Old 08-01-2010, 04:53 PM   #1
enick72
enick72's Avatar
Bed swapping 50 to 55
Just wanted to be clear before buying something I can't use. Sre the 47-53s different from the 54-55 because it's 2 inches deeper and the rails are flat? The reason I'm asking is because I'm having a hard time finding complete bed for my 55 but I have found a whole 50 that I can buy for a good price. My plan would be to swap beds but just want to make sure that mounting is the same along with running board match up etc.
55 Chevy 1st series
65 Chevy stepside short bed
www.bigslikpokertables.com
enick72 is offline   Reply With Quote
Old 08-01-2010, 05:44 PM   #2
Steve@OldSub.com
Cancer Survivor in the making.
Steve@OldSub.com's Avatar
Re: Bed swapping 50 to 55
I expect there would be some small differences in the mounting. I don't know that to be the case, but knowing how the beds differ I would not be surprised. What you can't do is put a '54-later bed on an earlier truck because of the difference in bed depth.
Well actually you can do it, I've seen it done. I don't think it worked.
'55 1st GMC Suburban - '54 GMC 1-ton trailer puller (in process) - '54 GMC 1-ton Hydra-Matic - '47 Chevy AD COE and lots more rusty old iron.
Steve@OldSub.com
OldSub.com . MaxwellGarage.com . OldGasTowRigs.com
Steve@OldSub.com is offline   Reply With Quote
Old 08-01-2010, 07:30 PM   #3
mr48chev
mr48chev's Avatar
I don't think you will have any problems as I don't think the first series 55 frame is any different than the earlier frames dimension wise. I have a 54 frame under my 48 and the 48 box bolted up fine.
Old 08-01-2010, 07:50 PM   #4
Steve@OldSub.com
The kickup is higher on the earlier frames. I have no doubt putting an early box on a late frame would be easy, going the other way is not.
Putting a late bed on an early frame ends up looking like this.
This particular truck was a '54 or '55 1st GMC with Hydra-Matic with a damaged frame. The restorer chose to repair it by using a '53 frame not realizing what the result would be.
The asking price was too high for a truck done right so I quickly went the other way.
Steve@OldSub.com
Old 08-01-2010, 08:53 PM   #5
enick72
enick72's Avatar
I do remember reading that in 54 the bed was lowered for ease of loading and unloading and straightened the rails to give the extra couple inches.
mr48chev
Was this a direct bolt up or did you have to use spacers in places or fab anything?
55 Chevy 1st series
Old 08-02-2010, 08:05 AM   #6
ClassicDreamer
I have a 52 bed on my 55 cab. The chassis is a s10 though. Bunch of mods as well. I filled that gap show with a piece of flat sheet metal.
ClassicDreamer is offline   Reply With Quote
