Old 07-28-2010, 02:29 PM   #1
breeze85cten
Lokar shift cable linkage
I bought the lokar cable linkage for my 85 c10, I have a 4l60e in it and I wanted to see if anyone else has used this lokar setup and how they mounted it on the steering column. pics would be best!!
breeze85cten is offline   Reply With Quote
Old 07-28-2010, 03:18 PM   #2
Puglia10
Re: Lokar shift cable linkage
in for pics
1979 c30 3+3 dually
1946 GMC
Puglia10 is offline   Reply With Quote
Old 07-28-2010, 03:21 PM   #3
STOCKISH
Formerly- 1972SuperCheyenne
STOCKISH's Avatar
Was it originally an auto or manual? Did yours not come with instructions? I will see if I can find the instructions for mine tonight if it will help you. Also, you can use the stock auto shifter linkge from the TH350 on the 4l60e.
--Josh
My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218
A good crossthread is better than Loctite any day.
Life is not about what you have, but who you have to share it with.
STOCKISH is offline   Reply With Quote
Old 07-29-2010, 03:34 PM   #4
breeze85cten
Yeah mine came with instructions and I put it all together but for some reason the angle of mine snapped the end of the cable where the threads are. The angle the instructions give to put the extension on the column is impossible because it will go into the firewall. So i tried a different angle but since I broke it the first time now I am waiting for the replacement. Its been fun! not.
Old 02-08-2011, 10:34 PM   #5
yelo71454
I bought that same kit for the 4l80e in my 84 suburban, and have already thrown it away. I think it just was not designed for our application. I couldnt use that billet arm holder thing and had to rig up cable holder using a home made bracket that bolted to the original speedometer cable holder bolt. I could only get park to drive, and eventually stretched the cable. I spoke to lokar and the guy I got a hold of said that it wouldnt work with my application and to have a nice day.... I have since bought the lokar 23'' auto floor shifter and love it.
yelo71454 is offline   Reply With Quote
Old 02-09-2011, 02:21 AM   #6
draggin86
draggin86's Avatar
Menace121978 has it on his ride
http://67-72chevytrucks.com/vboard/s...345612&page=69
draggin86 is offline   Reply With Quote
Old 02-09-2011, 06:29 PM   #7
yelo71454
and he isnt using that billet swivel holder piece that is saposed to clamp over the column either.... bet you a dollar he cant go from first to park and back again.
Old 02-10-2011, 12:25 AM   #8
breeze85cten
I actually have the same lokar shift cable and same set up with the 4l60e and I can go all the way to first no problem! Ill give you my address so you can send me that dollaR!!
Old 02-16-2011, 04:00 PM   #9
low_84_inchaska
low_84_inchaska's Avatar
i need that shiznit...i am needing a linkage for my 4l60e in my 84...what are the part numbers?
my build http://67-72chevytrucks.com/vboard/s...d.php?t=367330
84 short-wide 2wd. 99 5.3 vortec, built 4l60E, schoenfelds, bubb tune, cyber grey metallic
10 camaro ss/rs, 6spd manual, leather, loaded, cyber grey metallic
low_84_inchaska is offline   Reply With Quote
Old 02-16-2011, 09:31 PM   #10
cparman
sharp as a marble
If you bought this type, It need to go on the left side of the column, Not thr engine side. The cable will also need to be mounted to the trans from the rear of the trans.
http://lokar.com/interior_pages/prod...tlink2_rot.jpg
cparman is offline   Reply With Quote
