Old 08-13-2010, 02:14 PM   #1
blazed870
Lowered and Rally wheel questions
I found a guy that has 2 15 x 10, 2 15 x 8, and 2 15 x 7
He has new tires on the 8's and 7's and would sell all four for $500 or he will sell each wheel, without tires, for $50.
Is that a good deal or is it kind of steep?
Will I have issues with running the 15x10's on the back or the 8's on the front?
I just have cut springs up front now, but I plan on running the 2.5" drop spindles and either 4" springs or air bags.
blazed870 is offline   Reply With Quote
Old 08-13-2010, 02:17 PM   #2
blazed870
Re: Lowered and Rally wheel questions
And now a questions on tires..
What would be good tire size combos for either the 10's in the back and 8's in the front or the 8's in the back and 7's in the front?
I noticed alot of people run the BF Goodriches, so I am guessing I will probably go with those unless there is another brand that is good.
Old 08-13-2010, 02:29 PM   #3
70cst
70cst's Avatar
If your front end is lowered you might run into rubbing issues. My truck did as I had 2" drop spindles installed. I think it was the control arm that I was hitting on turns. Then again...others have had no issues with Ralleys Wheels on a lowered truck. Good Luck.
A husband can be right...or...A husband can be happy.
67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk.
1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc
JOHN 17:3...The better side of "LIFE"
Remember: Everyday is a good day...Some are just gooder!
70cst is offline   Reply With Quote
Old 08-13-2010, 03:22 PM   #4
Jack_71C10
Shortbed club member
Jack_71C10's Avatar
I'm running 15x8 rallys on all four corners with a 4/6 drop.
I have no rubbing issues. But I wish I had 15x10s in the rear.
71 custom/10 6.0/4L80E SWB ece 4/6
72 custom camper 350/3 spd
2020 Chevy Express 3500
2023 Hyundai Tuscon
1986 GMC 3500 Bucket Truck
Sent from my Rotary Phone via 14.4kb/s modem.
Jack_71C10 is offline   Reply With Quote
Old 08-13-2010, 03:27 PM   #5
Shane
Shane's Avatar
10" truck rallies were never available from GM ... make sure he is measuring the INSIDE of the bead rim ... NOT the outside. If they are truly 10" then they are aftermarket.
GM offered the truck rallies in 8" ... 7" ... & 6 1/2" widths.
Shane is offline   Reply With Quote
Old 08-13-2010, 05:29 PM   #6
blazed870
Thanks Shane for the info. I don't think he was trying to say they were original, he just had these and now has gone to 20" wheels.
Anyone know if I will have clearance issues with the 10" in back?
Old 08-13-2010, 07:27 PM   #7
POPO1984
POPO1984's Avatar
Probably depends on the backspacing I think it needs to be about 4 1/2 inch backspacing
1972 SWB Medium Olive
South Houston
Instagram: Antbish84
POPO1984 is offline   Reply With Quote
Old 08-13-2010, 08:01 PM   #8
Southcity
Southcity's Avatar
You need to speak to member "Bob 68327", he is running a setup just like this or at least very similar and he can most likely provide some good info. I'm sure if you PM him he'll provide some good info and pics of his rig.
66 GMC Suburban Custom
66 Chevy K10 Suburban
Southcity is offline   Reply With Quote
Old 08-13-2010, 08:18 PM   #9
70cst
70cst's Avatar
Very good point.
