Old 07-28-2010, 12:58 PM   #51
68 short step
Re: project " Blue-Ray"
lol, that pic was taken at 3am, and i was using a drop light, so those shadows dont help, ill get one in the daylight
68 short step is offline   Reply With Quote
Old 07-28-2010, 04:57 PM   #52
menace121978
menace121978's Avatar
still looks awesome! they sit at the right angle too
"Dennis the Menace"
1978 Silverado (2wd, 1/2 ton, short bed)complete nut & bolt frame off restomod LQ9/4L80E
MY LS SWAP/FRAME OFF BUILD BOOK
2006 TBSS way too much to list
menace121978 is offline   Reply With Quote
Old 07-28-2010, 10:47 PM   #53
killer71
killer71's Avatar
I'd pimp it!
R.I.P.
Killer 71
10/26/07
killer71 is offline   Reply With Quote
Old 07-30-2010, 09:49 PM   #54
signgod2
signgod2's Avatar
I'm sure i will looking at the road more than the gauges but they are cool so far. I like them. Will the back drop light up blue or white? or is it to much trouble to hook up 12v. to it temp> to light it up.keep it up don.
signgod2 is offline   Reply With Quote
Old 07-30-2010, 09:59 PM   #55
signgod2
signgod2's Avatar
Talking Re: project " Blue-Ray"
Originally Posted by 68 short step View Post
got a bit more progress....got the autometer guages in, and started modding the existing cluster so they'll fit...basically i cut out the backside of the cluster and formed a peice of sheetmetal for the guages to mount to...i re-used the raised factory clear plastic peice, so the guages that needed to be raised, would be...then once everything was fitted in place i dissaembled everything and painted the sheetmetal, and started wiring them up...i used a weatherpack connector so everything is modular and can be removed/installed easily... the non-terminated wires that go up, are for the MIL light,and high beams, and those will be installed in the bezal (with weatherpack connectors as well.)
Did you read the instructions or just throw them away like most of us would for these cluster's? Alot of wiring here too. I'm cunfused!!!!Can you hook up 12V. to it and take a pic in dark to see cluster on or is that to much to ask.?
Old 07-31-2010, 07:25 PM   #56
68 short step
ill get some pics of it light up...and i can have the backlighting, either white or blue, just let me know....
Old 07-31-2010, 07:29 PM   #57
68 short step
getting the firewall back together again, got the booster assy., wiper motor, and A/C box, cleaned up and painted....
Old 07-31-2010, 08:01 PM   #58
mcbassin
Still Learning
mcbassin's Avatar
Great work as always! this thing is going to be like new when you get it done!
Old 07-31-2010, 08:25 PM   #59
RandyP
Getting Old; Going Broke
RandyP's Avatar
Lookin' slick there. Can't wait to see the cluster lit up.
Why is every used 350 sbc out of a corvette?
There's only two things that excite a man, expensive toys and real expensive toys.
VEGETARIAN: That's an old Indian word meaning "I don't hunt so good."
When the going gets tough, switch to power tools.
RandyP is offline   Reply With Quote
Old 08-01-2010, 09:26 AM   #60
N2TRUX
Happy to be here
N2TRUX's Avatar
I think it's going to be much better than new. It should rival the late model trucks in comfort and performance, and it certainly will look better.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 08-01-2010, 03:03 PM   #61
STOCKISH
Formerly- 1972SuperCheyenne
STOCKISH's Avatar
^^ Thats for sure. The late model stuff doesn't even come close in the looks department!
--Josh
My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218
A good crossthread is better than Loctite any day.
Life is not about what you have, but who you have to share it with.
STOCKISH is offline   Reply With Quote
Old 08-01-2010, 08:12 PM   #62
mcbassin
Still Learning
mcbassin's Avatar
Yep, my bad I should have said way more reliable and comfortable than new, not to mention way cooler!
