Old 08-17-2010, 08:02 AM   #1
nlped
nlped's Avatar
2wd vs. 4wd rear leaf springs?
Hey All,
Are 4wd Leaf springs and 2wd leaf springs interchangable? I need to get the rear of my '76 up just a couple of inches. I have put the 4wd Tahoe leafs on it, and flipped it, but it is WAY low. Like, the rear receiver hitch is about 2" off the ground, and I tow a boat, so this is too low. So, I was wondering if the 4wd leafs were the same length, eye to eye, and do they have more of an arch?
I gotta get this raised up just a bit...Help!!!
Carter
1968 Chevy SWB Fleet... Walt
1963-1/2 Ford Falcon Futura...Martha
nlped is offline   Reply With Quote
Old 08-17-2010, 08:23 AM   #2
tvblazer78
Low & Fast!
tvblazer78's Avatar
Re: 2wd vs. 4wd rear leaf springs?
I am not sure about that, sorry that your leafs did not work right..
tvblazer78 is offline   Reply With Quote
Old 08-17-2010, 05:21 PM   #3
nlped
nlped's Avatar
Not your fault. It has 2-3 inches for of travel, but it is just a bit lower than I would like. If I just wanted it slammed, it would be awesome! I may just put leaf mounted bags on it.
Carter
Old 08-17-2010, 08:17 PM   #4
kevinr1970
How much total drop did you end up with using the newer springs and the flip?
I am planning on going that route (or similar) and am hoping for no more than ~3".
2009 Honda Fit CfC (bsf 44.9 mpg)
2000 Tahoe Limited
1991 GMC CrewCab Dually 2wd, will end up swb, not dually and replace CCswb below
1991 GMC CrewCab Dually 4x4, just going to fix things up for now
1982/1989 K5/GMC Jimmy 2wd
1987 GMC 1/2 ton swb 2wd Crew (sold)
kevinr1970 is offline   Reply With Quote
Old 08-18-2010, 01:34 AM   #5
bluex
bluex's Avatar
I think they are the same. The difference between 2/4wd is in the shackle hangers that are rivited on the frame. The 4wd ones are about 2" lower/longer if I remember right. This drops the spring mount down and raises the truck up.
bluex is offline   Reply With Quote
