Old 08-09-2010, 05:00 PM   #1
808humbo1
Trans Question.....
Will a 350 tranny bolt to an inline 6? or better yet.....i have a 5 speed (dont know what type of tranny) w/granny gear and want to convert to an automatic.....what trannys will work for me? Thanks!
No Grumbo Be Humbo
808humbo1 is offline   Reply With Quote
Old 08-10-2010, 12:20 AM   #2
Captainfab
60-66 Nut
Re: Trans Question.....
Yes a TH350 will bolt up to an I6 engine as long as it's a 230,250, 0r 292. You will have to remove the bellhousing crossmember, change the flywheel for a flexplate, change to a different starter, add a transmission cooler, and shorten your driveshaft. I'm sure I've forgotten a thing or two, but that's the basics. So you have a 5 speed in your truck now? If so that isn't stock. What year is your truck?
Old 08-10-2010, 10:45 AM   #3
vin63
It's Better With Nitro
vin63's Avatar
Yes, as mentioned the 194 through 292 blocks have the same trans mount...the only thing to keep an eye out for on on the trans bellhousing is for the BOP (Buick, Olds, Pontiac) pattern that appears to have a large dip on the top that accommodates the two higher trans bolt locations of those blocks.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 08-10-2010, 01:55 PM   #4
808humbo1
wow....i thought it would be a simple bolt on process and shorten the drive shaft.....hahahaha......i have a 62 LB. and yeah, i have a 5 speed on the floor with granny 1st. i really want to convert to automatic so the wifey can drive. where can i find all those other parts i need?
No Grumbo Be Humbo
Old 08-10-2010, 02:22 PM   #5
Heater63
Heater63's Avatar
It would be easier just to teach her to row gears. Oh, wait. No, it
would be easier to swap transmissions. If she's like mine that is.
292 + TKO500
Heater63 is offline   Reply With Quote
Old 08-10-2010, 07:03 PM   #6
raycow
If your 62 has the original engine, it's a 235, and a TH350 will NOT bolt up without an aftermarket adaptor plate. If you don't know what engine is in there now, count the valve cover screws.
Ray
raycow is offline   Reply With Quote
Old 08-11-2010, 01:15 AM   #7
Captainfab
60-66 Nut
This is puzzling to me. If you have a 5 speed with a granny 1st gear, I'm wondering what engine you have. A 4 speed with a granny 1st would be the common trans.
Old 08-11-2010, 08:25 AM   #8
raycow
5 speeds were available on the big trucks going back at least into the 50s. Look for names like Clark, Fuller, and Spicer. These will bolt to a 235 using stock parts, so it is certainly possible to put one in a pickup. They are huge and heavy though, so it is hard to make a good case for doing the swap.
Ray
Old 08-11-2010, 03:23 PM   #9
808humbo1
Ray
where can i get an adapter plate from? are they easy to find? pricey? thanks. oh and how many screws should there be for it to be a 235?
No Grumbo Be Humbo
Old 08-11-2010, 04:16 PM   #10
raycow
Here ya go.
http://www.stoveboltengineco.com/aca...?productid=168
350 bux plus the cost of a new starter.
A 54 or later 235 will have 4 screws around the edge of the valve cover. Earlier engines have 2 studs going through the center.
Ray
