07-21-2010, 04:56 PM | #1 |
VIN # Issue
Hello everyone, Ive been reading alot on the forums the last couple weeks and looking at the great pictures of all your trucks. I found a truck Id like to buy and I have been out to look it over. My problem is that I wrote down the VIN # off the drivers side door jam and Im having a hard time decoding it with the information I have found. The VIN was GM2590DZC2045B it is supposed to be a 1967 2wd swb chevrolet. Any help would be great. It also has the factory A/C on the bottom of the dash and power brakes.
07-21-2010, 05:04 PM | #2 |
Re: VIN # Issue
Scratch that, I posted a VIN decoder for you but your VIN does not match up. Not sure what you have there hopefully one of the other guys will.
1967 Stepper built and about to be rebuilt in Atlanta, GA Last edited by RustWrangler; 07-21-2010 at 05:14 PM. |
07-21-2010, 05:43 PM | #3 |
its all about the +6 inches
Re: VIN # Issue
can you get a photo of he VIN plate?
You sure it isn't a GMC? |
07-21-2010, 05:54 PM | #4 |
Active Member
Re: VIN # Issue
FYI, the factory only installed in dash air, under dash is dealer installed or a aftermarket company.
07-22-2010, 02:29 AM | #5 |
Re: VIN # Issue
Hello Wtatters and WELCOME to the board. I think you got a gmc vin there.
G= van/jimmy m=v6 2=3/4 ton 59- cab to rear axel dimension (actualy 54 inches) OD= wide side box Z= fremont assy. plant C= year 1967 2045=sequence number B=GVW range 6001# to 10000# If that first digit is a C instead of G then it's conv. cab 2wd.
CHEVY/GMC VIN DECODERS Last edited by bruceman1968; 07-22-2010 at 05:36 AM. |
07-22-2010, 08:25 AM | #6 |
Re: VIN # Issue
Thanks for the help everyone. Im going today to look at it again and Ill try to double check that VIN. here it is http://springfield.craigslist.org/cto/1849345671.html if anyone was interested.
07-22-2010, 08:46 AM | #7 |
Re: VIN # Issue
Compare that $10K to what you can get at a used car lot. I would have guessed it to be more expensive.
72 Fleet (died) 78 Step (sold) 55 Step named Fred (sold) 00 F150 68 Step (named El Scorcho by PO) Build thread for the new El Scorcho http://67-72chevytrucks.com/vboard/s...d.php?t=392932 |
07-22-2010, 08:55 AM | #8 |
Re: VIN # Issue
Doesnt look bad, small backglass wasnt rare,most all early 67 were small rear windows. Looks like it's missing carpet or matt in the floor, I would do some jewing down on him if your comfortable doing so!
Oyea welcome to the truck forum, hope you enjoy it, we do........... Donnie
Things happen for a reason! |
07-22-2010, 09:48 AM | #9 |
What?
Re: VIN # Issue
Nice looking truck!
But the seller lost me, when I read "short wide"... Or maybe I just need to finish my coffee.
Chris 1968 K20 Suburban 1972 K10 LWB PU |
07-22-2010, 10:04 AM | #10 |
The Older Generation
Re: VIN # Issue
If the seller has the paperwork to back up the "Newly rebuilt motor and tranny" statement there is no way you could duplicate that truck for 10 grand, even doing most of the work yourself. LockDoc
07-22-2010, 12:33 PM | #11 |
Re: VIN # Issue
So does the 54" cab to axle dimension in VIN signify that it is truly a short bed pickup?
07-22-2010, 01:43 PM | #12 |
Re: VIN # Issue
I'm not sure yet I'm checking I was thinking 42 was short and 54 is long but I'm still checking to be sure. Also I found a gmc chassis code that was G=light duty..... but I'm not sure what year so no worries if the first digit is in fact a G
CHEVY/GMC VIN DECODERS |
