Old 08-09-2010, 05:53 PM   #1
72-c20
Packrat
72-c20's Avatar
TH350 trans. changed fuild, filter, pan gasket. now shudders.
changed the trans filter and pan gasket. new fluid.
right after starting, it will shudder if I shift into D or R and move the truck slowly...
if I let it warm up, it seems fine, thought it does seem to have harder transitions between gears.
I checked the fluid, and it's not low.
thoughts?
gone: --'07 Tahoe LTZ 4WD
--'68 Firebird 400 Convertible
gone: --'72 Chevy K20
72-c20 is offline   Reply With Quote
Old 08-09-2010, 06:15 PM   #2
grs
Re: TH350 trans. changed fuild, filter, pan gasket. now shudders.
Did you check the fluid when it was hot? And do you have the correct dip stick?
grs is offline   Reply With Quote
Old 08-09-2010, 06:43 PM   #3
72-c20
Packrat
72-c20's Avatar
yes, checked when hot. it's the original dipstick.
Old 08-09-2010, 06:47 PM   #4
camjck89
camjck89's Avatar
mine did that when i first got it the kick down was loose and i rebuilt the carburetor. haven't had a problem since, except i have to stand on the manual brakes to keep it from taking off.
72 lwb farm truck 86k o.g. miles.
350/th350
89 toyota 3" drop 22r 4spd 2wd
camjck89 is offline   Reply With Quote
Old 08-09-2010, 06:52 PM   #5
72-c20
Packrat
72-c20's Avatar
hmmm. my kickdown cable isn't attached. it's been disconnected for as long as I've had the truck.... carb was rebuilt less than 1000 miles ago.
vac lines look okay. has new brake booster and MC too...
Old 08-09-2010, 09:44 PM   #6
68K30
Possible loose filter screws or missing or out of position filter gasket, I have overhauled several of these that customers diagnosed themselves and this was the problem.
68K30 is offline   Reply With Quote
Old 08-09-2010, 11:18 PM   #7
72-c20
Packrat
72-c20's Avatar
when I take my foot off the brake pedal, it's slow to "release"...
Old 08-10-2010, 02:01 AM   #8
Indyuke
This might make me sound stupid, but did you check the level with the truck running?
Indyuke is offline   Reply With Quote
Old 08-10-2010, 10:07 AM   #9
72-c20
Packrat
72-c20's Avatar
Yep. I'm gonna try and check all the vac lines again too. Just seems weird that my braking seems involved..
Old 08-10-2010, 11:07 AM   #10
Sinister
Between Trucks...
Sinister's Avatar
Put it into all the gears with the motor running. P R N D 2 1. Let it sit for a moment in each gear with your foot on the brake, then check the fluid level again.
Beat it to fit,
Paint it to match...
Sinister is offline   Reply With Quote
