07-21-2010, 03:34 PM | #76 |
Re: Project 91 Bsquared
This wire was taped off and I was missing vacuum hoses from the egr and the cruise was going to the ac vent and another hose was supposed to be coming from the back of the manifold but instead was T connected to the wipers.
07-21-2010, 03:51 PM | #77 |
6>8 Plugless........
That's always nice. Some people.
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
07-21-2010, 03:52 PM | #78 |
Getting Old; Going Broke
It started didn't it?
You want it fixed? Or you want it fixed right? To some people, there is no difference.
Why is every used 350 sbc out of a corvette? There's only two things that excite a man, expensive toys and real expensive toys. VEGETARIAN: That's an old Indian word meaning "I don't hunt so good." When the going gets tough, switch to power tools. |
07-21-2010, 09:49 PM | #79 |
I can't figure it out, I got it running and took it for a short test drive. Then got stranded. But after 30min of sitting on the side of the road it started up, so headed back home and tinkered with it for a little bit before taking it out for another quick test drive which resulted in 2 more shut downs. I'm not sure where to go from here.
07-22-2010, 12:07 AM | #80 |
There isn't another fusable link somewhere else farther up the wire is there?
07-23-2010, 05:25 PM | #81 |
Sounds like something like this might be your best bet. I know thats what I'm going to have to do on my K5 based on the hacking I've seen in it so far....
http://www.summitracing.com/search/P...s&autoview=SKU
Paul '78 GMC Serria 15 Heavy Half. 361/NV3500/3.73. Former LWB NV3500 swap Trailing arm swap '98 ECSB Z71 daily driver -traded '03 burb. Family cruiser http://upstategmtrucks.com/ |
07-26-2010, 04:35 PM | #82 |
any luck bro?
Fuzzy Dice Club Member 87 Crew SWB Build for the crew http://67-72chevytrucks.com/vboard/s...d.php?t=430082 http://www.cardomain.com/ride/3232925 90 burb 2wd Build Thread For The Burb! http://67-72chevytrucks.com/vboard/s...d.php?t=383055 |
07-26-2010, 04:54 PM | #83 |
No luck yet
07-26-2010, 05:00 PM | #84 |
man that sucks bro...
07-26-2010, 06:10 PM | #85 |
Have you pulled your Dizzy's cap and checked for cracks ? Sounds almost liek there could be moisture in there.
***My 84 short bed build up***** http://67-72chevytrucks.com/vboard/s...68#post3481968 |
07-26-2010, 07:37 PM | #86 |
My truck did that one time and it was the wires down by the starter that were in that metal tube heat shield thingy, but I think you said you already redid those wires
07-27-2010, 12:32 AM | #87 |
One day...
So when driving it just dies on you, right?
You check the wires at the starter? Have you replaced the ignition module? I have had one do that, when you drove it for a while it would die but you let it sit for a bit and off you would go, fuel pump going out would do it too.. |
07-27-2010, 08:32 AM | #88 |
Not much of an update:
I changed oil, fuel filter, spark plugs & wires, map sensor (code 33), spark control sensor (code 43), new starter and wiring, battery checked out good 12.4V, ignition control module (black piece under distributor cap) checked good although I've been told that when the engine warms up the ignition module or the coil (the shortest spark wire connect to in front of the distributor cap) with shut off and cause the engine to die while driving. Which is exactly what its doing, I can only get a few blocks away and the truck will die, then I have to wait about 10min before it will start back up and drive a few more blocks then die again. Another thing is that my truck has very little get up and go, I can only go about 50mph tops. Which could mean a clogged catalytic converter. I hope to be very productive this weekend changing parts and getting it running strong. |
07-28-2010, 12:04 PM | #89 |
My bet is on ignition module under the cap.............. In my experience coils are either good or bad most of the time.
2004 z71, 96 z71 on 38s, 88 Chevy k5 blazer, 4in lift. 84 swb project, 82 SWB project , 84 chevy 4x4 lwb project, 88 Jimmy beater/highschool ride. 79 c30. 99 tahoe 4x4 project. and a bunch of parts trucks.. |
07-28-2010, 04:36 PM | #90 |
One day...
Well is it up roasting tires yet??
07-28-2010, 04:43 PM | #91 |
had a fuel pump do that to me and a coil.
07-28-2010, 04:58 PM | #92 |
Still not fixed yet but I did just pass this awesome lady driver bahahahahahaha
07-29-2010, 01:16 PM | #93 |
she better hope the airbag doesn't go off. I bet it'll take her head off!
08-06-2010, 11:23 PM | #94 |
Pic of the burb
08-06-2010, 11:32 PM | #95 |
Nice pic!!
CHEVY ONLY |
08-08-2010, 11:30 AM | #96 |
Man! my big back passenger side window is cracked! Hope I can find one at the junk yard.
My theory is the landscapers mower flung a rock and hit my window Last edited by BGRAFX; 11-14-2010 at 05:31 PM. |
08-08-2010, 08:06 PM | #97 |
Dang-IT!!
CHEVY ONLY |
08-08-2010, 08:19 PM | #98 |
It followed me home?
oh yeah blame it on the landscapers ha ha, there are several here at the yard I go to if you need me to pull one out for you.
Adam That's why they call it a shortcut Kyle, if it was easy it would just be the way. 86 c-10 SWB 85 CCSB 90 GMC K30 Crew SRW 1985 C30 Dually |
08-08-2010, 08:46 PM | #99 |
Adam, you damn lawn boys! lol a first I blamed neighborhood kids throwing rocks, or a drive by bb gun incident. But then I thought about seeing the landscaper driving his mower through the parking lot and since I haven't been driving my truck it was a sitting duck for debris. I've talked to a couple local guys parting out suburbans but I will let you know how it goes.
The thing I most bummed about is that in the corner of all the windows on my burb the glass is etched with the vin# |
08-08-2010, 10:45 PM | #100 |
I think I have the true weatherstripping tool to install that locking strip on the window. Let me know if you want to try it out.
Edit: I went the 12th street yard and there is an spray painted black 88 Sub with tinted rear windows still in it. Last edited by blakeduren; 08-09-2010 at 04:02 PM. |
