Old 08-16-2010, 02:49 PM   #1
stevieB
stevieB's Avatar
got the notches put in!
havent really worked on the truck in awhile but in the last two weekends, i upholstered the dash and door panels, lowered the front 2.5 and did a flip in the back, but my biggest acomplishment was building the notches for the back.
stevieB is offline   Reply With Quote
Old 08-16-2010, 06:48 PM   #2
Davidmichael
Davidmichael's Avatar
Re: got the notches put in!
Did you do a rear flip yourself, or did the kit not come with the notches? Or something else?
86 Suburban 2WD = rolled it and totaled it
83 LWB STD Cab 4x4 = went to the scrapper. Was my baby.
84 Suburban 2WD = stripped it/ scrapped it
81 8 foot bed made into a trailer
86 Suburban going to be made into a trailer
91 Suburban 4x4 = that's my baby
00 S10 Xtreme STD Cab
01 S10 ZR2
Davidmichael is offline   Reply With Quote
Old 08-16-2010, 06:57 PM   #3
stevieB
stevieB's Avatar
well I bought a flip bracket off ebay and installed it, then I a 12"x12" 1/4" plate and a piece of 5" diameter pipe. and cut it in half. I wanted to bolt them in, because I will probably want to go lower later so I can just take those out easy and build a step notch. all in all about 50 bucks. oh and i got drop shocks from CPP for 40 bucks for the pair. So about 90 bucks for the back.
Old 08-17-2010, 10:51 AM   #4
stevieB
stevieB's Avatar
got some more pics.
Old 08-17-2010, 10:55 AM   #5
OARNGESI
OARNGESI's Avatar
great looking blazer another inch down in the front it will be perfect
70 SWB STEPSIDE
70 BLAZER
09 challenger
OARNGESI is offline   Reply With Quote
Old 08-17-2010, 12:27 PM   #6
kevinr1970
Could be mistaken, but I don't think anyone makes one for the K5's.
Didn't understand why until I saw the pictures posted above...
2009 Honda Fit CfC (bsf 44.9 mpg)
2000 Tahoe Limited
1991 GMC CrewCab Dually 2wd, will end up swb, not dually and replace CCswb below
1991 GMC CrewCab Dually 4x4, just going to fix things up for now
1982/1989 K5/GMC Jimmy 2wd
1987 GMC 1/2 ton swb 2wd Crew (sold)
kevinr1970 is offline   Reply With Quote
Old 08-17-2010, 02:03 PM   #7
tvblazer78
Low & Fast!
tvblazer78's Avatar
Nice job...
tvblazer78 is offline   Reply With Quote
Old 08-17-2010, 03:03 PM   #8
Davidmichael
I could be mistaken, but I did not think the frame's were that radically different in the way they were made from a truck to a blazer to a suburban. I know they were different, but I thought the general area over the axle was the same. Like a c notch could be used with out any issue.
And that's a great looking blazer!
01 S10 ZR2
Old 08-17-2010, 08:26 PM   #9
kevinr1970
Maybe I am missing your meaning, but if you look at the pictures he posted, you can see the frame curves down in the area above the axle. The frame on a truck (and I assume a Sub') are flat through that area.
It's not that you can't use a notch, just that no one makes one, at least that I am aware of. If you know of a company offering them, please post a link!
2000 Tahoe Limited
Old 08-17-2010, 10:19 PM   #10
bigblock73
yeller
bigblock73's Avatar
I don't know man, most aftermarket truck notches go over the frame and use about double the number of bolts you have in yours...hopefully yours won't fail. Not saying it will, but just letting you know how the truck ones are built and installed.
bigblock73 is offline   Reply With Quote
Old 08-18-2010, 08:44 AM   #11
Davidmichael
http://www.airbagit.com/product-p/fli-che-04.htm
http://www.stillen.com/product.asp?i...KIT&c=SU&m=all Part number BEL6852
http://www.streetperformance.com/aut...604-100582vcb/
http://www.summitracing.com/parts/BEL-6852/
I don't know if they are different but at least they say it's for your Blazer.
01 S10 ZR2
Old 08-18-2010, 11:05 AM   #12
stevieB
stevieB's Avatar
I built it to mimick the universal ones. not the wrap around ones. I also plated the inside of the frame. so there is over a 1/2 inch of steel that those bolts are through. Now that you mention I have some material left over, I think im gonna weld it to the bottom so it wraps the bottom, and put a couple extra bolts there. Better safe then sorry. But failure is always an option, it is how we learn.
