08-02-2010, 10:15 AM | #301 |
Glen
Re: How about some pics of '73-'91 Crew Cab Short beds?
Sounds nice!
Glen Simpson Severed Ties - Oregon Roseburg, Oregon
Past Trucks
08-05-2010, 05:04 PM | #302 |
This thread should be made a sticky with all the others!!!
'11 Z71 '88 V-30 Crew Cab '87 V-10 '69 Camaro SS '52 M38 '46 Rat Rod Word of the wise should be sufficient! |
08-05-2010, 05:34 PM | #303 |
I've tried.
there isn't enough traffic for it to become a sticky
CHEVY ONLY |
08-06-2010, 02:08 PM | #304 |
Not for a lack of trying though.
08-06-2010, 05:57 PM | #305 |
CHEVY ONLY |
08-06-2010, 06:09 PM | #306 |
Showoff
08-06-2010, 06:12 PM | #307 |
CHEVY ONLY |
08-06-2010, 06:27 PM | #308 |
I posted pics somewhere, but dunno where they went???
2000 GMC CCSB 454/4L80 6” lift SAS 1999 Chevy CCSB 454/NV4500 6” lift 1999 GMC Yukon 350/4L60 4" SAS |
08-06-2010, 06:36 PM | #309 |
Very COOL!!
CHEVY ONLY |
08-07-2010, 04:53 PM | #310 |
heres mine
08-09-2010, 10:33 AM | #311 |
One day...
Wow thats cool!
08-10-2010, 10:20 AM | #312 | |
The Cheesiest
Lookin good!! |
08-10-2010, 12:22 PM | #313 |
Thanks CHEESE!
when is the open house? All these badass 4x4 CCSB's are giving me an itch....don't think the wife would be too happy if I scratched it though
CHEVY ONLY |
08-10-2010, 01:39 PM | #314 |
The Cheesiest
Sept. 11th! Ill post the flyer when i get it! Bring that beast!!
08-11-2010, 06:59 PM | #315 | |
Do you know appx. how much drop you ended up with?
Also, what size tires are those? I read the last few pages of your thread and it mentioned 255/70-15; wondering if those in the picture are that size. They fill the wells nicely. Truck has a good stance! Quote:
2009 Honda Fit CfC (bsf 44.9 mpg) 2000 Tahoe Limited 1991 GMC CrewCab Dually 2wd, will end up swb, not dually and replace CCswb below 1991 GMC CrewCab Dually 4x4, just going to fix things up for now 1982/1989 K5/GMC Jimmy 2wd 1987 GMC 1/2 ton swb 2wd Crew (sold) Last edited by kevinr1970; 08-11-2010 at 07:00 PM. |
08-11-2010, 07:33 PM | #316 | |
Cool!
I'll have to see what's going on then Quote:
I don't know for sure how much drop I got. It has 3" spindles on the front and one coil plus cut off the springs. I swapped to 56" springs in the rear with 5 leaves at the same time I did the flip. The 88-98 diff has slightly taller spring perches. The frame was only 1-1 1/2" above the axle tubes so I flipped the rear spring hanger upside down and raised the reab back up @ 2 inches to get it where it is now. I still need to cut the front bump stops down and put some notches in the rear so it won't bottom out so easily. Down the road I'm either going to bag it or convert to 4x4....I haven't decided yet Maybe I'll run across a 4x4 crew for cheap before that though, fingers crossed
CHEVY ONLY |
08-11-2010, 10:35 PM | #317 |
That truck is bad azz, perfect lift and stance....I want one.
03 GMC Yukon XL 2500 Quadrasteer, wife`s DD 84 Chevy K30 CC SRW 55 Chevy 210 2dr post |
08-11-2010, 11:53 PM | #318 | |
With the 3" spindles, how much did you have to trim off the LCA's to get the 8" rally's to clear? I have removed more material than I am comfortable with on one side already and as I was finished with that side (so I thought), I relized when I put weight on the front wheels the LCA will probably make contact again. So I need to put the jacks under the the LCA's to simulate it being on the ground and see if I need to remove more material. I have chrome rally's and was hoping to run the weights on the inside but I don't think that is possible now. Mine is flipped in the back also and without the bed on the truck and no shocks, I can bounce up and down on the frame and get it to hit the axle. So a notch is going to be put on before I install the bed.
2009 Honda Fit CfC (bsf 44.9 mpg) 2000 Tahoe Limited 1991 GMC CrewCab Dually 2wd, will end up swb, not dually and replace CCswb below 1991 GMC CrewCab Dually 4x4, just going to fix things up for now 1982/1989 K5/GMC Jimmy 2wd 1987 GMC 1/2 ton swb 2wd Crew (sold) |
08-12-2010, 07:13 AM | #319 | |
255/70/15 all around As for the lower arms, I'm not sure. The spindles were on the truck already. I can take some pics of the lower arms if that might be helpful.
CHEVY ONLY |
08-12-2010, 01:23 PM | #320 | |
I knew I would have to remove material with the 3" spindles when I started, but it still makes me nervous!
08-12-2010, 08:18 PM | #321 |
^^who I am^^ what I say>
seeing all these, really makes me want a crewcab!
70 chevy LWB 350/TH350 Barn find (AKA the 70) http://www.67-72chevytrucks.com/vboa...d.php?t=406364 East Tx Squares |
08-16-2010, 09:02 PM | #322 |
Cleaned her up a bit
CHEVY ONLY |
08-16-2010, 10:00 PM | #323 |
if you come down here, bring it to the shop and LETS SPRAY IT!!
2006 GMC Sierra CCSB, 6.0 swap 2000 Chevy C3500 Crew Cab shortbed dually 1999 Chevy c2500 Crew Cab shortbed 1982 El Camino 350/350 1979 K5 2wd blazer bagged/bodied 1986 Monte Carlo SS 1991 Chevy CK SWB-67 clip and tailgate, bagged 350/700r4 1955 Chevy Bel Air 2014 Chevy Silverado ccsb |
08-16-2010, 10:01 PM | #324 |
Nice Joe. When is the open house out in west Texas?
My AD Truck Build Thread 52 GMC one day laying on the running boards 2004 Chevy Crewcab. 3/5 and notched |
08-17-2010, 10:10 AM | #325 |
The Cheesiest
Sept. 11th i should have a flyer today!
Tags |
ccsb crew cab short |
