Old 08-01-2010, 04:56 PM   #1
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
3 spd man. trans mounts, rubber goes where?
Im trying to figure out which way the rubber square goes?
Between trans/crossmember? Between bolt head and crossmember?
Its 1 big bolt and a funny looking washer thing..
Am i missing something?
John
1999 Toyota Tacoma 4x4
Old 08-01-2010, 09:47 PM   #2
ray_mcavoy
Re: 3 spd man. trans mounts, rubber goes where?
Each side should have two rubber mounts ... a U-shaped one and a square one.
The U-shaped ones go between the bellhousing and the crossmember. Open end of the "U" facing down (and cupping around) the crossmember.
The square ones go on the underside of the crossmember ... between the crossmember and bolt head.
Those funny looking washer things go directly under the bolt heads. After the bolts are tightened, bend the little "ears" down against the flat sides of the bolt head to keep the bolts from loosening.
ray_mcavoy is offline   Reply With Quote
Old 08-01-2010, 09:56 PM   #3
oldblue1968chevy
thanks! I must've thrown the U ones in the purple power bucket..lol!!
John
