08-05-2010, 05:54 PM | #1 |
Alright Alright Alright
My door wont latch
Last night, I noticed that when I shut my door, it will only initially latch, but wont latch flush (as if you didnt shut the door hard enough). It doesnt matter how hard I slam the door, it will just initially latch. I can push on the door and it will spring back. What could this be?
1972 Cheyenne Chevrolet red and white 357ci, Vortec heads, GM Performance high rise intake, Comp 268H .454/.454 218/218 110 LSA Quadrajet carb, Flowtech headers, 2.25 40 series HEI, Curve kit, TH 350, 3.07 gears 275/60/15s on 15x8 rallies |
08-05-2010, 08:37 PM | #2 |
Re: My door wont latch
Has this problem just started or has it been that way for some time?
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC |
08-05-2010, 09:11 PM | #3 |
Most likely the latch plate on the door frame has slipped inward. Try moving it out a little. Four bolts hold it in place and it has special spacers with teeth to keep it from slipping.
72 Fleet (died) 78 Step (sold) 55 Step named Fred (sold) 00 F150 68 Step (named El Scorcho by PO) Build thread for the new El Scorcho http://67-72chevytrucks.com/vboard/s...d.php?t=392932 |
08-05-2010, 10:44 PM | #4 |
I agree with readjusting the latch plate. From all the slamming it's most likely jarred loose. If that doesn't solve the problem it could be the latch internals need to be cleaned and lubbed up. And if there the hinges have too much slop the door could be sagging causing a misalignment too.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL" "You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig." ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629" |
08-05-2010, 11:17 PM | #5 |
I notice that in the past month that i have had to pull the door towards me to open it from the inside or push on it from the outside. I adjusted the latch plate a few months ago and it is still in the same place. Every 10 door shuts, it will close correctly, but I will hear a spring sound from the inside of the door which makes me think its the latch. Is it hard to get to once I take the handles and door skin off?
04-25-2011, 09:49 PM | #6 |
You ever determine the problem? Mine is now suddenly doing the same thing.
Eric 1967 C10 SWB 383 Stroker/TH400 Brother's One Piece Power Windows Shaved Doors, Markers, and Bumpers 4/6 Early Classic Drop Rear Fuel Tank (49-52 Chevy Car Tank) Surf Blue Paint Bella Vista, AR (Arkansas for those that get the 'A' states mixed up) My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=330869 |
04-25-2011, 11:00 PM | #7 | |
The Older Generation
Did you put new weatherstripping on it by chance? First thing I would do is to roll down the window and spray some lube on the door latch down through the window opening. You can see it pretty good with a flashlight. LockDoc
04-25-2011, 11:38 PM | #8 |
Thanks, Leon. I'll try that. It does have new weatherstripping, but was working fine with it for a couple of months.
