Old 07-21-2010, 09:08 PM   #1
kcfirstbuild
New Drums ???
I need some new rear drums for my 1968 c-10, but the new drums have no hole in the front for adjusting ?? And the backing has no hole either??
NOt sure what to do , my old ones are junk.
How will i adjust with new ones with no hole and how will i ever get them off i need to ?
kcfirstbuild is offline   Reply With Quote
Old 07-21-2010, 10:01 PM   #2
Sammy
Re: New Drums ???
Adjust them as far out as you can put the drums on. bleed, test drive it around the block. You might have to remove the drums another time to adjust them once more after the brakes get what i call seated. I caution you on your new drums. Mine were made in Canada and one was out of true. After a week one got cherry red after only a block. I had to turn that drum. Sorta pissed me off to turn a new drum.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL"
"You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig."
ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629"
Sammy is offline   Reply With Quote
Old 07-22-2010, 08:26 AM   #3
kcfirstbuild
Re: New Drums ???
OK so what about getting the new drums off ? Lets say after a year or so don't you have to adjust them down to get the drums off, but with the new ones there is no place to do so.
Old 07-22-2010, 08:41 AM   #4
cdowns
cdowns's Avatar
Re: New Drums ???
i've never had an issue with that//if you feel the need you can either put an adjusting slot in the backing plate or the drum your choice
Old 07-22-2010, 08:45 AM   #5
BIG ORANGE
BIG ORANGE's Avatar
Re: New Drums ???
I agree w cdowns!
Things happen for a reason!
BIG ORANGE is offline   Reply With Quote
Old 07-22-2010, 01:53 PM   #6
Jwill41
Jwill41's Avatar
Re: New Drums ???
just knock the nail heads off the backside
http://www.picturetrail.com/jwill41
67 1/2 ton GMC short step side
68 1/2 ton Chevy long fleet side
72 1/2 ton Chevy Suburban
99 1/2 ton Chevy Suburban
founder (and only member) of the primer/clearcoat club
Jwill41 is offline   Reply With Quote
Old 07-22-2010, 07:48 PM   #7
Mike J
vw guy & now c-10 guy
Mike J's Avatar
Re: New Drums ???
yeah, i wondered the same thing when I replaced mine a couple months ago- but I just said oh well, I'll figured that out whenever I have to take them off again, which shouldn't be any time soon...
'68 long fleet
Finally made some progress on the build!!!
My Build Thread
Mike J is offline   Reply With Quote
Old 07-22-2010, 08:22 PM   #8
Sinister
Between Trucks...
Sinister's Avatar
Re: New Drums ???
My front drums are like that. Stupid design. I plan on pulling a drum off every 6 months and taking a peek at the shoes, just to keep on top of it.
Beat it to fit,
Paint it to match...
Sinister is offline   Reply With Quote
Old 07-22-2010, 11:57 PM   #9
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: New Drums ???
I'd go to the junk yard and find thick ones before running those replacement part drums. They flat out suck.
If you do end up having to run them, if you only have two, but them in the back since the rear does so little to stop the truck.
I cut holes in the side of mine for adjusting, and since there was no lip for the spring that goes around the edge, I just left them off. I think I actually still have those springs laying around... it's only been 8 years or so.