Old 08-08-2010, 07:34 PM   #63
68 short step
some more progress this weekend.....
installed the water/oil sending units, istallled the wiring harness to the engine/trans, bolted the torque converter up, bolted the starter on, and installed the engine/trans for the final time....i also started to intagrate the two harnessess....
Old 08-08-2010, 07:38 PM   #64
68 short step
and some misc cool pics
Old 08-08-2010, 08:15 PM   #65
menace121978
thats awesome! i love how everything in the shop has an LS motor in it
nice progress buddy. kinda off subject but what yeAr truck is the brake master cylinder out of?
"Dennis the Menace"
Old 08-08-2010, 09:31 PM   #66
signgod2
signgod2's Avatar
The brake system is the original one that came with the 1984' truck, He just added some paint to to it. This truck you see here was in the condition you see pre-before I did all the other work to it besides body work and interior. Hardley no rust except on exterior panels roof and fender. Surface rust that is. No rotted out rockers or anything to speak of. I found this truck 1 mile from my home and bought it from a friend. It had 47,000 plus original miles on a In-line 6 when bought. Motor frozen up completely. I knew motor was shot and was going to rebuild anyway. It had been sitting at his home for over 12 years outside with no cover whatso ever on it. And it is as clean as you see now when it came home. I guess I got lucky there. Please keep up the good work don.
Old 08-15-2010, 10:08 AM   #67
menace121978
Hey Don, what did you do to get the autometer temp sending unit screwed into the block? the head on mine is metric and all the autometer stuff is npt. thanks man!
"Dennis the Menace"
Old 08-15-2010, 11:21 PM   #68
68 short step
drilled and tapped the pass side head to a 1/4"NPT.. there is a plug on the pass side head, near the rear, remove it, then take it up with a 7/16" drill, then tap it to a 1/4" NPT....done it many many times, with no issues
Old 08-16-2010, 12:13 AM   #69
menace121978
thank you. i already set the cab on so i'm not going to try and tap it. i did happen to find an adaptor from autometer today that will work
"Dennis the Menace"
Old 09-01-2010, 01:09 PM   #70
68 short step
got a bit more progress done...i mounted the PCM/TCM on the firewall with some vibration isolaters...then i made a adaptor bracket for the gas pedal, so it could mount in the factory location. also made the gas pedal to computer harness .. then i turned to the fuel system, got a sending unit for a 87 c10 with a intank pump, and combinded that with a high pressure walbro pump, and then added the AN adaptor fittings...i have the fuel filter regulator, to mount with the AN fittings as well....
and of coarse im still working on intigrating the 2 harness...
Old 09-01-2010, 01:15 PM   #71
68 short step
i also mounted up a mock-up A/C compressor and fittings to see if there is any clearence issues, but it fit like a glove...deffently, looks like it belongs there, and could of came from the factory like that...here are a few pics of the fitment...also sandblasted and painted the exhaust manifolds...
Old 09-01-2010, 02:38 PM   #72
Hart_Rod
Hart_Rod's Avatar
Looks sweet! That computer setup is so much nicer than the big one.
Hart_Rod is offline   Reply With Quote
Old 09-01-2010, 03:15 PM   #73
71'tahoe
71'tahoe's Avatar
whats the Manifolds off of? It looks like one would have to add the a/c after the engine is set in place or can you have it on the engine when it goes in? I cant tell from the pics..
Thanks,
Greg
71'tahoe is offline   Reply With Quote
Old 09-01-2010, 10:06 PM   #74
signgod2
signgod2's Avatar
Can you put that 1/4" npt anywhere on the head or just in that location?
Old 09-01-2010, 10:14 PM   #75
signgod2
signgod2's Avatar
Is that the a/c that you will use or is that just for mock-up ? I'm gonna ask but did you use the 87' fuel set-up because thats the first year they put feul injected on those style trucks that would fit that style tank ? And you needed that for this set-up of motor? Where does the gas pedal wiring hook up at? sorry so many questions, thats why your the man.
