
Old 07-20-2010, 12:15 PM   #1627
DPowers
One foot in front of the other
DPowers's Avatar
Had an appointment for new windshield. The guy gets there and says- "we have the wrong rubber"
Gonna take a couple days to get the new one in- sucks cause I wanted to get it to the alignment and muffler shop this week
DPowers is offline
Old 07-20-2010, 10:05 PM   #1628
Bugeyev8
Bugeyev8's Avatar
got the pass door stripped and did the metal work, got the filler on and shot it with some epoxy in and out, a whole day of final blocking and this will be in the done pile too !
Bugeyev8 is offline
Old 07-21-2010, 01:44 AM   #1629
fryer1979
Redneck Hillbilly
fryer1979's Avatar
Finally got to see her again! It has been a few weeks since I was last at my shop, so I drove out there today and paid her a visit. Didn't have anytime to spend with her, but I have been collecting a few essential power tools I have been years without. Now I think I have what I am going to need to get the parts truck disassembled and ready for the scrap yard. Should be some more progress coming soon...
fryer1979 is offline
Old 07-21-2010, 12:22 PM   #1630
onequickchevy
onequickchevy's Avatar
Jealous of your doors bugeye, mine need a visit from the patch man. All in good time.
Slowly but surely getting it done.
onequickchevy is offline
Old 07-21-2010, 02:33 PM   #1631
Bugeyev8
Bugeyev8's Avatar
Thanks man !
I started looking for doors, fenders and hood in 1997, just got these last year..even out here in Ca these things are rare, and these are far from perfect, they had some pin holes here and there along the bottom, I used Por15 and filled them, I scored these from the most rusty truck I ever saw, go figure...another member here has the cab and is using it for a crew cab build
Bugeyev8 is offline
Old 07-21-2010, 07:46 PM   #1632
Andice
Andice's Avatar
Picked up most of the painted bed panels this afternoon.
Andice is offline
Old 07-21-2010, 11:34 PM   #1633
onequickchevy
I have been looking for almost a year. Everything around here for doors is worse than what I have. Good thing the inner and outer lowers are available!
Old 07-22-2010, 07:44 PM   #1634
losthope
losthope's Avatar
today after work i busted out the battery grease gun at the shop and greased all the front end fittings,something i never thank of doing took five minutes!!!
losthope is offline
Old 07-22-2010, 10:52 PM   #1635
Sillyoldman
#16876
Sillyoldman's Avatar
I removed the bed end I messed up last weekend when I backed up and hooked it on my metal fence. I pounded on it for a while until I got bored with it. Nonhog & I swapped it over to HEI last weekend. I think I'll go out and broaden my plug gap from .035 to .045.
Posted via Stationary Device
'71 Custom Deluxe C-20 402.
'67 Buick Special 455.
'49 Plymouth Special Deluxe.
"I love that old car smell"
Some people are like Slinkies... not really good for anything, but they still bring a smile to your face when you push them down a flight of stairs.
Sillyoldman is offline
Old 07-23-2010, 10:07 AM   #1636
fredbarnes
fredbarnes's Avatar
i put a window regulator in my 65 c-10 daily driver, boy does the window work better.
fredbarnes is offline
Old 07-24-2010, 12:24 PM   #1637
Woogeroo
I finally got all of the rubber weather strip installed in the passenger side door today, so now both sides are finally done.
bleh.
However, the vent window does not want to seat just right at the top, so I have to fudge with it to make it close.
I'm not sure what the deal is there yet, I'll have to keep messing with it I guess.
-W
Woogeroo is offline
Old 07-24-2010, 05:22 PM   #1638
Fursphere
Cleaned about two tons of pine needles from underneath the panel body - prepping for reassembly.
