Old 07-14-2010, 02:56 AM   #2576
Vernski
Re: Project Vitamin C-10
Alan thanks for showing the steps on how to make a patch panel, you made it look easy and effortless, you do have a gift there with metal working...Vernski
Vernski is offline   Reply With Quote
Old 07-15-2010, 04:49 PM   #2577
Bkndsdl
Thanks, Allen, for the patch panel detailed pics; awesome as usual. What is the name of the material you are using for filler?
-Mike from Alabama
Why do we park on a driveway, and drive on a parkway?
Jake - '67 Short Step
Dirty Dan - '80 Short Fleet
Bkndsdl is offline   Reply With Quote
Old 07-15-2010, 04:57 PM   #2578
Bkndsdl
Talking Re: Project Vitamin C-10
Originally Posted by Alan's Classic View Post
Goes to show: you can NEVER have too many clamps......
-Mike from Alabama
Old 07-15-2010, 05:57 PM   #2579
Alan's Classic
1 thing at a time is progress.
Alan's Classic's Avatar
Originally Posted by daverod View Post
Looks nice good work as always.
Originally Posted by Strodder View Post
Good job Allan. 5.5 Hours at $40 per hour is $220.00. Now pay your self.
Now I can go by something. haha
I thought it was $25 an hour?
Nope!
When your working on your own $hit, it's FREE.
Until you break something
Originally Posted by 198plus View Post
I fixed it for you
Probably be a wise move to give him my money.......At least I'll only pay one time and it will be right.............
I tried calling you today.
Your welcome and thanks!
Thanks and Rage extreme by evercoat. It's awesome, but kind of thin and runny in the summer
There's a lot more where those came from.
Alan's Classic is offline   Reply With Quote
Old 07-15-2010, 10:27 PM   #2580
ruffrida2005
Member of the longbed union.
ruffrida2005's Avatar
do you paint them Orange so you know if someone in the shop jacked you?
Paul
88 GMC Crew Cab dually, 454/T400
64 LWB 400 HP 350/350T Bagged, under construction! Sold most of it!
92 S10 Iron Duke 5 speed, 5/7 drop for now. soon to be bagged. Sold http://67-72chevytrucks.com/vboard/s...59#post4637759
ruffrida2005 is offline   Reply With Quote
Old 07-15-2010, 10:56 PM   #2581
Alan's Classic
In our shop it's not a matter of getting jacked, but easy to identify when someone needs to borrow some. It also makes them easy to see in dark places.
Old 07-17-2010, 12:00 PM   #2582
Alan's Classic
Ronnie (198plus) is getting ready to bring his cab to me in a couple of days so I tried to find something I could knock out pretty quick on my truck, so I drug my hood out to work on it and it is worse than I remember from a year ago. The reinforcements on the front and rear are ate up with cancer.
The shell is in pretty good shape. Just a slight depressed area towards the back of the "V" rib.
There are some dents but nothing major.
I want to replace the front and rear reinforcements with some good ones that I have taken out of some other hoods. But first I need to build a crib of some sort to support the hood. Once I remove the reinforcements it will fold up like a pretzel. I'm trying to figure out the best and easiest way to support it. I'd like to build it out of wood. I'm thinking of using plywood and cut out ribs to match the profile of the hood and wrap with foam. The thing is I don't have any wood and by the time I go to the store it will be a wasted day.
I also need to get the reinforcements blasted. If I had a bigger compressor I could do it at home. But I don't. So here I sit trying to think of something else to work on. I've got a thinking problem. LOL
BTW still looking for my other (passenger) vent window frame that I painted last year.
Old 07-17-2010, 12:59 PM   #2583
I am trying to find parts for my tilt today. Dang I know I hand them just the other day....well 6 months or so ago. I know if I buy new pieces, I'll find it the minute the order ships.
Good Luck on your find Alan. Can't wait to see you tackle the hood.
