Need Door Glass Install Help
I bought a kit to install the door glass in my 48. It came with the channel, no problem, the cat whisker piece, not sure which side it is to be mounted on the door, and a floppy piece of rubber, I have no idea where it goes. Does anyone have a close up picture of this installed so I can see where the floppy rubber and cat whiskers go? Thanks for any help and advise.
Re: Need Door Glass Install Help
Also, is it best to put the chrome piece on the outside of the truck first that goes around the window, and do you put the channel in before you put in the glass or put the glass in and then fish in the channel? Thanks
![]() Join Date: Jun 2002
cat wiskers piece goes on the inside, on the window molding, installs with "staples" or wire,, Not sure which rubber piece your talking about, if the floppy rubber piece is same length as the "wiskers" it installs outside of the window glass...if its about 1.75" wide & as long as the door, goes on the edge of the floor (on cab) parallel to the door & is held on with metal channels screwed to the floor.
The kid Build threads: 51 Jimmy http://67-72chevytrucks.com/vboard/s...d.php?t=154951 http://67-72chevytrucks.com/vboard/s...d.php?t=219902 http://www.classictrucks.com/feature...uck/index.html 68 C10 http://67-72chevytrucks.com/vboard/s...ad.php?t=50348 |
Tags |
door glass |
