Old 08-01-2010, 01:10 AM   #1
Patriot
Question Adjusting linkage on 203 T-case
Hey fellas, I have to adjust my linkage on my 77 Blazer with the 350 Turbo/ 203 T-case. It doesn't want to go into gears corectly(the 203). Any one know the process off hand?? Is it like adjusting my Muncies in my old Muscle cars??
Thanks again guys
Patriot-----
Patriot is offline   Reply With Quote
Old 08-01-2010, 09:42 AM   #2
LONGHAIR
Re: Adjusting linkage on 203 T-case
Yes, pretty much the same. There is an alignment hole in the shifter and the links are adjustable on one end.
That may or may not fix your problem though. Those shifters are well-known for being "sticky". They need a complete disassembly and clean-up. Reassemble with some lithium grease and you are go to go. They are way too complicated in their action for what they do. If you use it a lot, you might be ahead to look into a "twin stick" shifter to get rid of the stock unit.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 08-01-2010, 12:45 PM   #3
Patriot
That amy or may not fix your problem though. Those shifters are well-known for being "sticky". They need a complete disassembly and clean-up. Reassemble with some lithium grease and you are go to go. They are way too complicated in their action for what they do. If you use it a lot, you might be ahead to look into a "twin stick" shifter to get rid of the stock unit.
Thank you sir.
