Old 08-19-2010, 02:23 AM   #1
evilways
evilways's Avatar
How important is this part?
I see a lot of people missing this, as well as myself. Is this needed? I figure it was put there for a reason. Someone school me here.
Mark
1967 C/10 stepside lwb daily driver
1968 C/10 fleetside lwb parts truck
1971 Cheyenne Super swb project
evilways is offline   Reply With Quote
Old 08-19-2010, 02:29 AM   #2
67ChevyRedneck
67ChevyRedneck's Avatar
Re: How important is this part?
What the crap is that...
My 67 did not have that, neither did the 71 GMC I stole the front disc suspension from...
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 08-19-2010, 02:51 AM   #3
evilways
evilways's Avatar
Yeah, I've only seen it on a couple trucks that I have come across. I am guessing it’s not a big deal, but wanted some input before I start assembling my frame. I thought it might be a 4x4 add on for little extra support???
Mark
Old 08-19-2010, 02:55 AM   #4
67ChevyRedneck
4x4's had straight axles and leaf springs.
Maybe a 3/4-1ton thing for 2wds?
Jesse James
Project "On a Dime"
Old 08-19-2010, 02:58 AM   #5
evilways
evilways's Avatar
You’re correct! I just started searching pics and thought to myself what the f*%@ was I thinking, so disregard that.
Mark
Old 08-19-2010, 03:08 AM   #6
evilways
evilways's Avatar
Found one, Ackattack has them on his 68 swb. I think it started its life a 1/2 ton? but then he also could have added them too.
Mark
Old 08-20-2010, 05:24 AM   #7
evilways
evilways's Avatar
Anyone else like to add?
Mark
Old 08-20-2010, 08:57 AM   #8
Sammy
First one I've ever seen.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL"
"You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig."
ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629"
Sammy is offline   Reply With Quote
Old 08-20-2010, 10:13 AM   #9
1970 CST Short Wide
Senior Moment
1970 CST Short Wide's Avatar
I found a set on a Big Block truck and were told it was to stiffin the frame ???????????????? I think put them on the shelf, I'll have to take another look see
1970 CST LS 1 6 speed Ford 9 inch Detroit Tru Track, Dakota Didgital, Vintage Air, QA1 Coil Overs Front & Rear Lots of FUN
2013 GMC PU, Oldest Son
71 GMC LWB. QA1 Suspension, Angry SB. Youngest Son
2019 GMC Diesil Dually. Youngest Son
2017 Toyota SUV Daughters car
2018 Traverse , Wife’s Ride
Pittsburg Ca
94565
1970 CST Short Wide is offline   Reply With Quote
Old 08-20-2010, 01:04 PM   #10
SWB4x4
SWB4x4's Avatar
I'd put my $ on that makes the most sense
J.T.
1972 SWB 4X4 on 35"s with 6" lift all around 3/4 ton running gear with high steer and 4.88s 350/th350. SOON TO BE DONE:2" higher in front 37"s,LSX Swap,Hugger Orange & White Paint Scheme,Air Conditioning,Power Windows & Locks,Complete Gauge Kit,Tank Relocation,Double Din Nav with full Audio System.
My Build Thread http://67-72chevytrucks.com/vboard/s...=1#post4169140
SWB4x4 is offline   Reply With Quote
Old 08-20-2010, 01:34 PM   #11
hounddogs!
Restoring it $200 at a time...
hounddogs!'s Avatar
Not on the 71 3/4T stub I just got from teeitup.
Charter member of the 'Put the dimmer switch back on the damn floor where it belongs' Society
'68 5.3L-4 speed LWB C20; grandpa bought it for the farm in '71. Now LS 5.3, rather than 327.
DD '09 Pilot
Weekender '65 Skylark 300-4V-4 speed
Wife's '07 Lexus ES350; 117 actuator motors and I can't see the engine.
Son's '04 F250 SuperCab 6.0
hounddogs! is offline   Reply With Quote
Old 08-20-2010, 02:04 PM   #12
Truckbert-CS
I switched my front cross member with an 81 chevy. My 69 did not have it but the 81 did so I put it on after I cleaned it up. It seems to be just a little more bracing.
TW
Truckbert-CS is offline   Reply With Quote
Old 08-20-2010, 02:47 PM   #13
sizzle-fry
sizzle-fry's Avatar
Hola,
Turns out that my 68 LWB C20 does not have this either. Bet its like 1970 cst sw said - big block weight or torque support - if it is stock part like drawing suggests. Someone said they knew where to get, got link? Extra strength sure sounds OK to me if the bolts are long enough for the extra 1/4 inch.
Here's mine:
http://67-72chevytrucks.com/vboard/s...6&postcount=23
and forgive external link but:
http://public.bay.livefilestore.com/...778.jpg?psid=1
1968 C20 CST 327/T400
http://67-72chevytrucks.com/vboard/s...d.php?t=394124
sizzle-fry is offline   Reply With Quote
Old 08-20-2010, 02:51 PM   #14
RichardJ
On my '67 3/4 ton, the angle pieces (blue arrow) that are riveted to the crossmember are forged steel. I removed the complete suspension from a '76 3/4 with big block for the disc brake conversion. The '76 had pressed steel angle brackets, but had these extra pieces on the inside of the frame rail.
I put the '67 crossmember back on the truck because I liked the forged ears better. I had to take it apart anyway to keep the original 6 cyl springs and change the bushings.
The top bolt hole on the bracket had to be redrilled to line up with an existing hole on the frame rail top. Just as with a crossmember switch, the inside bracket had one hole that lined up, one that had to be redrilled and two that had to be elongated.
These inside brackets are a lot beefier than the ones you have shown.
This is driver side, inside frame rail shown.
'67 GMC 2500, 292, 4spd, AC
RichardJ is offline   Reply With Quote
Old 08-20-2010, 02:56 PM   #15
leddzepp
Moderator
leddzepp's Avatar
I agree. These were also on my 72 BBC truck.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
