Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 08-02-2010, 07:43 PM   #1
mario1128
how much
how much hp will a stock 12 bolt rear end handle with stock axels .i have an auto tranny and 2800 stall . I picked up a spare rearend and am going to rebuild it so what ever it needs to handle 400- 500 hp ill do.
72 chevy former 1ton converted to 1/2 ton roller 350 engine , turbo 350 and a 12 bolt on leafsprings with a flip and drop springs
mario1128 is offline   Reply With Quote
Old 08-02-2010, 07:59 PM   #2
cableguy0
Re: how much
The power isnt the issue. Its the traction. If you plan to run slicks at the track and make it hook. I would reccomend a good posi unit (eaton) and a set of upgraded axles. Other than that the rear itself is plenty strong.
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
Old 08-02-2010, 09:25 PM   #3
mario1128
Re: how much
thanks i knew the are a strong rear and it will have a posi and a new 4 link setup hopefully by spring
Old 08-21-2010, 09:08 PM   #4
GMC70c20
Re: how much
which 12 bolt are you talking about? The ones they put in cars or trucks. The ones they put in trucks are pretty week even with axles and a new carrier. Now the 8.875" 12 bolt (the one they put in cars) with a good set of axles and a good carrier then ya it should handle 400-500hp hooked. Like cableguy0 said you could put a tired 10 bolt under it and hook 1000hp to it but if it never hooks itle never break. Another thing to remember is the more weight you are moving the more stress it puts on drivline components so maybe instead of spening $600 on a carrier tryd to shed 300-400 lbs plus then it will hook better and drive better. Or do get a new carrier and still try to shed some weight.
1970 c20 converted to c10 sleeper
1979 c20 the wood hauler
1991 honda civic daily driver
spray and pray baby
GMC70c20 is offline   Reply With Quote
Old 08-21-2010, 09:35 PM   #5
cableguy0
Re: how much
I disagree on the truck rear being that weak. It will handle 500hp with decent parts inside. I would reccomend a good posi unit and new axles with c clip eliminators. The car 12 bolt is stronger than the truck 12 bolt but its not near as extreme as its made out to be.
