Old 08-02-2010, 12:34 AM   #1
flamingbig10
6.0 powered square
flamingbig10's Avatar
electric fans
since I'm updating my engine to a ls I want to update my cooling fans to a dual setup, I was thinking about these fans from be cool http://www.summitracing.com/parts/BCI-75007/?rtype=10 and this type of fan controller http://www.summitracing.com/parts/HDA-3654/
I wondering how this setup would work and I already have afco radiator like this one http://www.speedwaymotors.com/AFCO-S...ght,24516.html
Aaron
1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot
Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326
flamingbig10 is offline   Reply With Quote
Old 08-02-2010, 02:39 AM   #2
KQQL IT
At the body shop.
KQQL IT's Avatar
Re: electric fans
[QUOTE=flamingbig10;4118585]since I'm updating my engine to a ls I want to update my cooling fans to a dual setup,
I did a Grand cherokee fan in the stock shroud.
Old 08-02-2010, 03:45 AM   #3
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Re: electric fans
Optional fans: Taurus, Mark VIII, Jeep, or LS1 dual fans. A Mark VIII dual speed fan is hard to beat. You can use low speed for the A/C. High speed for temperature probe.
Gerardo a.k.a. Mad Chemist
Silverado XST videos
Old 08-02-2010, 04:10 AM   #4
mongoose
mongoose's Avatar
Re: electric fans
go scrounge though a local junkyard.. Lots of electric fans in cars these days, for dirt cheap too.. If I knew that when i did this swap the first time there's no way i woulda put down the cash for new aftermarket fans.
I've head great things about the ford taurus fans.. they are dual speed pull close to 3000cfm, which is great for almost any sbc... es especially one with a aluminum rad.
I've just got done putting hyundia fans on mine, though depends on the specific measurement of your rad you might not be able to get 2 on there, mine has a 26" core, IIRC, and i could fit two one.. any smaller you'll have to cut some shroud away..
-'73 c/10 - Low with Go - will be complete... probably never.
-'90 2wd Blazer - well... soon enough anyways.
-'84 SWB - the daily gas guzzler.
mongoose is offline   Reply With Quote
Old 08-02-2010, 05:00 PM   #5
storked82
storked82's Avatar
Re: electric fans
Hi Guys
I dont mean to hijack Aaron what all do you need to get the electric fan
Up and running if I get one from a junk yard? Is there certain years that
Will work on a stock 82 radiator?
Thanks guys
storked82 is offline   Reply With Quote
Old 08-02-2010, 07:22 PM   #6
gchemist
gchemist's Avatar
Re: electric fans
Do you plan to run A/C?
Read this on the Mark VIII. http://www.fordmuscle.com/archives/2...cfan/index.php
I run dual LS1 fans. I'm going to upgrade to a dual speed for my A/C.
Any fan will require slight modifications to fit.
Old 08-02-2010, 07:52 PM   #7
jared87350
Re: electric fans
make sure you update you charging system or you will have a huge drain on your system valtage and amp.
jared87350 is offline   Reply With Quote
Old 08-02-2010, 11:42 PM   #8
flamingbig10
6.0 powered square
Re: electric fans
I have a 100 amp alternator
Aaron
Old 08-04-2010, 05:47 PM   #9
storked82
storked82's Avatar
Re: electric fans
Hi Guys
I donot have ac but my motor is a 400hp plus 383 stroker my temp usely
Runs around 190 degrees all the time Im not one for wireing LOL so I need
something easy to hook up I plan on heading to the bone yard as soon as
The 100 degree temp outside goes down lol to hot out there for me
Thanks guys for all the help and info
Jeff Main
