Addicted to Rust
![]() Join Date: Dec 2009
I got a good jump on the install today. I am using motor mounts from Welder Series. Paul sold me a ls155d and the pass side mount from a ls104 kit. That gives me the "Fred" style mounts. They fit the block well but I had to countersink two of the holes on the pass mount as the stock shell wouldf mot clear the mounting bolts.
![]() ![]() I am going to have to trim the frame for compressor clearance though. I suspect that the 3\4 ton frame has a thicker cross section and the compressor will not quite go in between the mount and the upper frame lip. It also would not go in with the compressor installed. I hope by trimming this sweep in the frame on the engine side of the tape it will give me enough clearance to get it in. ![]() ![]() I also need to lightly trim the upper part of the frame to let the pass motor mount stand sit down flush with the upper frame rail. I probably cam sand enough of it off to make it clear. ![]() I will also have to notch the frame for exhaust manifold clearance on both sides as they barely touch. I also have a new set of GTO manifolds but the drivers did not clear the motor mount. Just as an FYI the GMPP muscle car pan kit (Colorado, Hummer pan) has a different bell housing pattern on the bottom letting you only use on of the bottom bolts of course I am sure that seven bolts will hold it just fine. ![]() Jay
Current trucks: (48 GMC100 320 inliner) Gone (48 Suburban in pieces) Sold 87 GMC CCSB 5.3 4l60E Daily Driver ECTA National record holder XO/PP We never really grow up, we just learn how to act in public. |
Re: Some Progress Some Setbacks
Wow...looks like you're diggin' deep into this project. Thanks for the heads-up about the GMPP kit. I was about to buy one of those for my new project, but I think I'll stick with what I got(regular truck setup).
1982 Silverado - SBE, cleaned up GM heads, small cam, TH350, 850 Demon, 4.56 gears, and caltracs. Best time so far 11.8@XXXMPH |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
