#201 |
Daring to be Different
Re: Tommys66 Build
It's coming out really nice. I bet you can't wait to drive it.
Dennis ![]() http://www.67-72chevytrucks.com/vboa...d.php?t=327644 KUSTOM RIDES FACE BOOK PAGE: https://www.facebook.com/groups/291198124258863/ 1965 C-10 Short Bed 350/700r4 2012 Silverado 1500 Crew Cab 2016 Honda Accord w/ 18" rims 2007 Honda Goldwing Trike w/ NAVI 2001 Yamaha Roadstar Indian look alike "Life's journey is not to arrive at the grave safely in a well preserved body, but rather to skid in sideways, totally worn out, shouting "...WOW!...what an amazing ride!" Live Life Passionately!!! [/COLOR] ![]() I AM WE TODD IT, I AM SOFA KING WE TODD IT |
#202 |
SSN 706
Re: Tommys66 Build
Looks great. Your really getting it done. I cant wait to paint somthing. I see you still have that one wire still in the wrong spot.
![]() ![]() ![]() ![]() ![]() ![]() ![]() Last edited by daverod; 08-12-2010 at 10:47 PM. |
#203 |
Re: Tommys66 Build
been working on my wiring harness. I bought a 18 circuit harness from hot rod wires, and a relay kit from current performance for under hood circuits.(fans, horn, fuel pump, power to engine harness). I am open to any questions for the wiring, but I do not plan to give a detailed description of the install. Most of my information was gathered from lt1swap.com
I love the smell of lead paint! |
#204 |
Re: Tommys66 Build
thats for sure
#205 |
Re: Tommys66 Build
thanks, it was awesome to finally see some color on it!
#206 |
Re: Tommys66 Build
I used Hot Rod Wires on a 63 Studebaker recently. I hated them. I wish I went with Easy Wires. How do you like the Hot Rod Wires so far?
#207 |
Re: Tommys66 Build
[QUOTE=Strodder;4192513]I used Hot Rod Wires on a 63 Studebaker recently. I hated them. I wish I went with Easy Wires. How do you like the Hot Rod Wires so far?
Well I thought the instructions were crap...I realize it is a universal harness, but there was very little direction. Besides that it was complete with everything i needed. I do think the EZ harness is comparable, and alot cheaper. I bought the hot rod harness on impulse at a swap meet though.
#208 |
Re: Tommys66 Build
Got my gauge panel built, minus the led indicators...I used the original face plate, drilled the holes with a hole saw, and covered it with a vinyl film from oreillys. As for the outer bezel, I bead blasted it, then slightly polished with never dull. the finish looks like brushed aluminum.
#209 |
60-66 Nut
Re: Tommys66 Build
That turned out very nice
#210 |
Senior Enthusiast
Re: Tommys66 Build
That looks great!
#211 |
Re: Tommys66 Build
I like the Carbon Fiber.
#212 |
Re: Tommys66 Build
here is how i mounted the PCM. I cut the bottom off the original mount and made some angle brackets to bolt it to the fender.
#213 |
Re: Tommys66 Build
Got a brake booster and master cylinder assembly from a late model silverado. I have 4 wheel disc brakes, so this set up should work well. I hope I have it laid out right!
#214 |
60-66 Nut
Re: Tommys66 Build
Looking good
![]() When you say late model Silverado, do you know what year it was?
#215 |
Re: Tommys66 Build
I believe from 99-06 are the same. In 2005 GM went back to drum brakes on the rear, but the difference is in the proportional valve.
#216 |
Hey Y'all!!
Re: Tommys66 Build
Still doing some nice work Tommy. Keep at it!!
Just hopin' I live long enough to finish something!!! |
#217 |
Re: Tommys66 Build
got the brake booster/master cylinder mounted, and all the brake lines ran. I used a prop valve from a 04' tahoe with 4 wheel disc.
#218 |
Re: Tommys66 Build
Installed the gauge panel, and steering wheel. Im not sure what the steering wheel is off of, I picked it up at a swap meet.
I also had the inner fenders powercoated super wet black....nice shine!
#219 |
Re: Tommys66 Build
Wow, Truck looks like its coming along really nice. I like how all of your work makes the truck look like it came from the factory that way. Wish I had the time and money to do mine like that. Way to go.
#220 |
![]() Join Date: Nov 2009
Re: Tommys66 Build
Doing an awesome job!! I may have to find one of those steering wheels, I like the look.
#221 |
Re: Tommys66 Build
thanks, If I had the money it wouldn't take as much time!
#222 |
Re: Tommys66 Build
yeah, it seems like it fits the truck good, just not sure what its from.
#223 |
Re: Tommys66 Build
Looken good Tommy
#224 |
Grandpa in the rustmobile...
Re: Tommys66 Build
Wow, good work, looks factory!
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
#225 |
Re: Tommys66 Build
I think it is off if a newer model Chevy Cavalier or Monte Carlo.