1966 C10 Panel (3/4 Ton 4x4 Conversion)
2001 K1500 Silverado
Fursphere is offline
Old 07-24-2010, 05:49 PM   #1639
SRVBLUES64
its too darn hot! here in Indy, but I did work a bit on my fender and the bed, Im looking at a 93 fuel injected engine trans combo for 450 delievered. I hope it will fit
SRVBLUES64 is offline
Old 07-25-2010, 12:10 AM   #1640
Captainfab
60-66 Nut
What engine is it? If it's a TBI 305 or 350 it will fit with no problems. Are you staying with the EFI?
Captainfab is offline
Old 07-25-2010, 12:15 AM   #1641
SRVBLUES64
I actually found a 78 350 carb motor that I may pick up its just untill I decide how I will build my real motor for the truck
Old 07-25-2010, 12:21 AM   #1642
SRVBLUES64
what would be the best way to clean a engine? I know that the outside is easy pressure wash with a good degreaser but what about pulling the pan off and having just a block what and how would you clean the inside. I bought a 350 plus a turbo 350 trans that ran but has been sitting in storage for about 6 months. Im going to change all the gaskets and add other goodies but I wnat to clean it inside and out before adding royal purple. This is just my hurry up motor so I can move the truck around
Old 07-25-2010, 12:55 AM   #1643
Bugeyev8
Bugeyev8's Avatar
I would just drain it and fill it, not worth the effort , if you insist on cleaning I have heard that 1 qt of atf in the oll for a few miles will clean the engine inside, they sell cleaners for the block but it is just kerosene...
Bugeyev8 is offline
Old 07-25-2010, 02:16 AM   #1644
Martin64
Martin64's Avatar
Sea Foam
Martin Gibson
USAF Retired
1964(-ish) C10
Martin64 is offline
Old 07-25-2010, 02:57 AM   #1645
Bugeyev8
Bugeyev8's Avatar
Man...it must be nice to be at that point in your truck rebuild, I just have a little more work and then I hope to be there too !
Bugeyev8 is offline
Old 07-25-2010, 03:00 AM   #1646
Bugeyev8
Bugeyev8's Avatar
when I am done with my doors I will have my old ones for grabs if you are interested, the pass one is just needing an outer and the drivers an inner and outer, they both have 6x 9 holes cut in them
Bugeyev8 is offline
Old 07-25-2010, 09:31 AM   #1647
ravens65
ravens65's Avatar
I got my doors from the turkey rod run in datona $600.00 , nicest set that I've ever seen. With the biggest price!
If it has tits or wheels its gonna give you problems!!!
ravens65 is offline
Old 07-25-2010, 09:43 AM   #1648
ravens65
ravens65's Avatar
spent 3 hours trying to load it on a trailer that was too narrow!
It died on me in the middle of the road, it was breaking up last week, then just died. no spark, trouble shooting is not my best area????
maybe coil, dist modg. who knows??? takin the parts to the auto parts store to have them checked. Oooooh damaged both front fenders and a door loading on the stupid trailer ( just paint) and the freind that helped pulled a leg muscle and is off work for two weeks! Sorry mark!!!
ravens65 is offline
Old 07-25-2010, 10:41 AM   #1649
ravens65
ravens65's Avatar
Just got back from the parts store and it is the dist. mod a 23 dollar part, I'm glad thats all it is but..... The real kick in the teeth is- I have to wait till payday to get it. so broke lately! been in the hospital 3 times this month for the strokes, at least they are telling me that they are caused from seisures, the problem with that is ... the state could take my lic. five years to build my truck and I might lose my licence, nice!!!! I feel like retard , cant hardly speak and get confused , when I have a episode. my mind still works just cant get it out. enough about my wining. I'm drivin it- period!!!!
ravens65 is offline
Old 07-25-2010, 05:32 PM   #1650
Andice
Andice's Avatar
I started bolting things together and painting (Por15) the bed wood and cross rails today. I found an excellent (just like original) seam caulking product at NAPA a few days ago. It comes in 12" lengths x 60 pieces for approx $20. I used some when I attached the steps to the fenders and I will use more when I attach the rear fenders, etc.
Andice is offline
Closed Thread
