Old 08-04-2010, 10:22 PM   #1
69-72
69-72's Avatar
Dana 44 oil seal replacement
It appears that I have one side of my front axle leaking. From what I can figure I will need to replace the seals in the middle of the axle. What else should I consider replacing while I have it all apart?
I don't really 4x4 much, just put it on in the winter from time to time and the Blazer is pretty original, I doubt that the 4x4 was used much before I got it.
1969 Chevy Custom Camper 3/4 ton Rust free survivor
1972 Chevy Blazer CST 4x4 Almost Rust free survivor
1972 GMC Jimmy 2wd Undergoing surgery
69-72 is offline   Reply With Quote
Old 08-04-2010, 10:36 PM   #2
BERT306
BERT306's Avatar
Re: Dana 44 oil seal replacement
I'd replace the u joints on the axle shafts while it was apart
72 k10 swb. 350/th350/np205. Vintage air'd daily driver
BERT306 is offline   Reply With Quote
Old 08-05-2010, 06:14 AM   #3
LONGHAIR
I would take a good look at the bearing inside the spindle too. There is no way to service them w/o disassembly, so they get ignored.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 08-08-2010, 02:29 PM   #4
SeventyOne
This would be the time to regear if you have been considering it.
SeventyOne is offline   Reply With Quote
Old 08-09-2010, 10:42 PM   #5
D.PASSMORE
One of the First
D.PASSMORE's Avatar
You can get the seals from a local parts store. Its the same PN for all 1/2t, D-44 front axles. Chicago Rawhide (CR) makes them and be aware that the crosses in your outer axles will have to be taken to the parts store and matched up. Sometime in '72, GM started putting larger crosses in the outer axles and the only sure way to know is remove and take with you. Hope this helps.
Oh yeah, don't jack the slingers up, they are to find these days.
DAVID PASSMORE
ST AUGUSTINE ,FL
ZIP 32084
'71 SWB K/10 CUSTOM DELUXE (Chili)
'72 BLAZER K/5 Muscle Truck (Mule)
'72 LWB K/20 CHEYENNE (Blackie)
D.PASSMORE is offline   Reply With Quote
