Old 08-13-2010, 07:30 AM   #1
jondancer
upper and lower side mouldings...
does anyone ever two way tape on there side moldings? i dont really wand to drill any holes, but like the way the upper and lower moldings look running the full length of the truck.
thanks
jondancer is offline   Reply With Quote
Old 08-13-2010, 08:09 AM   #2
Zoomin
Man of Mini-Talents
Zoomin's Avatar
Re: upper and lower side mouldings...
There's no reason it wouldn't work. Get the good 3M automotive stuff.
Zoomin is offline   Reply With Quote
Old 08-13-2010, 11:40 AM   #3
copywritten
CopyWritten
copywritten's Avatar
I agree, most of the late model Chevy mouldings were taped on from the factory
copywritten is offline   Reply With Quote
Old 08-13-2010, 11:57 AM   #4
blime81
Laid Lo
blime81's Avatar
Check out Hart_Rod's SuperBurb build. I'm pretty sure thats how he did it.
http://67-72chevytrucks.com/vboard/s...d.php?t=200387
Semper Fi,
Jeff
'72 C10 - lays frame
'07 Sand Rail - ecotec powered
'05 2500HD - tows stuff
'67 VW Bug - gas saver
'01 Jeep TJ - rock crawler
blime81 is offline   Reply With Quote
Old 08-13-2010, 10:28 PM   #5
Zoomin
Man of Mini-Talents
Zoomin's Avatar
Ran across this tread: Link
Old 08-13-2010, 10:57 PM   #6
jondancer
thanks guys
Old 08-13-2010, 11:24 PM   #7
highliner
highliner's Avatar
Mine had moulding from the factory, but because most of the hardware is impossible to reach without disassembling the fenders, I put the little bolt and nut clip front and back and taped the rest. Be sure to use the dark exterior tape. It's a lot thinner and less noticeable than the regular white stuff.
72 C-10 Longbed (3rd generation truck)
79 K-15 Shortbed SBC400 4in. lift super swampers
05 2500HD Crew 6.0L
39 International P/U (future rat rod)
highliner is offline   Reply With Quote
Old 08-14-2010, 07:20 PM   #8
mbgmike
If you are in a hot climate the tape my or may not work. The tape that is sold over the counter usually is not the tape the oem's use. We have found that we have to use adhesive to get them to stay on permanently around here. their is tape you can use but its not the stuff you buy at auto parts stores. get the VHB stuff from 3M not the auto store stuff it will hold sheetmetal together.
mbgmike is offline   Reply With Quote
Old 08-14-2010, 07:25 PM   #9
leddzepp
Moderator
leddzepp's Avatar
I have used 3M outdoor double sided tape. It works well, but it does not pull the mouldings in tight to the body like the metal clips.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 08-14-2010, 07:29 PM   #10
vectorit
What?
vectorit's Avatar
Agreed.. I tried this with a small piece of trim on my burb, and it couldn't survive car washing if it's life depended on it. Ended up just taking it off.
Chris
1968 K20 Suburban
1972 K10 LWB PU
vectorit is offline   Reply With Quote
