#26 | |
![]() Join Date: Aug 2001
Re: K&N Filter Tops
junkyardjohn 69 1 TON TOW TRUCK // 84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. ![]() LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS) DON'T RENT U-HAUL ALWAYS TELL THE TRUTH IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST Last edited by junkyardjohn; 07-22-2010 at 12:30 PM. |
#27 |
Re: K&N Filter Tops
Look John, I will tell you this one time. YOU made the offer on my K&N top not me, all I did was counter offer your ridiculously low and sarcastic offer. If I would of thought that you were not being sarcastic I would of gladly sold it to you if you payed the freight for your offer because I will never use it. Forward to all the moderators you want, but I did nothing wrong. I have never made an offer to sell anything on this site to anyone, because these are the rules of the site. Quit acting like a tat-l-tell and just deal with the consequences of your remarks.
#28 | |
Re: K&N Filter Tops
it does seem like a good idea at first. but from what i learned in my engine design classes in engineering school .....the air speed in the venturi's will approach Mach 1 at WOT. the carbs are designed for the 90 degree turn of the incoming air into the carb, hence the rounded shape of the upper venturi. when you combine the air coming in at 90 deg's, with the air coming in straight down, you drastically change the flow characteristics especially approaching WOT, ie mach 1. the atomization of the carbs were not designed for this funky flow of air. not to mention pulling the hot air out of the top of your engine compartment at low speed or takeoff. in my opinion, you would want either straight down, or 90 deg's, not both. remeber the air bleed sit in the throat of the carb. if you pass turbulent air across those air bleeds, or if you pull air straight down, you screw up the vacuum signal in the carb. they were designed for a steady flow of air across the air bleeds to providing stable vacuum to pull the fuel through the fuel passages. i have never run an open top like what is being discussed here, but i did run an edelbrock cage type filter, which pulls from all direction. i noticed a loss in power and torque, plus some backfiring when i installed it. it all went away when i took it off and went back to a round style with a solid top. for what its worth, on a street engine the old stock dual snorkel type intakes that these trucks came with would be the best bet. it pulls the cool incoming air from the fenders and keeps a uniform air flow coming into the carb. its a differnt story on a healthy race engine. Last edited by dznucks; 07-22-2010 at 09:43 PM. |
#29 |
Re: K&N Filter Tops
They look cool to. 59 caddy?.. I'd love to have an orginal one.
junkyardjohn 69 1 TON TOW TRUCK // 84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. ![]() LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS) DON'T RENT U-HAUL ALWAYS TELL THE TRUTH IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST |
#30 | |
Moderator
![]() Join Date: May 2007
Re: K&N Filter Tops
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul |
#31 | |
Catchy title goes here..
![]() Join Date: Mar 2002
Re: K&N Filter Tops
BTW board rules do apply to pm too.. if someone reports your pm, its the same as reporting a post. I suggest if someone offends you, that you use the report a post feature in the future. My goodness ya'll need to grow up |
#32 | |
Laid Lo
Re: K&N Filter Tops
FWIW I run K&N on everything I own. I believe they clean much better then a paper filter especially in the dust (jeeps, dirtbikes, etc) For you off road guys, a prefilter (panty hose works very well) is something else to consider.
Semper Fi, Jeff ![]() '72 C10 - lays frame '07 Sand Rail - ecotec powered '05 2500HD - tows stuff '67 VW Bug - gas saver '01 Jeep TJ - rock crawler Last edited by blime81; 07-23-2010 at 03:07 PM. |
#33 |
Moderator
Re: K&N Filter Tops
#34 |
Re: K&N Filter Tops
I have K&N's on all my toys too
![]() Even Bonnie thinks is awesome!!!
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild |
#35 |
Re: K&N Filter Tops
the filters are great, it is the filtered tops that disturb the airflow. I agree on the actual filter being a great product, that is why I was disappointed in the filtered top causing such power loss. there sales ideas work good, but the dyno shows the real story.
#36 |
Trucks N Tranzams
Re: K&N Filter Tops
Is Bonnie a rubber Chicken? (Never mind I just remembered the trucks are for chickens post)
![]() '68 Chevy LB 383 TH400/GV/373 posi '56 Chevy 4WD SWB '64 Chevy short stepside '79 Trans Am 455/TH2004R/12blt/4whldisc 95 Kia (Wifes car) 2002 S-10 extended cab pickup "God punishes small sins immediately" Last edited by Arad68; 07-23-2010 at 06:55 PM. |
#37 |
Re: K&N Filter Tops
In my book if Big Al says it then it's a fact, because we have the same first name. Al I hope your biker buddy is doing better. Hey Junkyard John don't let anyone suck you into a bunch of BS it isn't worth it.
I'm not as good as I once was, But I'm as good once as I ever was. |
#38 | |
Re: K&N Filter Tops
#39 |
Re: K&N Filter Tops
Big Al- The filters work great, yes. I'm talking about the filter tops, not K&N filters themselves. The X-Stream filter lids make you lose power, not the K&N filter. I run K&N on all my things as well, truck, car, YFZ.
'70 K10-- 4" lift on 35"s-- For Sale http://www.ksl.com/index.php?sid=733...iew&ad=4578305 |
#40 |
Re: K&N Filter Tops
Having done considerable research myself and in concurrence with some of the others here I feel K-N is way overrated, I can buy a couple of GM over the counter paper filters that have been proven superior in air flow (VELOCITY)in an independent comparison test for what you pay for a K-N I have a K-N for an S&S for a Harley any one wanna buy it ....oops Im not a subscribing member so I can post for sales and I havnt got a replacement yet anyway so it really aint for sale ! Your mileage may vary, spend yur money as you will!
#41 |
Re: K&N Filter Tops
Yes, you can make any paper filter to outflow everything, but the reason K&N filters are good because at the same time they are really good at filtering out dirt and they can take a lot of abuse. Actually, if memory serves me right, K&N filters became well known because they were a great performance offroad filter when they first came out.
#42 |
Re: K&N Filter Tops
Yes you are....... and you've SUCKED contaminents into your engine and it's life is shortened.
Please contact me and I will take that Nasty/Dirty/Lifeless engine from you and GIVE you my stock 350. (no need to thank me) ![]()
Hello members... I'd like you to know that I sold, my 72 GMC (Ratikle), back in November of 2011. I don't visit the site much anymore, but please feel free, to drop me a private message. RIP...."RATIKLE" |
#43 | |
"THE GREEN GOBLIN"
Re: K&N Filter Tops
![]() "THE GREEN GOBLIN" 1972 Cheyenne 10 Short Fleet Side Front 2.5inch Spindles with 2inch Springs Rear 4inch drop Springs. 454BBC TH400,Posi 1971 Cheyenne 10 Long Fleet Side 454BBC TH350,Posi ![]() Drive it like you stole it! ![]() Petey-pablo@sbcglobal.net |
