Old 08-10-2010, 10:30 PM   #26
deepnsteep
Re: Lift Pics
Originally Posted by blakeduren View Post
The front shackles are factory ones.
The sway bar does have a bit or correction, but it still not parallel yet.
The Draglink has quite an angle to it. That is one of the main reasons for the poor driving. I'm surprised it doesn't have a dropped draglink or a dropped pitman arm with 8 inches of lift. Most front 8 inch springs will ride rough though.
That truck is so clean compared to our "rust-belt" trucks around here!
It has this pitman arm...
So seeing that even with lift springs in the front w/ stock shackles the shackles are nearly touching the frame, wouldn't it be a good idea to get longer shackles for the front?
Because on my stock suspension the front shackles are nearly touching the frame too...
It looks like the springs do hit the frame occasionally...the powder coating is a little marked up.
deepnsteep is offline   Reply With Quote
Old 08-10-2010, 10:40 PM   #27
mooseknuckles
mooseknuckles's Avatar
Re: Lift Pics
Originally Posted by deepnsteep View Post
This is what I just got home and I do not like the lift/tires it has. It has 8" suspension plus 3" body and 38"x15.5" Toyo M/T's. It drives like crap! This will be my driver and I need it to be practical and still look good...
I'm a little worried that 4" lift with 33" tires will look a little awkward.
Thanks!
Levi
I think you bought the wrong truck to be your driver......not very practical at all, but man is it awesome!
mooseknuckles is offline   Reply With Quote
Old 08-10-2010, 11:28 PM   #28
Blue Chevy 1987
Blue Chevy 1987's Avatar
Re: Lift Pics
that is a stock pitman arm. looks like you have a raised steering arm. id at least get a drop pitman arm an htat might help some. take the swaybar off. your leaf springs are like mine an have the shim built onto them. im not sure how to cure the rubbing issue but if you put longer shackles on it you could create more iaaues
Blue Chevy 1987 is offline   Reply With Quote
Old 08-10-2010, 11:29 PM   #29
trixter99
I have no time for this
trixter99's Avatar
Re: Lift Pics
If you are looking to make a lifted truck drive well you had better get over that thought. I have had lots of lifted trucks and driven tons more and none of them drove great,You just have to get used to it wandering a little. I personally do not care how a vehicle rides or drives as long as it was built well and looked cool as hell and you have a very cool truck. And I would not take the sway bar off if you are worried about how your truck handles, it will suck with out it. PS my wife used to drive our last 86 lifted eveywhere rain or shine summer or winter on 37 12.50 super swampers.
1986 Chevy short box ( PROJECT )
1994 Chevy Blazer lifted 6"
2009 Gmc 2500 HD
1999 Hugger orange Camaro SS
2007 BMW X5 Sport
trixter99 is offline   Reply With Quote
Old 08-10-2010, 11:34 PM   #30
JHT67
JHT67's Avatar
Re: Lift Pics
some dropped pitman arms, long link, I know.....
http://www.google.com/products?clien...ed=0CDoQrQQwAg
Didn't show up as long.
JHT67 is offline   Reply With Quote
Old 08-11-2010, 12:51 AM   #31
jimmy3fan
jimmy3fan's Avatar
Re: Lift Pics
4 inch lift with 33's
jimmy3fan is offline   Reply With Quote
Old 08-11-2010, 08:35 AM   #32
deepnsteep
Re: Lift Pics
Originally Posted by 78 Chevyrado View Post
Are those raceline wheels? What size are they? They look just like the 18's I bought for my C20.
Mine are Weld Cheyenne. They are 18x12.5 and for sale on Wyoming CL...
Your truck looks great...that's pretty much the look I'm going for!
Thanks for all the input!
Levi
Old 08-11-2010, 09:36 AM   #33
sdailey
The Few, The Proud
sdailey's Avatar
Re: Lift Pics
Not a crew cab, but here's my old '87 with a 2" lift running 33's.
Shannon
sdailey is offline   Reply With Quote
Old 08-12-2010, 05:52 AM   #34
chevymadness
Re: Lift Pics
Thanks!
Levi
man that trucks looks really good what are you thinking no that lift looks great and 33 tires are perfect i actually getting 33s that paint job is sweet what a great truck how much you pay for that i wouldnt change a thing
chevymadness is offline   Reply With Quote
Old 08-12-2010, 05:54 AM   #35
chevymadness
Re: Lift Pics
very nice i was thinking to get a 7 inch or so lift but i think i should get this exact set up 33s aswell looks really good and normal for everyday use then a lifted truck so high even tho im in tx great truck im just buying a truck just like this a 83 long bed
Old 08-12-2010, 05:59 AM   #36
chevymadness
Re: Lift Pics
Thanks!
Levi
oh and forgot to say if you dont want them tires i like them alot so if your maybe thinking about selling them or something holla at me im just getting a chevy and need some treds those look nice and rims aswell
Old 09-02-2010, 01:44 AM   #37
LowBurbAZ
Re: Lift Pics
First what you are going to need to do is get some lift shackles to give you truck the additional flex that it needs up front. Your front stock shackles are going to make contact with the frame when ever it flexes. That will make the ride harsh cause your hitting the frame. You only need an extra 1-2" which will raise the ride height the from 1/2-1" up front. http://www.hill4wheeldrive.com/shackles.html
Secondly, it's hard to tell if you have the lifted steering arm. If you do it's only good for 4-6" lift. If not get one and you will want to add a lift draglink to that combination as well. The draglink will give you another 4" of lift to get you to your 8" lift and should put your steering geometry back in spec.
