Old 08-04-2010, 05:45 PM   #1
theprestongroup
Keeping A/c while laying on 22's
Is it possible to relocate the factory A/C under the dash? I realize that it could be a lot of work, but could it be done? Has anyone modified the factory configuration under the hood to make this work? Pics please.
theprestongroup is offline   Reply With Quote
Old 08-04-2010, 06:33 PM   #2
OARNGESI
OARNGESI's Avatar
Re: Keeping A/c while laying on 22's
Yes vintage air
70 SWB STEPSIDE
70 BLAZER
09 challenger
OARNGESI is offline   Reply With Quote
Old 08-04-2010, 08:11 PM   #3
theprestongroup
Well I was trying to work with the factory A/C components. I am trying to do this on the cheap.
Old 08-04-2010, 10:30 PM   #4
N2TRUX
Happy to be here
N2TRUX's Avatar
laying on 22's on the cheap isn't going to happen so you may as well get past that.
To answer your question specifically we will need to know "what" 22 you plan on running. Regardless of specific size, you are asking a lot to truly lay out and keep the factory a/c.
I did modify a factory fan and housing to clear a set of 245/45/20's, but that was just to lay crossmember. If your wanting to lay frame, plan on buying an aftermarket a/c system.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 08-05-2010, 01:29 PM   #5
theprestongroup
N2TRUX, I hear what you are saying. I actually was thinking laying cross member but it came out laying frame. Could you please enlighten me on what is needed to obtain the results that you ended up with?
Old 08-07-2010, 12:36 AM   #6
N2TRUX
Happy to be here
N2TRUX's Avatar
..... Could you please enlighten me on what is needed to obtain the results that you ended up with?
That took a LOT of mods to accomplish. We sectioned the inner fender and moved it up 3", then sectioned the fender liner in several pieces and made it taller.We sectioned the blower housing and slimmed it down, then custom built a fan that was slimmer.
I don't recommend going this way. It was a snowball mod, that just kept getting bigger, and bigger.
Articles-
"Refining Sierra"
Old 08-09-2010, 01:25 AM   #7
ZZ4Blazer
What about adapting a different AC set up? Might be some work, but might be loads cheaper.
I know in my 98 tahoe, nearly everything is under the dash/ the footwell of the passenger side. Theres a ton of these trucks out there. If youve got a u pull it yard, might be worth looking into.
ZZ4Blazer is offline   Reply With Quote
Old 08-10-2010, 03:37 PM   #8
robnolimit
robnolimit's Avatar
Carefully remove the stock ac/heat unit. It can be modified to mount behind the seat, vents at the center of the seat edge, and one in each corner above the seat back. The controle must be moved as well. Takes about 25 hrs of fiddling to do it well. I'd go the vint. Air route.
robnolimit is offline   Reply With Quote
Old 08-10-2010, 03:50 PM   #9
ibad57
ibad57's Avatar
Im working on a system for my extended cab 1972 where the center councel would go is a heat ac unit from rear of a Limo puts heater core and evaporter between seats needing only duct going forward to vents it will require air diverters and cables to reg where air goes but cleans up the firewall.
I will post some pics in a day or so along with info on air diverters
My Project Old Glory trike visit here http://www.facebook.com/home.php?#!/...48577705162172
ibad57 is offline   Reply With Quote
Old 08-10-2010, 03:53 PM   #10
ibad57
ibad57's Avatar
Tryed it too much trouble and fit issues
Old 08-10-2010, 08:15 PM   #11
ibad57
ibad57's Avatar
This unit came from a limozine and was mounted behind rear seat with hoses to front I plan on creating seat cushon to match seats to cover ac box and center consel to front for shifter and cocealing the ducts and hoses
Nostalgic air parts has air diverters called y valve at $24.99 special made i ordered 4 cost was $99.00 shipped
i have an extra unit made more upright im not using e mail if interested
ibad57@roadrunner.com
Hope this helps it saved me a lot
