Old 08-04-2010, 06:11 PM   #1
70stroker
70stroker's Avatar
dash pad removal
Alright guys pretty new to this body style of truck, been into 67-72 for a bit to long. I just recently got a 86 4x4 and am gettin ready to order a new dash pad for it seeing as mine is all cracked.
What all is involved in removing the old one? any write ups on it anywhere?
thanks
70stroker is offline   Reply With Quote
Old 08-04-2010, 07:11 PM   #2
bigblock73
yeller
bigblock73's Avatar
Re: dash pad removal
Remove dash cluster bezel, then simply remove the screws along the bottom of the pad on the passenger side...lift up slightly on the pad and pull out. Simple as that.
bigblock73 is offline   Reply With Quote
Old 08-04-2010, 07:21 PM   #3
Prerunner1982
Prerunner1982's Avatar
There may also be a screw at each end (if you open the door and look at the end that butts up to the door), perhaps only on the passenger side. It has been awhile since I have looked at my 82.
Jon
1982 Chevy Silverado 350/th350.... RETIRED
1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231
Oklahoma Roll Call
Prerunner1982 is offline   Reply With Quote
Old 08-04-2010, 08:21 PM   #4
355bullet
355bullet's Avatar
LMC has a dash cap that goes over the old one...100bucks
355bullet is offline   Reply With Quote
Old 08-04-2010, 09:43 PM   #5
bigblock73
yeller
bigblock73's Avatar
oh yeah, I forgot the 81+ had the screws on the ends...good catch.
Old 08-05-2010, 12:12 PM   #6
cor86
It also has clips along the windsheild, so you will have to gently pull it towards you and up when taking it out. A bit of advice, order a $100 cap, unless you want to spend big $$$ on a good one. I bought a cheapo, and wish I had just got a cap. If I could do it all over again, I would have just looked into having the original recovered with vinyl.
cor86 is offline   Reply With Quote
Old 08-05-2010, 04:43 PM   #7
OleBlue79
OleBlue79's Avatar
Manbearpig had some pics of his from LMC on a thread on here. Looked really good.
OleBlue79 is offline   Reply With Quote
