New Member
trimming lower control arms
Hey guys im sure this has been asked a thousand times,so ill ask once more,i need to trim my lower control arms but i need to know where and how much is safe,i really appreciate any help.
BMW & ASE Master Certified
Re: trimming lower control arms
In my experience, I will never do it again. I trimmed the front lower control arms so I could run Centerline 15" wheels... after say 2 months control arm failed on the freeway and I went from the far right lane, 3 lanes over into the conrete wall... wasnt hurt that bad... somehow I missed everyone, Someone was watching over me that day I tell ya. Just fatigued due to trimming too much off the "rain gutter". I would rather buy a spacer of some sort, or just get bigger wheels.
clint
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes 1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD A poor man buy's it twice finally got my domain name back, 87chevy.com.... site rework in progress |
#3 | |
think we used a grinder... I think the problem was they were 3" drop spindles on aluminum wheels and it required to chop a lot of the gutter material... that gutter material is what gives the ball joint area its strength... thats where it failed... essentially bent the metal back and fourth untill it let go.
clint
67-72 parts collector,…
![]() Join Date: Nov 2002
I've trimmed every 67-87 lower control arm on every truck I have lowered.
(My trucks and others) Never had a failure of any kind. I've done this mod since the 1980's.
The area with the blue masking tape has already been trimmed.
The last picture is a stock "un-trimmed" lower a-arm, with the area "to be trimmed",... marked in red.
Happy to be here
![]() Join Date: Mar 2000
I have trimmed several sets with no issue, but I have also heard of them cracking. My solution was to trim as needed then add a boxing plate on the bottom. After that I came up with the best solution in my opinion. I no longer wheels small enough to require the arms to be trimmed...
I had no choice but to trim mine they were rubbing into the bead on my tire, the first time I drove it thy peeled off my wheel weights!
GM Addicted
??the picture with the red markings is the area that can be trimmed off correct??
![]() ![]() 73 GMC, 54 Caddy, 2010 Silverado, 68 C10 RIP DAd My 73 GMC Truck Build Pic 2010 Silverado 4/6 on 24s IG:MacsGarage |
#10 | |
I also trimmed that area on my son's truck a few years ago. At each oil change we rotate the wheels, and check the area for signs of failure. So far so good.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
#12 | |
You still have to check for clearance issues. Set the truck on the ground after trimming, and turn the wheels in both directions to verify that no part of the a-arm will make contact with the wheel.
Tot Roddin'
Here's what you'll end up with...
-Nate ![]() 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
GM Addicted
i was going to completly cut off the bump stop and the metal, would that be a bad idea. Basically cut off the rest of what is showing on the picture above. Going with bags.
#15 |
The only part I leave is the "steering stop" for the spindle.
Some people remove all of it.
#16 |
Kill Bill...et
Not to jack this thread, but did any of you have trouble with the LCA clearing the disk break dust shield? And yeah...I was also wondering about the question above with the steering stop.
#17 |
Some do clear, some don't. It's easy enough to tweak or trim the 'shield' for clearance if it interferes.
#18 |
gets board easy.......
u normaly grind the stop off also, i like the travel
#19 |
Grinding the stop off only increases the problem if the wheels rub. Once the stop is gone, you have to remove more material because the steering arc will slightly increase (close to, or in bind).
#20 |
#21 |
vw guy & now c-10 guy
![]() Join Date: Sep 2008
I cut the stops off completely on mine, but even with the 5.5" lowering and 15x7 steel wheels, I didnt have to take off any of the lip- I guess it really depends on the backspace of the wheel...
#22 |
Yep.
Usually a 15" wheel with more that 3.75" of backspacing,... will require a trim.
#23 | |
Read my statement again.....
#24 |
GM Addicted
well i looked at my truck and with the wheels fully turned nothing hits the stop, so im thinking just taking it all off.
#25 |
Very nice thread guys, thanks for the info and pictures.