Or you can go the more costly route and go with crossover steering. It will function much better but will require more modifications to the steering and suspension than you may not want to make.
LowBurbAZ is offline   Reply With Quote
Old 09-02-2010, 02:31 AM   #38
355bullet
355bullet's Avatar
Re: Lift Pics
4inch with 33's 3.73 gears
i dig it,. barely fits in the downtown parking garage..
355bullet is offline   Reply With Quote
Old 09-04-2010, 09:40 AM   #39
dman1982
dman1982's Avatar
Re: Lift Pics
heres mine...i got 35's and a four inch rough country lift. and i got a pic of my tire...my boy loves them. lol
dman1982 is offline   Reply With Quote
Old 09-04-2010, 03:54 PM   #40
355bullet
355bullet's Avatar
Re: Lift Pics
he's on the right track!! lol!
Old 09-04-2010, 04:12 PM   #41
dman1982
dman1982's Avatar
Re: Lift Pics
he sure is!!! i cant keep him outta the garage or outta my tools..he gets pi@@ed when i take him back in the house lol
Old 09-04-2010, 04:57 PM   #42
b454rat
Re: Lift Pics
You need to go crossover steering. If that truck was a 1 ton originally, it has a taller frame than 1/2 and 3/4 tons do. So whatever lift springs you put on, say 4", the truck will have 6" of lift. The frames are about 2" taller on a 1 ton.
My old truck didn't have a swaybar on it, and drove fine. My crew doesn't have one either, and not gonna put one on. So I can't take an offramp at 70, big deal. Only thing I noticed was a little body roll. Not enough to worry bout IMO.
2000 GMC CCSB 454/4L80 6” lift SAS
1999 Chevy CCSB 454/NV4500 4” SAS
1999 GMC Yukon 350/4L60 6" SAS
Old 09-04-2010, 07:41 PM   #43
gafiredog
Re: Lift Pics
Thanks!
Levi
is that red late model g.m. red?? its a very nice shade. do you have the color code ?
Art
1975 c-10 stepper
1978 single cab dually
1987 crewcab dually
1986 crewcab single wheel
1948 anglia- (the dixie twister super gas)
gafiredog is offline   Reply With Quote
Old 09-05-2010, 01:36 AM   #44
BigRed76
BigRed76's Avatar
Re: Lift Pics
How does it ride with those mud terrains?
And how does the rough country lift ride?
Zach
1970 Chevrolet Custom Camper K20
1971 GMC Super K2500, 12V/NV4500 swap in progress
1971 Chevrolet Custom C10
1972 Chevrolet Custom Deluxe C20, 5.3/4L60E
1972 Oldsmobile Cutlass Supreme, 455/TH400, 3.73 posi
2004 GMC Sierra 2500HD, LB7/Allison, CCSB
2005 GMC Sierra 1500, 5.3/4L60E, CCSB
BigRed76 is offline   Reply With Quote
Old 09-05-2010, 08:31 AM   #45
dman1982
dman1982's Avatar
Re: Lift Pics
well...i still need to put new sway bar bushings in it...but it rides ten times better than it did before, but my front springs were shot and it needed shocks. but those mud terrains ride really well. and they dont hum down the highway at all...really really queit. and they have alot of bite...i was pulling out some little trees in my back yard the other day...good times..lol id really recommend them. great tire...and the lift was pretty easy to put on. i did it in a couple days after work in my driveway.
Old 09-05-2010, 12:33 PM   #46
Patriot
Re: Lift Pics
Are those factory 8" wheels. MAN that looks nice!!!
Patriot is offline   Reply With Quote
Old 09-05-2010, 01:19 PM   #47
BigRed76
BigRed76's Avatar
Re: Lift Pics
Very nice. My truck rides like a tank too cuz my front springs are shot as well as the shocks. And people have always told me that rough country lifts ride really rough but i've never had a reason to believe it.
And did you have to get extended brake lines?
Zach
Old 09-05-2010, 02:16 PM   #48
dman1982
dman1982's Avatar
Re: Lift Pics
ya its amazing what the front springs will do...and the steering stablizer...havent got the extended brake lines yet but i am very soon...it cuts it real close with a 4 inch lift and the brake lines...i havent been able to go off road yet...but as soon as i get those brake lines im off to the mudd!!!! the rough country isnt too bad...got to remember these trucks have the straight axles and not the independent front suspension...but compaired to what it was before i got the truck...huge difference...even my ol lady notices...she said still bumpy tho...i can live with that lol
Old 09-05-2010, 09:22 PM   #49
Mr Pops
Ridin' Dirty
Mr Pops's Avatar
Re: Lift Pics
Here's 6" with 35's
1978 C3500 Crewcab (Project)
1979 C2500 Crewcab (Driver/project)
1988 R2500 Crewcab (Driver)
1988 V3500 Crewcab
1988 R2500 Crewcab (Mint, Ex Fire Dept)
1968 Chev Suburban (4x4 conversion) LINK
1970 Chev C20 Suburban (driver/cruiser)LINK
2005 Impala (Incognito vehicle)
2004 Yukon XL Denali (Kid hauler)
1947 Case tractor
Facebook Page(1000's of pictures of GM cars and trucks organized into albums)
YouTube Channel
Mr Pops is offline   Reply With Quote
Old 02-15-2011, 02:34 AM   #50
chevymadness
Re: Lift Pics
hey man was up im about to get 4 INCH ROUGH COUNTRY suspension also do they flex are they great suspensions what can you say about them looks good nice truck
1982 chevy silverado
It's all about original guys original let me say again original.
