05-31-2003, 01:00 AM | #1 |
Phantom wiper problem solved
My wipers would cycle a few times evey time I turned on the ignition. I changed out the wiper delay module, and the problem went away. Just wish I would have known that in the begining.
Before changing out the column switch. Oh well another lesson.
Chris '92 ext. cab s/b 4.3L "Sparky" '04 crew cab 2500 4x4 6.0L |
05-31-2003, 01:23 AM | #2 |
ok, mine cycles once every 12 min approx, as long as the power to the truck is on, sometimes i dont notice it. but i know it still does it. would this cure my problem too, how much did it cost and where is it located? though i do have the dash mounted switch.
Jon 1982 Chevy Silverado 350/th350.... RETIRED 1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231 .... Oklahoma Roll Call |
05-31-2003, 02:47 AM | #3 |
I'm back with 2nd truck!
Jon it's located behind the dash bezel and above the column. It's in all that mess of wires usually near the bottom. Look up at http://www.chevyduty.com and look up part numbers 67-682, 67-683, 67-684 for pics off the modules. Just find the right one for you and replace.
1979 Chevrolet Bonanza Big10 "Tootsie Roll" 1985 Chevrolet Silverado (wife's) Member of the Southern Bowties Club "Don't underestimate how sexy a fat man who drinks to excess can be." Homer Simpson |
05-31-2003, 05:34 PM | #4 |
Genuine Chevrolet
Chris,
You have a newer model with the wiper switch on the turn signal switch. The modules are different. Jon, If yours is an 82 like mine and your intermittent switch is on the dash, the module plugs directly into the back side of the wiper switch. GM still carries new modules but they are a bit pricey. When mine went bad, I removed both the intermittent switch and module and replaced it with a stock non-intermittent switch. The plug is the same and it plugs right into the stock non-intermittent switch.
George 82 Silverado LWB 4x4 350 SM465 NP208 77 Chevrolet Blazer Chalet 400 TH350 NP203 |
05-31-2003, 09:51 PM | #5 |
i have replaced the switch once before when i could turn the wipers on, but not off unless i turned truck off. fixed that. but it does this now? seems funny to replace the same part. i will try the module.. thanks
