Old 08-19-2010, 12:07 AM   #1
72marino
decode me please.....
new to the old trucks so i am looking for some info on my truck. any info would help me out. thanks! vin, ccs142s125406 model cs10934 with base 127.c 18x210 body side molding 15422c white/medium blue. which moldings are correct for this truck? 250 6cyl 3 on the tree. also looking for paint codes and possibly rear gear ratio
72marino is offline   Reply With Quote
Old 08-19-2010, 04:45 AM   #2
OARNGESI
OARNGESI's Avatar
Re: decode me please.....
Is the sticker still on the inside of your glovebox if it is that should let you know everything
70 SWB STEPSIDE
70 BLAZER
09 challenger
OARNGESI is offline   Reply With Quote
Old 08-19-2010, 07:29 AM   #3
72marino
yeup, thats where i got all the info i listed. i just dont know what that side moldings look like, the gear ratio or the actual paint code for the med blue. id like to stick with the factory blue, but two tone with silver (paint code 519f)
Old 08-20-2010, 01:29 PM   #4
bruceman1968
bruceman1968's Avatar
Marino, First off welcome to the board. Your vin decodes as;
C= chevy (72 only)
C=2wd
S= 6cyl
1= 1/2 ton
4= pickup
2= 1972
S= st. louis assy plant
1= is a place marker
25406= 25406th truck produced /production number
Your model number decodes as;
C=2wd
S=6cyl
1= 1/2 ton
09= cowl to axel 54" to 59" (longbed or lwb)
34= cab and fleetside box
Here is a link if you want to see for yourself http://www.lmctruck.com/icatalog/cb/full.aspx?Page=10
As for the molding code you have 18x210, that's probably 1bx210 or bx2= body side molding wide LWR. But I'm not sure what it looks like. Rpo codes are 3 digits but some spids have 6 or 7 digits. Here is a link for RPO codes http://outintheshop.com/options.html On the paint 15422C is 542= 510 med. blue and 521 white here is a link for that, Check both pages 1 and 2 http://www.tcpglobal.com/autocolorli...truck-pg01.jpg As for the rear end ratio if it's not on the spid or build sheet then jack up the rear end and spin the tire one turn, as your doing that count how many times the dirveshaft goes around and that will get you close if not right on. Sorry I can't be more help on the moldings, but try lmc catolog pg 38 to 40 http://www.lmctruck.com/icatalog/cb/t.aspx?Page=39 may be some info there. Nice looking truck you got BTW,
CHEVY/GMC VIN DECODERS
bruceman1968 is offline   Reply With Quote
Old 08-20-2010, 08:09 PM   #5
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
inline 6 and a 3 speed would mean 3.73 gears unless otherwise optioned. If its not on the SPID (the option sheet you got all your info off of) then it has no optional gear.
Old 08-20-2010, 09:40 PM   #6
72marino
Smile Re: decode me please.....
thank you guys very much!!!
