LS fuel filters?
Hey Guys,
I was wondering what your fuel filter setup looks like? Will you please post up if you are running a pre and post filter? I plan on using my Walbor 255 with a pre and post filter, but I have no idea which pre and post filter I should be using. David |
![]() Join Date: Jun 2007
Re: LS fuel filters?
Does your fuel rail have 1 or 2 lines? If it has 1 most use the covette filter regulator. As for a pre filter I am not running one but am interested in the replies.
Click on my Not really a build thread, yet NOT SO RUST FREE RUST FREE BLAZER LS ENGINE SWAP INFORMATION THREAD BOLT RESTORATIONS 4l60 to an NP205 |
I have two lines on the drivers side.
![]() Join Date: Dec 2008
This is the link to the post filter I just perchased I havent decided on a prefilter yet http://www.jegs.com/i/JEGS/555/150070/10002/-1
It's -8 an & I'm running 1/2 feed, 3/8 return |
Here is mine....corvette fuel filter/regulator hooked to a LS1 Trans Am fuel tank mounted backwards.
I'm using an Earl's 40 micron pre-filter and Vette style post filter/regulator.
I've read you shouldn't use much more than a 40 micron pre-filter, or you can choke-out the pump too much. Don't know if it's true, but it sounded reasonable to me, so that's what I did. Some pics of the filters and Walbro inline are in this thread: http://67-72chevytrucks.com/vboard/s...d.php?t=412762 Last edited by Jim_PA; 08-11-2010 at 12:03 AM. |
I found out that aeromotive suggest that people run a 100 pre-filter and 10 post filter. You can find this info on their website.
| Bookmarks |
| Thread Tools | |
| Display Modes | |