Old 07-17-2010, 04:28 PM   #2584
Alan's Classic
Thanks Bill, I hope you have better luck than I have looking for mine.
After a little thinking time I thought why not use the old hood shell to support the hood that I'm working on. I figured both of them together would support each other. It seemed to work out pretty good.
The old shell for support
I drilled the spot welds and busted them loose with a air hammer very carefully. Then use a block of wood and 3 pound hammer to knock it out of the folded over area.
I then took a wide screw driver and opened the flange up that I knocked it out of so I could slide the new one back in. I put the new one in temporarily so I could see how it was going to act. It worked out pretty well.
Then it was one to patching the sides of the hood. I used some old cowl extensions I had left over. They have the perfect contour for the hood.
One side I laid the piece I cut out of the hood for a pattern.
Then tacked it in. I had to be carefull not to weld the reinforcement in place with my tacks, since it will be coming back out later for blasting, prime and paint.
The other side of the hood I had to reverse the way I made the pattern. I cut the new piece larger then used it as a pattern then clamped in place and made my cut on the hood. This is where it is at now.
I will be removing the reinforcement and cleaning up my welds on the inside. Then I will paint the inside of the hood and the reinforcements then put the reinforcement back in. Yes when I weld it back in I will have some burnt areas from welding, but at least there will be some paint in the areas that can't be seen and impossible to get paint on. I will repair the burnt areas when I repaint the inside of the hood.
Old 07-18-2010, 01:07 PM   #2585
my67chevytruck
Under Construction
my67chevytruck's Avatar
Nice work Alan!
Heath
subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php
http://67-72chevytrucks.com/vboard/s...d.php?t=157669
FAQ how to's
1956 Chevy Apache
1967 C10 SWB FleetSide (under construction)
1969 K10 SWB FleetSide (Future Build)
1972 C10 SWB Stepside (Future Build)
56 chevy truck :
http://www.cardomain.com/ride/2955823/1
67 truck build:
http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1
69 k10:
http://67-72chevytrucks.com/vboard/s...d.php?t=389470
my67chevytruck is offline   Reply With Quote
Old 07-18-2010, 02:23 PM   #2586
LiLDrumKing3
I really like what you've done with the truck. I wish I could that kind of body work, I guess I need to get me some more tools.
Jeremy
1965 Chevy c10 Short Stepside
Check out my Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=410658
LiLDrumKing3 is offline   Reply With Quote
Old 07-21-2010, 10:22 PM   #2587
Alan's Classic
Originally Posted by my67chevytruck View Post
Nice work Alan!
thanks Heath
tools are always good . Practice, practice, and more practice. I learn something everyday.
I'm still working on the hood some. I took vacation this week and didn't even go out in the shop Monday and Tuesday. I did go out today and helped Shannon on his cab. Made some progress on the hood, but nothing worth taking pics of. Check out Shannon's build for some good progress pics.
Old 07-21-2010, 10:51 PM   #2588
LiLDrumKing3
Well hopefully I can learn more from you and the rest of the guys from the forum. I'm looking forward to see your truck done.
Jeremy
Old 07-22-2010, 11:42 PM   #2589
Alan's Classic
If you don't learn how to do it here you will definately learn what not to do. We learn from our mistakes and I make plenty of them.
I put the hood on hold. I'll finish the rest of the truck and hopefully they will repop them by the the time I'm done.
Old 07-23-2010, 02:33 PM   #2590
Alan's Classic
I took today and took my oldest daughter out in the shop for some father/daughter time. She said she wanted to build a car, toy car that is. She wanted to build a "mater". She hasn't had much hands on yet due to air tools etc. But she said she wants to paint it.
As I was making it, it dawned on me this would be a great exercise for those that want to learn how to work with metal, but are scared to cut on their truck. There are a lot of the same steps involved and will get you some experience working with metal. Anyway here's what we have done thus far.
Took a toy apart for the wheels and axles.
