Old 07-29-2010, 11:36 PM   #1
77chris03
77chris03's Avatar
a little advice please...
ive been working on my build for a little over a year now and i need some more advice.....with wheels and the floor pan. just look at my build thread for pics. my question is what is the offset for the rear and the front? or a median offset so i can rotate the tires at mileage intervals? its a 68 short bed with 71 suspension (5 lug). please someone give me a direction....i would like to go with 18" wheels btw...
68 C10 Stepper #1- GONE 68 C10 Stepper #2
1977 Chevy Cheyenne...gone...was my first Chevy
04 Tahoe Z71, 04 Silverado 2500HD, 04 Sierra 2500HD
99 Sierra Stepside, 17 Denali HD, 84 K10
My 1st build-- http://67-72chevytrucks.com/vboard/s...d.php?t=379333
My 2nd build-- http://67-72chevytrucks.com/vboard/s...d.php?t=700310
77chris03 is offline   Reply With Quote
Old 07-30-2010, 07:33 AM   #2
cdowns
cdowns's Avatar
Re: a little advice please...
a good backspace is normally 4.5-5inches
Old 07-30-2010, 11:24 AM   #3
77chris03
77chris03's Avatar
Can I use that offset all the way around? Or will it look like crap?
Old 07-30-2010, 11:56 AM   #4
michael bustamante
michael bustamante's Avatar
is the truck lowered?
1967custom
michael bustamante is offline   Reply With Quote
Old 07-30-2010, 06:30 PM   #5
77chris03
77chris03's Avatar
Only a 2/4 drop
Old 07-30-2010, 06:44 PM   #6
lolife99
67-72 parts collector,…
lolife99's Avatar
I like running a narrower wheel up front.
8's with 9.5's,... or 8.5's with 10's.
You really need to play with the backspace number to make it look right in my opinion.
With 17" or larger diameter rims you can use a 5"-5.5" BS up front.
Just remember the BS numbers are in direct relationship to the rim width.
4.5" BS might be fine on a 8" wide rim,... but won't work an a 12" wide rim.
The track width of the front is wider than the rear axle, so for me,... running the same size rim all the way around doesn't look right.
Just my opinion,...
Keith
Convert to disc brakes.
Old 07-30-2010, 10:43 PM   #7
swierker
swierker's Avatar
I'm looking at a set of 17 inch wheels 8" wide 4.5 backspace up front, 9.5" 5.5 backspace in the rear. I'm doing a 4/6 drop front disc brake conversion and 72 rear end. This is all on my 70 LWB.
Will this backspace look alright and fit? In my mind it seems like it should be what I want. And going to get 255/50/17 in front 275/50/17 in the rear.
1970 Chevy LWB - 305/350
In Progress: 4/6 ECE drop, front discs, power brakes, Coys C5's.
swierker is offline   Reply With Quote
Old 07-30-2010, 11:22 PM   #8
lolife99
lolife99's Avatar
My blazer has the wider 71-72 rearend, and I had 17x8's with 5" BS and 17x9.5's with a 4.5" BS. To me that was perfect.
Keith
