08-07-2010, 12:25 AM | #26 |
Back in the sticks
Re: Assembly Manual Index
Derek, I've got most of the Blazer pages earmarked in my manual. I'll start putting those in when you are ready for me to. Do I need a log in to use the spreadsheet?
1971 Cheyenne C-10 w/700R4 and Tuned Port Injection 1969 K5 Blazer w/Tuned Port 2010 2SS/RS Flaming Orange Camaro 2011 K1500 Suburban 2014 K1500 Pickup 2008 Nissan Altima? The wifes' hoopty |
08-07-2010, 01:42 AM | #27 |
I changed the permission on the spreadsheet so that anyone with the link can edit it.
08-07-2010, 08:00 AM | #28 |
Who's got steelies?
I got the gap from 31-39 covered for ya!
Bump!
1969 C10 LWB W/ 250 I6 & 3spd 1970 C10 with '67 small window cab, 68 front end, blue; 305/TH350, 3.08 limited slip rear end, manual brakes, power steering; & 4-wheel drums-My daily driver. 1975 Chevelle Malibu Classic Coupe 350/th350 mint green 1970 C20 Suburban 350/700R4 4.10 gearing green & white 1978 Big 10 Silverado 350/th350, working ac, 2 tone blue-My summer daily driver 1983 GMC 1500 Sierra 305/SM465 2.73 rear end How to add a trip odometer to your 67-72 stock speedometer How to rebuild your Q-Jet My Truck Page My Youtube Channel |
01-05-2012, 05:00 PM | #29 |
I'd like to see us get this thread going again. I've numbered my book but came up with 1064 pages NOT the 1066 previously posted. So far I've labeled 136 pages in my personal copy of the spreadsheet & copied many of those into the Google doc version too. I've hit a point where info in the online doc does not match my version. Please help me resolve where I'm off. My p.267 is the plug wires for the L6, not the V8 as Red71Cheyenne has listed.
Anyone want to get involved? Post it up.
Bryan '52 Bel Air 2dr HT - in pieces '68 C10 - 6cyl/4spd REMOVED, LT1/T56 to be installed “Any society that would give up a little liberty to gain a little security will deserve neither and lose both.” - Benjamin Franklin "And those who know what's best for us, Must rise and save us from ourselves" - RUSH lyric (mockery) |
01-05-2012, 06:43 PM | #30 |
You are right. Pg 267 is the 6 cyl. Are you using the link above in post #27
01-05-2012, 08:09 PM | #31 |
Yes I am. Thanks for confirming p.267 for me. Can you spot check a few of my entries between 295-446 to make sure those match yours? I want to do more updates but don't want to mess anyone up.
01-06-2012, 02:32 AM | #32 |
OK I put up some more updates. I'm stuck on My p.582 - Park Brake Lever Boot, p.583 - Door Plate Location - Custom. As you can see, my numbering is 2 pages off from Red71cheyenne at this point. Can someone audit this? LMK & TIA.
01-06-2012, 07:08 AM | #33 |
You are correct again. I don't know how it got off. If you have microsoft excel you can open the assembly manual link, then save it to your computer and you can edit your own copy. I just did it on my computer.
01-06-2012, 07:16 AM | #34 |
It looks like it is messed up from there forward. It won.t allow you to change the original spreadsheet. Maybe some has password can go in and fix it.
01-06-2012, 07:36 AM | #35 |
I sent red71 a message to see if he can fix the problem
01-06-2012, 10:37 AM | #36 |
So does your manual numbering end at 1064 also? I thought I numbered mine wrong but it sounds like you match my numbering. I went into the Google doc this morning & pushed all of the remaining entries down 2 lines to correct it. I'll keep an eye on things as I continue. Thanks for checking your copy.