I cut out the rear wheel opening.
I had to notch out so the tires could fit.
It want be sitting this low, she wants it to sit up normal. I like it low. This is the way it is now. I've got to cut out the engine bay, make the frame, bed floor and wrecker frame and cable. We will see how it turns out.
Old 07-23-2010, 02:46 PM   #2591
sdailey
The Few, The Proud
sdailey's Avatar
The bed gap doesn't look even and the door doesn't match the rocker...... What kind of work are you turning out over there?
Seriously though, that looks great. What the the plans for it? 22's, bags, stroker? Details man we need details.
Shannon
sdailey is offline   Reply With Quote
Old 07-23-2010, 03:55 PM   #2592
Strodder
Daring to be Different
Strodder's Avatar
I don't know Allan? You have way too much time on your hands.
Good practice though
Dennis
Check out my 65/73 Cheap Build Thread.
http://www.67-72chevytrucks.com/vboa...d.php?t=327644
KUSTOM RIDES
FACE BOOK PAGE:
https://www.facebook.com/groups/291198124258863/
1965 C-10 Short Bed 350/700r4
2012 Silverado 1500 Crew Cab
2016 Honda Accord w/ 18" rims
2007 Honda Goldwing Trike w/ NAVI
2001 Yamaha Roadstar Indian look alike
"Life's journey is not to arrive at the grave safely
in a well preserved body, but rather to skid in sideways,
totally worn out, shouting "...WOW!...what an amazing ride!"
Live Life Passionately!!!
[/COLOR]
I AM WE TODD IT, I AM SOFA KING WE TODD IT
Strodder is offline   Reply With Quote
Old 07-23-2010, 05:49 PM   #2593
Nice Alan. That is one scream'n mater.
Old 07-23-2010, 08:08 PM   #2594
Alan's Classic
I got my rockers the same place you did. I can't tell you everything I plan to do to it. Gotta have some suspense
I don't have enough time now, but I did promise some shop time with the girls. You know I will have to make another for the other daughter. I'm actually enjoying it. Maybe they will cherish it when I'm gone. That is if they still like me after their teens. LOL
You darn tootin'. You never know what I will be working on next when you click on this build.
Old 07-23-2010, 09:15 PM   #2595
Strodder
Strodder's Avatar
Don't worry when they hit the 20's they will think your Kewl, and like you again.
Dennis
KUSTOM RIDES
FACE BOOK PAGE:
[/COLOR]
Old 07-23-2010, 10:31 PM   #2596
ruffrida2005
I see the money just pouring in on this one Alan. That looks so sweet.
Paul
Old 07-23-2010, 11:36 PM   #2597
daverod
SSN 706
daverod's Avatar
Very kewl. Somthing about the back of the cab just doesn't look right though. It's not a f#rd is it? Good to you spending time with the girls.
daverod is offline   Reply With Quote
Old 07-24-2010, 01:26 AM   #2598
Captainfab
60-66 Nut
Kudos to you Alan for spending some time with your daughter. This is something you both will remember for a long time to come. Make the time whenever you can 'cause before you know it they'll be all grown up and out of the house.
Old 07-24-2010, 01:35 PM   #2599
my67chevytruck
Under Construction
Nice.
Heath
FAQ how to's
1956 Chevy Apache
56 chevy truck :
67 truck build:
69 k10:
Old 07-27-2010, 12:04 AM   #2600
bubba327
HOW long until spring??
bubba327's Avatar
Way to go Alan . I like to have my daughters help me on projects.
Now they are bringing their friends over since our house is a fun place to hang out.
Be careful or she will be wanting to be drive your truck to school someday!!
69 chevelle convertible
71-C-10 short-wide and low
64 C-10 custom shortbox "Bubba"s Recycling project"
bubba327 is offline   Reply With Quote
1959, 1960, 1964, 1965, 1966, c10, hugger, impala, orange
