08-19-2010, 12:17 AM | #1 |
Radiator mounts
I have a 1970 frame and I am putting a 1968 radiator support on the 70 frame, which radiator mounts do I use?
08-19-2010, 12:29 AM | #2 |
Re: Radiator mounts
The radiator support mounts on a 70 are different from a 68.
08-19-2010, 02:09 AM | #3 |
Re: Radiator mounts
Are you using the whole 68 frontend clip or just the radiator support?
72 Cheyenne Super 80 Silverado Blazer 2wd |
08-19-2010, 08:45 AM | #4 |
Re: Radiator mounts
radiator supports are different from 68 to 70 intirely. depending on if you have a 3flu or 4flu makes a difference in where the radiator mounts and the retainers that hold them in place also! 4flu is wider than a 3flu.
Things happen for a reason! |
08-19-2010, 09:53 AM | #5 |
Re: Radiator mounts
I am using the whole front clip off a 68 truck.
08-19-2010, 10:31 AM | #6 |
Re: Radiator mounts
Ok I see now, No the bushens are also different, you will need to get new ones for the 68 front clip!
08-19-2010, 11:55 AM | #7 |
Re: Radiator mounts
Does it matter that the mounts on the 70 frame have bigger openings than the 68?
08-19-2010, 01:24 PM | #8 |
Re: Radiator mounts
That's a good ? There should be plenty of people on here who have done the front clip swap that can help. I would think you would use the 69-72 mounts because the radiator supports are the same on 67-72 except for the headlight brackets. So the difference for the core support mounts, you would think, is for the different size holes for the brackets attached to the frame. Some one who has done the swap will chime in soon enough....
08-19-2010, 01:28 PM | #9 |
Moderator
Re: Radiator mounts
Use the core mounts that correspond to the year of the frame you are using. In your case, use the 69-72 core mounts. This is your answer.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul Last edited by leddzepp; 08-19-2010 at 01:37 PM. |
08-19-2010, 01:30 PM | #10 |
Re: Radiator mounts
If I'm not mistaken the 67-68 bushen's are not as tall as the 69-72 bushen's.
08-19-2010, 01:32 PM | #11 |
Re: Radiator mounts
pics
08-19-2010, 04:57 PM | #12 |
Re: Radiator mounts
Thanks for all your help. I hope they work. I'm also looking for the best company that sells bed sides for my short box, any suggestions?