01-21-2012, 09:08 PM | #37 |
I just spent some time downloading the file. I'd like to thank all these folks for spending the time to make this useful index:
Ackattack KEL Hammer500 oldgold70c10 Lugnut64052 nyncompute 68C10HotRod Red71cheyenne An impressive collaborative effort. Congrats. (My aplogies if I've left anyone out) https://docs.google.com/spreadsheet/...sOXcwVWc#gid=0
- Jim - My Daily Driver is a 1969 Chevrolet Custom/20 Fleetside 350/TH400/Eaton H052 4.10 and its Project thread is here http://67-72chevytrucks.com/vboard/s...d.php?t=456911 |
05-04-2012, 11:20 AM | #38 |
Restoration Virgin!
Hey Ack...now this is complete, can you change the permission again to avoid any accidental deletions/ additons etc doesn't happen.....maybe if anything needs changing pass them through you or give permission to several folks?? Thoughts??
Geoff with a G 1968 Chevy C10 SWB The Mistress 1972 Custom Deluxe C20 Suburban A Suburban Named Isabella 1966 Ford Mustang Mama's High School Graduation Present |
05-04-2012, 04:54 PM | #39 |
I didn't realize it was complete. I'll take a look at it and see what I can do.
05-04-2012, 04:59 PM | #40 |
OK, I changed it so only I can edit it.
What happened to the heading at the top to show what year/application it applies to? Originally it had each year, 2wd or 4wd, blazer, burb, pickup, 1/2ton, 3/4ton, etc which if you imported it to excel would allow you to filter it to your application. |
05-05-2012, 12:15 AM | #41 |
When i click on the service manual index I get a blank spreadsheet. ? How much is done? I bought mine today on paper not an electronic copy.
Dan <---(my name) 67 SWB C10 project "GEORGIA"-59 Brookwood 2dr wag...Next project-03 Tahoe 4x4 5.3 family ride-07 Hondur Accord, commuter car |
05-05-2012, 05:45 AM | #42 |
You have to click on sheet one tab at the bottom of the spread sheet page that you downloaded. Any other sheet tab you click on shows blank sheets.
05-05-2012, 10:53 AM | #43 | |
Restoration Virgin!
Appreciate all of your efforts!!!
08-02-2012, 12:25 AM | #44 |
I was pretty excited when I discovered some folks took the time to create an index for the assembly manual (many thanks!), but the bummed to find out my copy of the manual does not have page numbers!
Mine also has most part numbers removed, which sucks, but that's another story. In any event, am I alone in this or do other people number theirs by hand? That'll take some time. If there's a PDF version around, I'd be pleased if someone would PM me a link. I already bought the book, so I'm not trying to pirate it, just trying to be able to find stuff in it! At least with a PDF I could "jump" to page location instead of numbering all 1064 pages by hand... Thanks! Dave
1970 GMC Sierra Grande Custom Camper - Built, not Bought 1969 Pontiac 2+2 427/390 4-speed Coupe 1969 Pontiac 2+2 427/390 4-speed Convertible |
08-02-2012, 01:06 AM | #45 |
Never mind, I numbered them... all 1064 pages of it! Well, the odd ones anyway.
The reprints of these are sure bad... I have an Impala one that seems to be original or at least a lot older and its half-way organized, calls out most part numbers, and so on. I wonder if GM placed some restrictions or it was just a sloppy copy?
03-10-2015, 01:08 AM | #46 | |
Any way to add the header back in or at least list what each column header should be? |
03-10-2015, 09:26 AM | #47 |
The Older Generation
The CD version has a search feature to look stuff up. Makes it really easy and you can print pages from it.... Just a heads up for the lazy people like me... I applaud you guys for doing this though, quite an undertaking... LockDoc
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 03-10-2015 at 10:35 AM. |
03-10-2015, 01:36 PM | #48 |
does the CD version have the part numbers?
07-18-2016, 07:30 PM | #49 |
Thanks for making my assembly manual useful!! You guys rock.
10-07-2016, 05:03 PM | #50 |
I purchased an assembly manual and see what everyone was stating about how it lacks an index.
I am getting an error message to the link and this spreadsheet for the assembly manual for 1967 to 1972 C10 trucks. Is there a new pathway link or do I need permission to gain access to the index that helps decipher the incomplete harcopy Manual. Thanks for any help and to you guys for updating an index. Sam |
