08-06-2010, 10:20 PM | #1 |
how to tell gear ratio and posi?
Guys, I have a 78 4X4 and was hoping for help finding out what gear ratio and if it has posi? I know you can tell by the codes in the glove box? thanks Rick
08-06-2010, 10:27 PM | #2 |
Re: how to tell gear ratio and posi?
Your right! It should list the ratio in the spec sheet, and there is a code for posi, but I cannot remember it. The not-so-easy way is to mark the driveshaft, put it in neutral, while jacked up, and count how many times the tire turns before the driveshaft does a full turn. For posi, just pop the diff cover off and look.
08-06-2010, 11:57 PM | #3 |
Or roll into a water puddle and powerbrake it... It also says the gear ratio on the ring gear and a posi is EASY to spot with the diff cover off
08-07-2010, 12:16 AM | #4 |
Posi- jack up one wheel turn, if it turns easy no posi
Gears- do the driveshaft counting method Word to the wise: due to parts interchangeability most old square bodies have been changed/modified/swapped/played with/upgraded so your glove box might not have the codes that match your current rear end, it might not even be your original glove box... lol
1991 V3500 350TBI/4l80/205 D60/14bff - Crew long 1987 IrocZ-28 525 horse/567 Lb Tq 383 1976 K30 on 39.5s One wheel drive thanks to a np203 and some K5's lol |
08-07-2010, 09:58 AM | #5 |
Still plays with trucks
The option code for posi is G80. You can decode everything on the sticker in your glove box. Just do a search for RPO codes.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577 69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been 69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc 68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E 79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars |
08-07-2010, 10:08 AM | #6 |
Not necessarily true about the posi check with a wheel in the air. With the gov-lock posi carriers that are very common in trucks you have to have several hundred RPM difference between the wheel speeds for it to lock and engage both tires and then they are mechanically locked together like a spool. Either wheel will spin freely if one is in the air. They feel like an open carrier when you do this test. Only way to tell for sure is to pull the cover and look. With a clutch type posi this test will work. If the rear end is in the air like at a pull it yourself wrecking yard both tires will spin in the same direction on a clutch type posi and in opposite directions with an open carrier.
Exactly what I was going to say.
08-07-2010, 03:06 PM | #7 | ||
The whole mess is a way over-complicated timebomb. Any kind of horsepower gains or tire size increase will spell it's end pretty quickly. Spin the tires while pulling your boat up the ramp and hit the dry pavement.......boom.
You can review the site's rules here. Quote:
Bad planning on your part does not necessarily constitute an instant emergency on my part.... The great thing about being a pessimist is that you are either pleasantly surprised or right. |
08-07-2010, 03:20 PM | #8 |
Any Links to a full and detailed description of a gov-lock longhair?
08-08-2010, 08:05 AM | #9 | |
Yup, right here They audio part still refers to it as "locking" which it does NOT do. It just applies pressure to the clutch packs. There are no springs between the side gears like a traditional Posi unit. So the Gov-lock functions much like an open differential, until the centrifugal mechanism ramps up....but even at that point, it's still just a clutch-type posi, with some little "clock works" parts to overcomplicate things.
08-08-2010, 11:27 AM | #10 |
Just FWIW - even at the factory the terms "locking" and "limited slip" are used interchangibly - in error.
There are even two separate RPO codes: the aforementioned G80 but, in addition, there is a lesser known G81 code as well. The locking (usually with a moveable pawl) vs slip designs (usually done with clutch packs) are dramatically different in the way they manage how torque is distributed. The specifications people would often mix and match the release codes, either because they didn't fully understand how the device worked, or simply out of convenience (or habit). Don't ask me to recall which is which (....further proof of my original point...) K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ Last edited by Keith Seymore; 08-08-2010 at 11:29 AM. |
10-24-2010, 10:05 PM | #11 |
Does anyone know about the process of rebuilding a G80 Posi? I have the factory one in my truck and I'm pretty sure the clutches are worn out because it only works half the time and not that well.
10-25-2010, 11:40 AM | #12 | |
Get a bottle of the GM posi additive from the dealer and use it to lube up the new clutch plates before you put it together. This will prevent a whole lot of damage to the brand new clutches and make it last longer after the rebuild. Buy new preload springs too. The old ones have lost much of their original strength over the years and new ones are pretty cheap.
10-25-2010, 07:25 PM | #13 | ||
I wouldn't waste a nickel on rebuilding it. Replace it with a proper spring-loaded posi unit.
