Old 08-07-2010, 09:12 AM   #1
kcfirstbuild
HOw to center the rear axle ?
Im slowly putting in a 2/4 drop on my 68 c10 lwb. I was wondering how you center the rear axle back up with an adjustable panhard bar. I do have to bed off right now would, do i have to have that on in order to have to the correct amount of weight ?
kcfirstbuild is offline   Reply With Quote
Old 08-07-2010, 09:28 AM   #2
cdowns
cdowns's Avatar
Re: HOw to center the rear axle ?
no need for bed really just have it sitting static measure the difference how far tires r away from frame rails and adjust bar to make tires equidistant from frame rails// a pretty much common sence type of adjustment
i use tyedown ratchet straps to pull rear in desired direction to center it
Old 08-07-2010, 09:47 AM   #3
Andy4639
Old member
Andy4639's Avatar
Talking Re: HOw to center the rear axle ?
What he said!
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