Old 08-18-2010, 12:42 PM   #13
tvblazer78
Low & Fast!
tvblazer78's Avatar
If your not towing with it you should be ok with that.
Old 08-18-2010, 12:53 PM   #14
lakeroadster
Good advice!
Notches such as these really do affect towing and load hauling capacities drastically, especially on leaf spring suspensions. If you aren't using your truck for towing or hauling purposes then no big deal.
I am not preaching, do what you like, I just want you to be aware of what these changes do to the strength of the frame.
Want to know more about why this is? Here is a thread from the 60-66 forum where this was discussed at length:
http://67-72chevytrucks.com/vboard/s...ighlight=notch
lakeroadster is offline   Reply With Quote
Old 08-18-2010, 01:01 PM   #15
stevieB
stevieB's Avatar
Well I will not be towing at all, but sometimes i will have passangers in the back seat. Any feedback is good feedback, better than scrartching my head.
really appreciate it!
gettin new tires this saturday, ill post more pics
Old 08-18-2010, 01:07 PM   #16
tvblazer78
Low & Fast!
tvblazer78's Avatar
Good info Thanks for posting that link..
Old 08-18-2010, 05:10 PM   #17
kevinr1970
I am not trying to argue with you nor am I out to prove you wrong!!!
I am just putting what I found so in the future if someone finds this thread they will see what was found.
The image with this part has an odd shaped C-notch, which is promising. But the "model" section says "C10, Blazer" and they can't be the same (if they wrap the frame).
BELLTECH FLIP KIT FLIP KIT GM C-10 6" DROP MINUS C-SECTIONS 73-87
None of the kits mention a C-notch, maybe I missed that part? But they all say "Sorry! Currently no stores sell this product."
This is a flip kit, but it doesn't indicate a C-notch. I looked trhough both Summit and Jeggs before using my specific year and vehicle and didn't even come up with the filp-kit???
Thanks for the links!
That first one (airbagit) has promise. As I get my crew to a driving state and turn back to the Blazer, I will investigate it further.
Thanks for the research!
2000 Tahoe Limited
Old 08-18-2010, 05:55 PM   #18
Davidmichael
Yeah I am glad you are going to reinforce it. I just hate to see when people try and make something that the aftermarket may have, but then you hear a horrible story about a wreck or it messed up there truck more. Yeah the search was just a quick 2 minute search this morning after I just got off a 16 hour shift. The screen was all blurry so I did not read everything.
01 S10 ZR2
Old 08-18-2010, 07:27 PM   #19
SBTork
Garage wrench
SBTork's Avatar
Not to hi-jack, but I just flipped the rear in my suburban and was thinking about using a notch of this style and had planned on doing some towing. Nothing really really heavy, just a smaller camper and the occasional car. Do you, or anyone, have any idea's on how to notch the frame and have it strong enough for towing. I also have some load leveling type air bags to add, if that factors into anyone advice. Thanks.
-Adam
90 V1500 GMC Suburban 350/700R4/NP241.....
01 Saturn SL1 stock DD.....
SBTork is offline   Reply With Quote
Old 08-19-2010, 08:25 AM   #20
tvblazer78
Low & Fast!
tvblazer78's Avatar
The best thing to do is weld it in, you can us a 6" pipe and cut it in half and then weld it in. Only cut what you need to on the frame, do not cut more then you need, it need to fit tite. Here is a pic.
Old 08-19-2010, 06:12 PM   #21
SBTork
Garage wrench
SBTork's Avatar
Thanks Travis, that's what I was looking for. So if I weld in a pipe like section and box the frame over the axle and a little infront of and behind it I should be ok, right?
-Adam
Old 08-19-2010, 08:47 PM   #22
tvblazer78
Low & Fast!
tvblazer78's Avatar
Ya you so be ok.
Old 08-19-2010, 08:49 PM   #23
N2TRUX
Happy to be here
N2TRUX's Avatar
Thanks Travis, that's what I was looking for. So if I weld in a pipe like section and box the frame over the axle and a little in front of and behind it I should be ok, right?
Yes, it should be fine.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 08-20-2010, 10:06 AM   #24
blazn79
I used McGaughy's C-10 notches and had a buddy of mine who does welding and metal fab modify them to work on the blazer frame here's a diagram and pics!
Name:  C-Notch Diagram.jpg
blazn79 is offline   Reply With Quote
Old 08-20-2010, 09:56 PM   #25
N2TRUX
Happy to be here
N2TRUX's Avatar
Great idea..
Articles-
"Refining Sierra"
